Question about Candy AQ130 Front Load Washer
Candy 140 CDN washer. Water won't drain or spin properly. Happened after I accidentally unplugged it midcycle. It has a white plug at front bottom left which I assume is how to remove the filter but it comes straight out and there's another black plug behind that looks pretty static. Do I try and force this black plug out or is the filter elsewhere?
2 Suggested Answers
SOURCE: Will not drain
I have a similar problem with my Candy WM801. However I cannot find the filter, it does not appear to be at the front... pulled it out and can't see anything obvious at the back either. Looking online for manuals, it should be simple shouldn't it!
Posted on Sep 23, 2008
Kenmore 90 series washer won't drain and go to spin cycle
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl say so.
Apr 02, 2013 | Kenmore 15864/15862 Top Load Washer
Fiirst started with a buzzing noise, then next load wouldn't spin proper, then not at all, unplugged washer to reset, tried a small load and it won't run water now,after running 10 to 15 minut
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp that connects the trap assembly to the pump and clean it out.
If helped, pl say so.
Apr 01, 2013 | Frigidaire Washing Machines
My Kenmore H2t front load washer won't drain and
Hallo there
So it will not do what it is told. This happened to my Candy machine the other day. It was finished and I opened the door, out came water and I got 5 towels on the floor to dry up the water. Closed the door again and put empty water on, it emptied the water, stopped the machine and put spin on and it made it.
My experience ,learned the hard way, to wait long enough after the machine stops as well as between changing programs.
I this will be of some use to you.
Kolbrun
Apr 15, 2012 | Kenmore Washing Machines
Ge washer won't let water spin out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
My candy 514 is not draining properly - even after a spin cycle the clothes are still very wet suggesting that water is not getting out
I have a GE and my friend has the same problem with his whirlpool. Removed the frt cover adn looking at the washer on the left side there is a clean out drain. My kids leave things in pockets and filles this drain up and washer will not drain. it is very easy to do
Oct 26, 2009 | Candy CNW136 Front Load Washer/Dryer
My kenmore front loader wont spin fast. it will spin when the clothes are washing slowly but wont spin fast to get rid of the water so clothes stay soaking wet.
Check your drain and make sure it isn't plugged. If ok then remove the bottom panel on the front of the machine. Under it is the washer pump. The pump is either clogged or bad. The washer will not go into a full spin when the water isn't draining properly.
Sep 16, 2009 | Washing Machines
Washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Mar 21, 2009 | GE Energy Star WCVH6260F Front Load Washer
Washer blink F1 and will not spin water out will not empty water out of drum keeps shutting down
I just had this problem and was able to fix it. Your pump filter is probably clogged. To get to it you need to remove the front bottom panel of washer. The screws for the panel are on the very bottom of the front. You will need a T20 screwdiver bit. Once you have removed the panel unscrew the white plug at the front (water might spill out so drain what water you can from the washtub with a shopvac, the have a shallow water pan under the white drain with the shopvac running. Clean out the debris in the filter chamber. If this does not correct the problem disconnect the black rubber drain from under the tub and check for anything clogging the drain. Good luck. Johnny C.
Dec 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine has intermittent drain issues with F02 code
When the three screws are out of the bottom, you should be able to pull the front panel down (towards the floor) and then out from the bottom. Unscrew the big white cap on the drain housing. Be prepped for the water. Most of the time the problem is due to **** in there.
Sep 04, 2008 | Kenmore 4292x Front Load Washer
Will not drain
Try cleaning the filter as when this gets all clogged up the water doesnt drain thru the pump
Apr 24, 2008 | Candy AQ130 Front Load Washer
Candy AQ130 Front Load Washer Logo
78 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
