Question about Bosch SHU4006 Dishwasher
My BOSCH dishwasher has stuck in wash and ringed. Even if I turn off and on, it starts from the same place and does not end. What do i do?
  • Bosch Master
  • 17,130 Answers
Possible that the porgram controller is faulty and is shorted inside this drive.
you will need to remove and reset once again to make sure all connections are tight, if not the controller must be checked or swapped to confirm
Posted on Sep 28, 2010
Bosch Classixx dishwasher fault
it can be a dry joint on the electronic board, or a defective thermostat, or the element, or an interrupted wire in the lower point of the door
Dec 23, 2013 | Bosch Dishwashers
Bosch Logixx won't start - Stuck on "Close the door" even though door is closed.
Open the door, look along the top stainless on the door and you should find the ENr number (model number) etched into the stainless, may need to give it a wipe and look at an angle to read it. Post the ENr and that should help with diagnosis.
Mar 15, 2013 | Bosch 24 in. SGS69L02 Logixx Built-in...
Bosch dishwasher turns on but doesn't fill with water and start washing
There is a float in the dishwasher that sometimes gets stuck and when that happens, the washer will not fill. Look for a (mostly round) upright part that will be in the front of the washer either on the left or right side. That is the float and it could be stuck in the cutoff position (caused by the soap). The older models have it on the same side where the soap is placed. The newer models have it on the opposite side to stop that exact problem. MOve it up and down and clean out any dried caked soap that might be under it.
Good Luck
Nov 19, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Classic Bosch Active & end light are alternately blinking rapidly when turned on. It will not start
Thisjust happened to me. The wash program wasnt set. Check thedial and make sure it is set to a wash program.
Feb 13, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishes not washed detergent still in compartment pump will not stop pumping bosch dishwasher
cycle stuck possibly..........unplug it or turn it off at the main electric box circuit breaker......wait 10 minutes and try it again.........
Feb 13, 2010 | Bosch Dishwashers
Bosch shu4006uc dishwasher timer problem
REPLACE YOUR MODULE. IM A OLD BOSCH TECH. POST 4 THUMBS FOR THE INFO THANKS
Feb 08, 2010 | Bosch SHU4006 Dishwasher
My Bosch SHV46C dishwasher keeps running, even when the door is open, unless you turn the control switch off. Then, when you turn the switch on, it starts running again.
I have a Bosch that was stuck in pump down mode even when the door was open.
The problem ended up being too much water in the drip pan below the unit. There is a float in the drip pan that actuates the same limit switch as the internal overfilled float.
I had recently cleaned the incoming water filter and must have loosened the water line tube.
Nov 20, 2009 | Bosch SHV46C03 Built-in Dishwasher
Bosch Dishwasher Maxx classixx Model S9H1B Lights stuck on end and last program.... will not reset nor start Think it just needs resetting ...but how?? Was working fine up to now Regards M
look carefully at operating buttons they will have 2 marked with a line with dots at either end, open door press and hold these 2 buttons usually 2 and 4 as from left too right, turn on keeping fingers on these buttons after a few seconds end light will come on turn off at main switch then back on again should work after that.
Nov 10, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch dishwasher
is all the water draining from the tub? if not the pressure switch will not reset and it will continue to try and clear it self...check drainage system.
2. pressure switch is jammed on..build up in the sensing chamber..common..or switch faulty...rarely
3. if water is in the bottom panel most have a flood switch which automatically operates the pump in case its over filling
Dec 04, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
141 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
