Question about Sharp VC-A411U VHS VCR
After recording using automatic timer to stop the recording all lights blink rapidly and nothing works. Did a power cycle, and it worked the first time but I recorded again and it seized up again but now nothing will work after another power cycle. Have a cassette stuck in it and can't get it out. It is 1 years old. Serial # 109733919.
  • duhowe Sep 28, 2010
    Somehow the age of the VCR got changed from 10 years to 1 year, but I don't think this will change the diagnosis.I have tried the power cycling numerous times without success, so I guess it is a lost cause. Thanks for response.
    accepted
    President:
  • 2,777 Answers
Yikes, that is very unfortunate, it sounds like internal hardware malfunction for sure. Try to power cycle again, completely unplugging for at least 30 seconds and hitting a few buttons while unplugged to drain capacitors. Then plug in, immediately turn on, and right away try to EJECT the tape in there. Let me know if you can at least get that out. From there, since it is such a new machine, you will want to contact Sharp and try to file a warranty claim on this VCR, it is definitely experiencing hardware failure.
Let me know!
Tim
Posted on Sep 28, 2010
  • Tim Grayson
    Tim Grayson Sep 28, 2010
    Oh haha, I figured it couldn't be 1 year old, but was thinking possibly you found it somewhere :). So sorry about that, lucking VCRs can be head for a very low price on ebay... I'd just replace it for sure.
    Also, if you get a chance, please make sure to come back to the question here and click the Accept This Solution link otherwise I get no credit for the help, thanks so much.
    Thanks
    Tim
Frigidaire AEQ8700FGO dryer will run (and heat) for about 30 to 60 seconds then stop. 3 lights above start button will flash rapidly. Depressing cancel and start buttons at same time will not work for...
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it
Sep 30, 2013 | Electrolux AEQ8700F Electric Dryer
I bought a house with a Night Sentry Solid State Timer model # EJ341 and have no instructions on setting or programming the unit.
rapid Programming.
1. Move control lever to OFFCLEAR for at least 5 seconds
• red indicator light goes off
• all time settings are
erased.
2. Move control lever to ON.
• red indicator light will start
flashing.
3. Check a clock; then turn pushbutton time dial clockwise at least one click.
• stop at the half hour nearest to present time (note
AM or PM).
Note: When turning pushbutton time dial, do NOT
accidentally PRESS at the same time.
4. Press pushbutton time dial once to enter present time.
• red indicator light goes off (present time has been
recorded).
5. Turn pushbutton time dial clockwise to desired
ON time.
• red indicator light blinks with each click.
6. Press pushbutton to enter ON time.
• controlled light(s) will turn on.
7. Turn pushbutton time dial clockwise to desired
OFF time.
8. Press pushbutton time dial to enter OFF time.
• controlled light(s) turn off.
9. Repeat 5-8 for other on/off times.
10.Turn pushbutton time dial for at least 2 more turns
from the first ON time to complete this program
• red indicator light will turn on and stay on (steady
light means timer is in automatic).
Note: Pushbutton time dial does not turn
automatically after setting to indicate time of day
Aug 22, 2010 | Hardware & Accessories
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Mitsubishi TV WD-62527 will not turn on
Hi there, this is most commonly known as power board failure in the industry. the capacitors are blown. if you are experienced in inspecting circuit boards this will be helpful. you will have to disassemble and pull the power board and preform a break point test. the bown capacitors are easily picked out. they will be swollen and discolored. If you are not comfortable with disassembling this set, i suggest a service call. just tell the tech you are experiencing a power board failure.
Mar 07, 2009 | Mitsubishi WD-62827 62" Television
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Problems with Whirlpool dishwasher model GU1500XTKB0
have they checked the thernals on the bottom of the tub
Mar 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Blinking Green Light on Mitsubishi DLP 52525
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Jan 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Sharp VC-A411U VHS VCR Logo
142 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
