Question about Dell Inspiron 1000 Notebook
My laptop won't turn on. it seems that during my previouse use, something got burned inside. do you think it is still repairable? what part might have been affected.
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 28, 2010
Won't burn DVD data discs, error code 0x207
Have you looked at this from ACER: http://acer--uk.custhelp.com/app/answers/detail/a_id/3410/~/error-code-0x207-shows-during-recovery-dvd-creation I'm sure you already know it seems to be a common problem. Every post seems to point to Media type , can't use RW disk, +or-, seems kink of finicky which seems odd. Only use DVD+R or DVD-R.
Apr 02, 2013 | Acer Aspire 53362524 Intel Celeron 900 2....
Panasonic tc-p60gt30 won't turn on. Something hit screen. Screen did not crack but now won't turn on
May have damaged the PDP (plasma display panel) inside---if the panel which is fragile shorted inside it will trigger shutdown.
Aug 28, 2012 | Panasonic 60 TCP60GT30 3D Plasma TV
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
Kitchen aid dw won't start,, the lights come on it beeps at me but won't start the cycle... also, during a cycle i can open the door and it doesnt halt the cycle, it just keeps on going
see this causes:
Power from the house
reset the c.breaker from your hose or replace blown fuse inside the machine.
Door switch
test the door switch for open or defective this will NOT permit to close the relais for start the motor
Wiring
loose wiring, break or burn repair
Timer or selector switch
selector switch, open or defective, timer defective, however clean contacts diryt or oxide, loose wires, break or burn. GOD BLESS YOU.
Jun 21, 2012 | KitchenAid Dishwashers
Dv7 motherboard won't turn on
used good power jack and check for wrong soldering&tracks cat
then joint the power jack its work
Feb 09, 2012 | Computers & Internet
WHY DOES THE BELT BURN OFF LIKE A VAC BELT
Take the belt off and try turning everything it turns like the transmission or pump . I think that model has a seperate pump. If something won't turn that is your problem. It can't turn, the belt slips and burns. Hope this helps.
May 03, 2011 | GE Profile Prodigy WPSE4200A
PROVIEW PL-456S LCD MONITOR TURNING PINK ON ONE SIDE
Chances are that you are not hurting anything with the lower power supply. What is probably happening is most likely two fold. 1. The light bulbs in the backlight circuit may just be wearing out and need replacement, and 2. the lower current power supply may not be capable of producing al the current that the monitor needs at certain times during operation. I would suggest getting hold of the correct power supply module and see where that gets you. If you still have the red outs,replace the light bulbs in the monitor. The only other fault than that would have to be in the video controller. Hope this helps.
Oct 03, 2007 | Proview PL 566s 15" Flat Panel LCD Monitor
T.V. TURNS OFF
Sounds like somethings over heating if you smell something. The wise thing to do if you know nothing at all about the tv repair is to call someone unless you feel convident enough to open it and look around very carefully and see if you can describe whats over heating or burning as if you keep turning on the set and it keeps smelling it will burn something out thats not burned out now.
Mar 24, 2006 | Mitsubishi VS-60609 60" Rear Projection...
Dell Inspiron 1000 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
