Question about LG 37LC7D 37 in. LCD HDTV
I have an LG 37LC7D, whenever I turn it on once its been sitting unplugged for a while, it comes to life perfectly for about 3 secs (can see video signal) then the screen shuts off for 3 secs, turns on for 3 secs, and repeat this 3 sec cycle about 10 - 15 times (green power light stays on entire time) before it seems to give up and turn itself off. Ive had the back off, there seems to be some squealing from the large black angled transformer on the power board each time it blinks on for 3 secs. (the best way to describe the sound is like the way a modem sounds while handshaking or faxing, just much quieter). if i keep trying to turn it on, it will turn on for 3 secs, then the screen will just shut off completely, green power light stays on for a while, then eventually turns red (off)
  • 12 more comments
  • Rommel Cana
    Rommel Cana Sep 28, 2010
    it only means that there is something that hinders the power supply from turning ON
    completely. Use a Multimeter to measure PSU output voltages
    to facilitate and diagnose properly , you need a service manual to guide you,
    http://www.service-manual.net/ashop/cata...
    only with a fee
    And bleed ( discharge ) the power capacitor with a 4.7K 5W resistor , when having
    a resistance check ( to be safe )
  • aekirwin Sep 28, 2010
    As a computer tech, im more into component swapping, not circuitry. im wondering if the issue is the power board or a ballast or something (maybe inverter). i found a replacement powerboard on ebay, but unlike troubleshooting computer hardware, im not positive about my diagnosis:P. Laptops have a small inverter that jacks up the voltage for the ccfl, however at first glance, it looks like this powerboard (p# EAY34796801) has an integrated inverter (the squeeling transformer), or is this just the first step before the high voltage gets carted off into the screen and jacked up even further by actual inverters that are out of view? the cables that go from this powerboard to the LCD look like larger versions of the unique wires that go from the inverter to the ccfl in an LCD on a laptop.
  • Rommel Cana
    same principle applies, remove the load from the power supply , to see where it acts up
    more details can be found on the service manual
  • Rommel Cana
    on the upper left side of the image :
    http://www.shopjimmy.com/lg-eay34796801-...
    you can measure the voltages on it, and post what you got,
    if the unit is in standby and when you try to turn it ON
    had it unplugged for a while, turned it on, stayed on for about 5 mins, started to flicker with zappy sounds from the large transformer on (bottom right of that image) whenever it flickered, after a few more flickers, it powered down. the contacts on the top left image that you are refering to go to the image processing board, which from what i can tell functions perfectly. are there inverter boards inside the panel, or is that zapping transformer the actual inverter for the ccfl? i bought that service manual but it was not very helpful (my understanding of circuitry is severely lacking). i was more hoping maybe you can identify and confirm the power board as the cause so i can just buy a new one:P can a failing ccfl tube cause this in a tv? (cant on a laptop) if i were to compare these symptoms to a laptop, id be absolutely positive its inverter. what i havent been able to identify is if the power board has the inverter built in, or are they built into the panel where i cant see them without taking the tv apart further, and possibly malfunctioning causing the effects (buzzing from transformer) that i see on the power board. in which case if i replace the power board, I've got the same issue. I truly appreciate all your help.
    id be happy to email you a hi res pic of the back of the tv, a low res vid of the tv in action, and the repair manual if you had some spare time....
  • Rommel Cana
    you can send a link where I can view , to help you further , and i need the voltage measurement
  • Rommel Cana
    you will have to check the P_ +19V
    + 12V
    + 9v
    + 6v
    ST 5V
    3.3 V
  • Rommel Cana
    on page 8 of your service manual you can see that the
    LVDS is powered by 12V
    Try to find that line , and disconnect the 12 V that goes to the Inverter,
    Be fast enough to catch the voltage , it drifts easily,
    ground or connect the negative of your Multimeter to the chassis
    ( when measuring voltages )
  • Rommel Cana
    i mean page 18
  • Rommel Cana
    then follow the flow diagram on page 19 ,
    and post what you found
  • Rommel Cana
    EAY34796801 is only a power supply board
  • Rommel Cana
    your inverter board may look like these :
    http://www.discount-merchant.com/LG-6632...
