Question about Sanyo 24KS32A Cool Mini Split Air Conditioner
I have a Mistral Inverter Reverse Cycle Split System Air Conditioner. MSS.3INV. The trouble we are having is the cooling will work for half an hour or so and the compressor will turn off leaving only the fan going and the comporessor and timer light flashing. This hapens before the desired cooling temp is reached. You can switch the main power off to the unit and back on again after a few minutes have past and the unit will operate again in cooling mode and then just do the same thing. The gas has been checked and it is full. It is if the programing if any isn't working properly. I have been told you can"t get parts for Mistral anymore either. Can you help?
  • npidgeon110 Sep 28, 2010
    I would have thought, that if the termostat was not working, then it would not work at all. But every time you turn the unit on, it will cool for half to one hour each time, before the compressor shuts down and only the fan operates until the unit is turned off then on again.
  • npidgeon110 Sep 29, 2010
    One would have thought, that if the thermostat had packed it in, the air con would just blow warm air every time you turned it on, but it works,cooling like normal for half to one hour.
    Every time you turn the unit on, it will cool like it should, then it turns to just the fan.
    Genius:
  • 1,416 Answers
What this problem indicate is that the thermostat of the air condition has been gone bad.
When ever an refrigerator does such it simply mean that thermostat need to be replace by some time it could be on the time programming
note , this problem is on the thermostat you can get the (part)replacement at the below site if you which to order for it livesupport.maybenow.com
or you invite then to visit the system only if you can not carry out the solution your self
To do this fix up your on then carefully unscrew the screw on the condition
thank you and thanks for using fixya.
Posted on Sep 28, 2010
  • Oloyede Monsuru Sep 28, 2010
    hello,
    what is the problem like ?
    After the above solution.
Need to know what error 6 on a minstrel air conditioner unit.Also can you scan and email me the manual for a Chunghop K 1028E 1000 1 Uinverisal remote. Thanks Gwenda
Hope this helps
error code is the fan in the head unit (indoor part) of the split system. After rining around for hours this morning - the number to get parts Mistral Bellini & Ringroup. 1300 373 199 They are based in Melbourne.
Apr 03, 2017 | Heating & Cooling
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
RETAIL PRICE FOR ONIX REVERSE CYCLE SPLIT SYSTEM
contact shops that install units and get quotes. retailers generally have contractors that will give quotes for installation on new units.
Jan 01, 2015 | Heating & Cooling
Hi I have a mistral reverse cycle a/c model MSS 15 the fan works but the air coming out is not refrigerated.
Check if your a/c unit needs cleaning dirt's sometimes causes not to cool the air. But if your unit is clean then your compressor needs to be re-charged with freon.
Nov 12, 2010 | Heating & Cooling
Low refrigerant?
never of you have no leak but if every thing is working and it is not cooling them you may need to do that...
Nov 08, 2009 | LG Art Cool LA1000PR Air Conditioner
Mistral mss15 aircon will not operate on heat setting , not sure if it is being set properly because cannot understand remote control symbols
My Mistral was working yesterday (on heat) now it won't. Just sits there as if warming up but actually blows out freezing air - on "sun" mode.
Jul 12, 2009 | Sanyo 24KS32A Cool Mini Split Air...
Fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Feb 16, 2009 | Cfm Daikin R410a Split System Air...
Hitachi RAS-63CHA2 split system reverse cycle air con
You can try universalremote.com but it cost me 15USD for digital delivery. Its better than being cold and I have spent hours on the net to no avail.
May 22, 2008 | Hitachi RAS-09UH Air Conditioner
Sanyo 24KS32A Cool Mini Split Air Conditioner Logo
368 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
