Question about Blaupunkt Car Audio & Video
My fm frequency scan change to 0.2 units like from 93.70 to 93.90, how i can set it to 93.80
  • Blaupunkt Master
  • 17,130 Answers
On the backoff the set there can be small switch which can be set to read in tens. so check this out.
if not check if a manual setting will make it advance in fractions
Posted on Sep 28, 2010
How to program memory for radio stations
Scan until you find a station you like and remember the frequency, carry on until you find another station any station, put in the first frequency and quickly press and hold the button that you want to save it too until the unit beeps. Carry on for the rest of the buttons. Generally with the FM there are two sets of presets, one for each time you press the FM button. The display will usually show FM1 and FM2.
Jan 16, 2016 | Car Audio & Video
How do I access the settings to change the area for local fm frequencies?
Which radio do you own, first of all? Also you MUST unplug any cables from the audio connector - THEN - you can go to "MENU" and select your frequency. If you have an audio cable inserted, nearly every unit will NOT let you select the FM frequency. Okay? Thanks.
Apr 04, 2015 | Audio Players & Recorders
Technics ST C04L
1. Search strong FM stereo station. (Like 97.05Mhz instead of 97.00Mhz)
2. Turn off auto scan/FM mode.
3. Adjust the frequency to 97.00Mhz
4.Adjust the Filter T01 very gently (about 5 degrees clockwise) as to make the Quartz lock lamp light up.
5.Turn on auto scan/FM mode and check for FM stereo lamp
Oct 05, 2012 | Cars & Trucks
How do i change the AM radio to FM?
Hello
Press RADIO BAND.AUTO PRESET until the band you want appears in the display (direct power on). Each time you press this button, the indication changes as "FM" --> "AM". Hold down TUNE + or --, until the frequency digit begins to change in the display. The player automatically scans the radio frequencies and stops when it finds a clear station. If you can't tuned in a station, press the button repeatedly to change the frequency step by step. If FM broadcast is noisy, press "MODE" until "Mono" appears on the display and the radio will play in monatural without any noise. Only strong FM signals can be decoded to stereo. OK.
Oct 22, 2011 | Sony CFD-S300 Radio/Cassette/CD Boombox
My midland allen 78+ uk channel has changed to am it should be fm
I Italy 40 Ch AM/FM 4 Watts I2 Italy 34 Ch AM/FM 4 Watts D Germany 80 Ch FM 4Watts/ 12 Ch Am 1 Watt D2 Germany 40 Ch FM 4 Watts/ 12 Ch AM 1 Watt D3 Germany 80 Ch FM 4 Watts/ 40 Ch AM 1 Watt EU Europe 40 Ch FM 4 Watts / 40 Ch AM 1Watt EC CEPT 40 Ch FM 4 Watts E Spain 40 Ch AM/FM 4 Watts F France 40 Ch FM 4 Watts / 40 Ch AM 1 Watt UKE UK 40 Ch Fm 4 Watts UK frequencies UKC UK 40 Ch Fm 4 Watts CEPT frequencies PL Poland 40 Ch FM/AM 4 Watts midland alan 78 multi plus frequencies
Jun 06, 2009 | Midland 1001Z 40-Channels Base CB Radio
Trying to install Roady 2
If the Roady2 has a fm modulator built in, you can go to the menu and set the fm frequency. If it doesn't, you could use a fm transmitter that they have for mp3 players to listen to in the car
Apr 13, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
How to set up fm transmitter for sanyo gps nvn-4370
At the main menu press settings
press FM Transmitter
Turn transmitter on by pressing off. Will change to On
Press the Frequency button. Than change the frequency to one that doesnt have a radio station.
All sounds from the GPS will now be transmitted to the frequency set. Make sure your FM radio is set to the same frequency.
With my one vehicle this option does not work very well & is full of static because my radio entenna is at the rear of the car. The GPS only transmits a couple of feet.
Dec 27, 2008 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Pioneer GEX-FM903XM, system works great, however it often drops out and has just static. The signal indicator is strong. I think there is a bad connection into the radio. Where should I start...
It may be possible that the FM frequency chosen during setup, is in use in your area by a strong signal from a local station. Change to another frequency and see if the situation improves.
The following is from the Operation's Manual:
FM Modulator Setting
You can adjust FM Modulator frequency and output level.
7 Frequency
If output from the FM Modulator is hard to hear due to interference from a strong broadcast
station transmission, you can switch to another frequency.
You can adjust frequency between 87.9 and 90.1MHz.
7 Level
If the output sound is too quiet, too loud or distorted, you can adjust FM Modulator output
level.
You can adjust level between “LEVEL–1” and “LEVEL–7”.
1. Press the POWER button for 2 seconds to enter the FM Modulator Setting
mode.
2. Select the desired frequency
with the left/right arrow buttons.
3. Increase or decrease the Level
with the up/down arrows (buttons).
4. To cancel the FM Modulator Setting mode, press the POWER button again
for 2 seconds.
Note:
• After entering the FM Modulator Setting mode, if you do not perform an operation within about 8 seconds, the FM Modulator Setting is automatically canceled.
Nov 29, 2008 | Pioneer Car Audio & Video
Sirius S-50 Portable
Go to device settings - FM Frequencies - select the FM 1 or FM 2 or FM 3, turn the dial to move the FM frequency to that which you want. Press the Sirius Dog to enter this frequency. That's it.
Oct 20, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Radio set up on samsung j700
FM radio works the same way that AM radio works. The difference is in how the carrier wave is modulated, or altered. With AM radio, the amplitude, or overall strength, of the signal is varied to incorporate the sound information. With FM, the frequency (the number of times each second that the current changes direction) of the carrier signal is varied. FM signals have a great advantage over AM signals. Both signals are susceptible to slight changes in amplitude. With an AM broadcast, these changes result in static. With an FM broadcast, slight changes in amplitude don't matter -- since the audio signal is conveyed through changes in frequency, the FM receiver can just ignore changes in amplitude. The result: no static at all.
For sellecting frenquencies, go to radio, options, set frequency and search...
Jun 13, 2008 | Samsung Cell Phones
Car Audio & Video Logo
57 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
