Question about Konica Minolta magicolor 2300DL Laser Printer
I am having "size mismatch" error on Magicolor 2300DL.
  • 214 Answers
SOURCE: My Magicolor 2300dl printer displays
best solution would be:
if you remove the waste box you'll see blue knob and above there is a sensor now take a look at the waste box and find the place what goes between the sensor. you should cut off one side and clean the other sides and then use some invisible tape to fix the hole. and try again.
so anyway the point is this place what goes between the sensor have to be clean. its not good idea to cut or remove the sensor at all because next time the box will be full you don't know that and it will brake your printer.
good luck
Posted on Feb 29, 2008
SOURCE: MagiColor 2300DL Printing Wtih Vista over Wireless Network
I am using Vista 64 and a 2300DL in the same manner as abertola003. I downloaded the Latest driver from Konica Website and everything is working well.
the driver is named Konica-Minolta 2300DL (unidrv)
Posted on Apr 21, 2008
  • 214 Answers
SOURCE: Konica/Minolta majicolor 2300DL printer
pleas check the driver settings, maybe there is a setting fit to paper or something.
Posted on Jul 02, 2008
SOURCE: magicolor 2300DL 17H fatal - labels stuck in printer
This happened to me last week. A label (or part of it) has adhered to the belt inside the printer. It's an easy fix. Turn off printer and open the side door. Remove waste toner bottle. Lift blue handle in direction of arrow to 11 o'clock position to release belt unit. Carefully remove OPC drum by pressing and pulling handle as shown by little graphic (try not to leave this drum in lighted area and don't touch green drum with fingers). Next, remove two chrome thumbscrews (may have to use slotted screwdriver) on either side of belt unit, then pull out belt unit and inspect to find stuck label. You can rotate belt easily. I removed stuck label and then cleaned glue residue with Elmer's Sticky Out ( a citrus product with no solvents) and a soft cloth. Clean thoroughly and replace belt unit, replaced thumbscrews, OPC drum, and finally, the Waste Toner bottle. Close door, turn on printer and test.
Neil
Posted on Oct 09, 2008
SOURCE: Paper Mismatch
I had this problem on the 6300 and was able to fix it by doing the following:
After selecting print, select preferences.
Select the Features tab.
Under Resizing Options, select "Custom" from the drop down menu.
Put in the custom dimensions of the paper on which you are printing.
Save it under a new name (e.g., "Invitation")
When it is time to print,
Select "More" from the drop down tab under Resizing Options.
At the bottom of the list of those options, you will see your custom sized saved.
Select it, and happy printing.
Posted on May 04, 2009
How do I fix size mismatch? No information in maual or on internet. Size in Word paper properties matches size I am using in printer. Size I have always used with no error or problems.
Did you check the printer properties in Control panel, or in Word. check them in windows control panel, select print right click.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 27, 2016 | Konica Minolta magicolor 2300DL Laser...
Our 2300DL is leaving streaks when printing
Out of one or more toners. If you have removed and replaced a cartridge in error the % remaining is reset to 100%. Try to determine which color is missing in your print out (usually black), and then follow menu instructions to replace that cartridge. The ends are color coded so be sure you change the correct one. This will insure the remaining cartridges % remaining is correct.
Jan 13, 2010 | Konica Minolta magicolor 2300DL Laser...
Smeared print on paper
I was getting a similar blur/blob down one side of the paper (with no discernable print anywhere,) but after removing and emptying the toner collection bottle my printing returned to normal. I am still working on the size mismatch issue, which seems to be prevalent in the 2300DL population.
Aug 25, 2009 | Office Equipment & Supplies
I am trying to print a copy and I keep getting message.... Paper mismatch. Try changing the paper type/size or paper in tray. I am using the same 8.5x11 paper I have always used. Reference guide does not...
Check your printer preferences. Check inside the printer if it has some paper jam.
Cancel all your printer jobs, turn off the printer - Turn on the printer and try again
Oct 08, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta QMS magicolor 2300dl
It sits on the left hand side behind the HVPS, if you want the manual, update with your e mail address and i'll forward it (it's 4.17mb)
May 18, 2008 | Konica Minolta magicolor 2300DL Laser...
May 07, 2008 | Konica Minolta magicolor 2300DL Laser...
Apr 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
372 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
