Question about Dell XPS M1530 Laptop
My dell XPSM1530 getting more heated while working what to do
    Sniper:
  • 66 Answers
Check he heat sink fan working properly or not.
this fan start swinging when more heat generates/
also keep your laptop on hard plane surface while working on it.
never place it over bed like surface. if want to place it over bed.. then first of all place a book, then place the laptop over it.
Posted on Sep 28, 2010
Call your hardware vendor for support NMI: Parity Check / Memory Parity Error *** The system has halted
1) ALL power removed, AC adapter (Charger), and Battery
2) Lay a soft cloth down on the table you are working on.
(DO NOT work on a bed, couch, or directly on a carpet floor. HIGH areas of Static electricity)
Lay the Dell Notebook PC upside down on the cloth.(Helps prevent scratching the notebook, and the table)
3) Remove all Ram Memory module/s. ('Stick')
http://support.dell.com/support/edocs/systems/xpsM1530/en/SM/memory.htm#wp1180190
[From,
http://support.dell.com/support/edocs/systems/xpsM1530/en/SM/index.htm ]
Handle the Ram Memory module by the BODY.
The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins on the bottom.
The Body is coated with a see-through protective plastic,
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
Use a pencil eraser to clean the contact pins. ALL pins, BOTH sides.
If you are using a pencil eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band of the pencil, touch the gold plated contact pins.
Rub up, and down on each contact pin. Doesn't take much pressure, nor rubbing to clean them.
In fact when you are done the contact pins may not be bright, and shiny.
It's okay I assure you that you have cleaned them.
(Doesn't take much 'corrosion' to make a bad contact surface)
Use air to remove the eraser dust. If you have a can if compressed air available use it. (Also use on the ram memory slots)
If not air pressure from your mouth will be sufficient.
Reinstall all Ram Memory modules.
Reinstall the Battery, and then plug the AC adapter in. (Then plug the AC adapter into power)
WAIT 1 minute, turn the laptop on.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 18, 2012 | Dell XPS M1530 Laptop
Dell 1600n low heat error
Remove the fuser lamp and put it back in place, it is not heating properly.
Apr 02, 2008 | Dell 1600n All-In-One Laser Printer
Dell xpsm1530 drivers for win xp
Dell XPS M1530 Drivers for Windows XP are available at the following sites
http://www.notebook-driver.com/dell/dell-xps-m1530-laptop-windows-xp-drivers/
http://www.getpcmemory.com/drivers/download-dell-xps-m1530-notebook-windows-xp-drivers/
http://forum.notebookreview.com/dell-xps-studio-xps/254815-xps-m1530-windows-xp-driver-pack-final-udi.html
Hope it helps! Good Luck!
CreativeTECH
Mar 04, 2011 | Computers & Internet
My dell vostro a860 keeps over heating because i dropped and now it over heats because the cores get up to 93 degrees celsius
Due to the shock, your laptop may have broken and have displaced parts and the fan/ heat sink etc might not be working. Over heating can cause further damage. Hence, it is strongly recommended that you immediately seek professional assistance to avoid any permanent damage to the system
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 06, 2010 | Dell Vostro A860 Notebook
How do i remove replace battery in my dell XPS 1530 laptop?
Please refer to the owner's manual for this laptop model at the following link:
http://support.dell.com/support/edocs/systems/xpsM1530/en/OM/PDF/RU335A02MR.pdf
Page 48 of this PDF file explains how to replace the battery.
Nov 23, 2010 | Computers & Internet
Ac/dc power plug replacement for a dell XPS m1530 laptop
It would be stated as DC Power Jack.
For the Dell XPS M1530 it has a circuit board that is removed.
The circuit board also has the I/O USB ports on it.
(Input/Output)
DC Power Jack I/O USB Circuit Board example,
http://www.parts-people.com/index.php?action=item&id=5400
A lot more convenient for replacing the DC Power Jack.
Examples of a Dell XPS M1530 DC Power Jack,
http://www.discountelectronics.com/index.php?l=product_list&c=4527
Round and Octagon.
Dell XPS M1530 Service Manual. (From Dell Support)
1) Remove ALL electrical sources. AC adapter (Charger) and Battery.
2) Use an ESD wrist strap, and connect the alligator clip to a good ground source.
(Cost averages from $3 to $12. I connect to the metal frame of an empty desktop computer case)
3) Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screw/s came out of.
(You can use a clean egg carton in a pinch. Label each each holder)
There may be as many as 60 screws, and 12 different types of screws.
DO NOT mix them up.
4) Make notes and drawings as you disassemble. Use a video cam if available. (Use good lighting)
Nice to have a record to come back to if you are interrupted.
5) I suggest using Solder Wick, (Desoldering Braid), for desoldering.
A lot better IMHO than using a Desoldering Tool.
(Solder S u c k e r tool)
50 Watt of less soldering iron, No.2 chisel tip.
.055 Rosin core solder
Rosin paste flux
Solder Iron stand with a damp sponge, or a damp sponge nearby.
To add;
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Nov 03, 2010 | Computers & Internet
My daughter put two cd in my dell xps m1530.any idea how to get them out
Please try the following:
On your dvd drive there is a very small pinhole. Get a paperclip and try to push it through. This pinhole is used for emergencies where the dvd drive does not eject.
Other thing you can do, is to turn your laptop upside down and remove the dvd rom drive from your laptop. Then unscrew the dvd drive to get the cds out.
Jan 31, 2010 | Dell XPS M1530 Laptop
How do I remove the DVD player from my Dell 1530 XPS laptop ?
download the service manual via this link: http://support.dell.com/support/edocs/systems/xpsM1530/en/SM/HawkeSM0_H.zip unzip it and run the index.html file, this with open a local webpage with various options on it. Select 'Optical drive' this will then give you a step by step guide on how to remove and replace the DVD drive, it even includes good detailed pictures. remember to follow the instructions carefully. Hope this helps.
Nov 25, 2009 | Dell XPS M1530 Laptop
My dell xps m1530 will not and the eject will not function
The M1530 slot drive has no manual eject. If the drive is not ejecting the media, then a service call is required to replace the optical drive. (The old drive has to be removed from the chassis to get the media out of it)
Hopefully, the system is under warranty.
if not, information on removing the optical drive is here:
http://support.dell.com/support/edocs/systems/xpsM1530/en/SM/optical.htm#wp1038494
Mar 30, 2009 | Dell XPS M1530 Laptop
Dell xpsM1530 administrator unlock code
Dear Flaco_2233,
Thanks for the posting in FIXYA.
You need to boot system into safe mode and can access a default admin account.
This link may get useful information regarding this:
http://zedomax.com/blog/2006/12/30/hack-unlock-windows-xp-password-without-any-programs/
Regards
ELLIN
Sep 12, 2008 | Computers & Internet
Dell XPS M1530 Laptop Logo
96 people viewed this question
Alun Cox
