Question about Honda 6370C - Parallel Power Kit For EU3000i
I have generac c 5000 series, that is 5000 watts . can you give me the equivalent watts given into Kva?
  • 1,476 Answers
Philliprabay,
This is the formula The conversion of W to KVA is governed by the equation KVA=W/(1000*PF)
For example 1500W/(1000*0.83) = 1.8 kVA (assuming a power factor of 0.83)
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Oct 02, 2010
Why centurion 5000w generator has no spark
change the cdi on the motor sounds like it is fried
Jun 08, 2014 | Generac 5622R GP5000 GP Series 5000 Watt...
My Generac GP5000 generator runs great for about 4 minutes until it heats up then it starts cutting out and backfiring until it ultimately dies and wont restart until it cools down. the generator has...
If it is new and under warranty, talk to Generac about getting it fixed.
If it is old and unused, it probably needs fuel system cleaned out. Carb needs to be removed and cleaned inside and out, fuel lines need flushing, filter changed and if it has an automatic choke, it needs to be checked because it sounds like it is stuck on.
Oct 03, 2012 | Generac 5622R GP5000 GP Series 5000 Watt...
Can i use my welder with my generac 5000 generator? my welder is 220VAC.
probably but it may be a streck 1300 watts may do it but it depends on the draw of the welder and it will be maxed out thats 13 100 watt light bulbs running at the same time use common sence
Nov 29, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
Generac 5623 GP6500 8000 Watt 389cc ohv will not stay running. Will only run for a few minutes then quit and then usually can't restart.
if the gerator runs pretty smooth up until then, i would suggest checking/changing your oil as the low oil level switch is picking up on a slight change in the oil level (easier to detect when oil is hot), if it start to give hesitation or reduction of power, check the choke, make sure its off.
Jun 19, 2010 | Generac 5623 GP Series GP6500 8,000 Watt...
I have a Generac 5000 Power Plus 10HP Model 09856-0 Series 401 4891. It works fine but the gas tank petcock leaks. Where can I get a replacement and for reference I'd like to get a parts manual for future...
The original part number your looking for is 78298 (Plastic tank valve). It has been superseded by part number 080270 and it it available here:
http://www.ordertree.com/ARI.aspx?Mfg=36&Model=9856-0%20POWERPLUS,%205,000%20Watt
http://www.ordertree.com/AddtoCart.aspx?&ProductID=78298&ProductQlfr=GEN $5.34
Part Mfg: GENERAC Part Number: GEN 78298 This Part has been superseded arrowdown.gif Part Number: GEN 080270 Price: $5.34
When you do parts searches in the future for your generator use 9856-0 (Powerplus 5000Watt) for the model number.
You can also order the 080270 tank valve here:
http://www.jackssmallengines.com/searchdb2.cfm
If you enter the part number on the search page.
$4.60
Thanks for using FixYa.
Kelly
Jun 10, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
How many watts would you get from a generator rated at 11hp and 5.8 kva. thanks
kva = kilo-volt-amps
watts = volts x amps = va
Therefore, 5.8kva = 5800 watts
Mar 24, 2010 | Honda 3000 Watt Portable Generator
Honda 6370C - Parallel Power Kit For  EU3000i Logo
244 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