  • Rommel Cana
    Please be guided that the Inverter Output Voltage can reach over 1.2KV ( ballast )
    if it is working
  • 346 Answers
SOURCE: LG LCD TV 32LC4R BLACK SCREEN
change the power regulator
Posted on Nov 01, 2007
  • 12 Answers
SOURCE: 42" LG 42LC2D HDTV Will not turn on
Hi, sounds like a power supply problem, most likely needs capacitors replaced, costs about £5 to do it yourself, and a fortune in the repair shop, easy enough if your handy or know someone who is,its worth a try,it'll be going in the bin anyway, cam
Posted on Jul 14, 2009
  • 5 Answers
SOURCE: LG 47LC7DF Green Light Blinks 16 Times - No Picture or Sound
The lights indicate what the issue is. Kind of like your check engine light in your car tells you something is wrong with the engine.
Posted on Aug 31, 2009
circuitworld
  • 335 Answers
SOURCE: My 42 inch LG plasma turns on and off repeatedly
Theres a short between the start-up processor signal on the interface board and power supply. It keeps sending the same start-byte over and over again to the power board. This could also be a DC high voltage shutdown on the power board its self. Now the tv is in protection mode to prevent further damage. Get it serviced at your local repair center. If its under warranty take it back.
Posted on Nov 04, 2009
SOURCE: No Sound, No Picture on LG 42LC7D
I do not have a solution but I have the same situation with my tv
Posted on May 25, 2010
So i ordered a new power supply board for my LG 55la7400 television set...part was a perfect match..it went on smoothly with no issues whatsoever. Still just comes on and then black screen
Is it the same as it was before? If so You may have replaced the wrong board, but chances are if tv has a back light it's the problem. It would prob. be cheaper to have a tech. fix it the long run. You might try youtube videos they might help solve your problem. With electronics today their cheap & they don't last long.
Nov 10, 2015 | LG 55LA7400 55-inch 240hz Cinema 3D Smart...
On/off problems with my LG 37LC7D TV. It is hooked up to Direct TV
You need to contact a local TV repair service, UNLESS you have the tools and the repair manual to repair it yourself, it will take diagnostic work to determine what is the cause, one thing is for sure you have a defective circuit board.
Jul 16, 2017 | LG 37LC7D 37 in. LCD HDTV
LG 37LC7D HDTV just went blank. Screen blacked out and green light is on but no response to input change, remote, volume, or channel change. I've unplugged it for several minutes in an effort to reboot...
My lg 37lc7d is having the same problem. My backlight is on but no display. Also the standby light blinks several times then the screen goes on but it's just all black. No a/v
Feb 08, 2011 | LG 37LC7D 37 in. LCD HDTV
LG 37LC7D 37-inch 720p LCD HDTV
Unplug it for about an hour to let it reset itself and try again, if it still has problem then you will have to open it up or take it to the repair shop. The power supply module will have to be looked at first to make sure all the voltages are present. Right now the 5vdc standby power supply is working and may be partially function processor.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 10, 2010 | LG 37LC7D 37 in. LCD HDTV
Lg lcd tv and the liquid crystal display light is on
U have cables,satalites or telicom compannies pay services?Unplug the tv and any of those services box about an hour,replug both back let the box upgrade it software.Turn on the tv.The tv push the button on the remote said Menu.PICTURE go down to reset,the tv now reset it back to factory setting.The air broscasting signal,now should on ur tv.
Jun 23, 2010 | LG 37LC7D 37 in. LCD HDTV
Truble switching on tv
its repair immediatly its a power supply problem,
Apr 14, 2010 | LG 37LC7D 37 in. LCD HDTV
37'' LG lcd tv, no power
I just want to clear things here.
The stand by light will remain on whenever the tv set is turned on by a button on the side of the tv.
Then use your remote to turn on the tv, but wait as it can take 10secs before you get a picture.
Nov 04, 2009 | LG 37LC7D 37 in. LCD HDTV
LG 37LC7D
Howard,
Do not keep forcing this unit on - - This particular unit has a VERY commonly known problem and there are at least five tech bulletins from LG explaining this and other symptoms for the failure. In a nutshell there are coils that have to be removed and replaced with a jumper wire. This is not a repair you want to tackle so please get some experienced help for this one. A good technician will look-up the bulletins and educate themselves on the manner of the repair.
Almost all of the symptoms that can happen are intermittent and can be extremely difficult to verify. For this reason make sure to discuss with the technician that he replace all of the coils listed in the bulletin not just the ones causing your particular problem. Here's a list of symptoms that these defective coils cause, taken right from the bulletin:
1. Channels Or Menu Functions Scroll On Their Own
2. Remote Does Not Function
3. Tv Randomly Powers On And Off On Its Own
4. Dead
5. No Backlight
Hope this helps!
William Rayburn, CET
Premium Technologies
Aug 03, 2009 | Televison & Video
LG 37LC7D 37 in. LCD HDTV Logo
828 people viewed this question
Computer Repairing
Computer Repairing
