Question about Belkin Surf Share Wireless USB Adapters (F7D2101)
I try connecting to the internet after plugging in my Belkin Surf and Share wireless adapter, and it says it's not connected. I tried installing the Belkin utility, but it wasn't working either (all the buttons in the utility were grayed out :P). Now when I try to connect using the Windows Zero Configuration, it says that it cannot configure the connection. I checked in the Services and the WZC is running. I've tried everything I can think of, I've uninstalled and reinstalled the drivers to the adapter ten times, rebooted dozens of times, and nothing seems to be changing a thing. If anybody can offer some assistance, I would greatly appreciate it, as everywhere else i've gone has told me to enable the WZC, which is simply redundant, seeing as it's already enabled. Thanks.
    Sergeant:
  • 358 Answers
Hi, let me know the operating system of your laptop or desktop that you're using (it's very
important for compatibility) and also the service pack that's running your PC. If you don't
install the adapter properly, the problem will occur repeatedly. Remember, running the
driver without plug in USB.
Posted on Oct 31, 2010
I have a F7D2101 Surf & Share Wireless USB Adapter and I have a wired internet connection. Can i use the surf and share USB adaprtor to share the internet (Creating a hotspot) between my desktop and...
You need wireless router for your usb adapter if you want to share your internet connection. Just an example if you have 2 laptop which dont have wireless adapters then you need 2 usb wireless adapters.
Sep 06, 2011 | Computers & Internet
Installed belkin Surf USB but it is unable to get Ip address from bt hub tried uninstalling and reinstalling no change
there is a button on the bt hub with the wireless sign on it, press it to allow the usb device to connect. You onlt need to to do this once its a security measure to stop anyone logging into your wireless network. Also it will only stay allowable for connections for a short period of time. But as i have said you only need to do it once to allow the new computer to connect.
Please vote if you found this info useful
Mar 15, 2011 | Belkin Surf Share Wireless USB Adapters...
Ok on my brothers comp a dell inspron 531s he has a belkin adapter it was working before and now it is saying the limited to no conectitivy ive tried un installing and re instaling the adapter with same...
You can try an simple step like..deleting the preferred networks(saved networks) and then try re-connecting..That should do the job. Even then if its the same issue.. Change the channel and SSID in the belkin router and power cycle the router(turn off the power of the router for 10 sec) and power it back on.. and reconnect all your computers and everything will work properly.
Hope this helps. For further information please do feel free to contact us.
Jan 04, 2011 | Belkin (F5D7050) 802.11a/g/b Wireless...
How do i search fro wi-fi on it
You will have to go to belkins website and download the drivers and installation files for it. Then it should install a software that allows you to search for an internet connection :) hope this helps :)
Dec 27, 2010 | Belkin Surf Share Wireless USB Adapters...
I have a belkin surf/share usb adapter f7d2102 got a good signal i hit connect windows searches it cannot connect i have tryed for a d------ nweek it has to be in the configured something need unchecked...
Hi i got your issue .....
Try with the following steps ....
I hope that when you scan and connect for the network ..you will get the message as "windows cannot configure any wireless networks"
This means that there is a conflict between xp utility and belkin utility but this can be resolved by the following steps
Step 1: Click on the "start " and then go to "run"
Step 2: On "run" type - "services.msc" and then hit "ok"
Step 3: Now a new window pops up ....there u please search for "wireless zero configuration " and double click on it
Step 4: You will get a " wireless zero configuration -properties window"
Step 5: IN that window check that the start type should be "automatic" and the service status should be "started "
Step 6: Then click ok and close the screen
Step 7: Then click on start -control panel-network connections- wireless network connections (make a right click) and
you will find properties and at the top you will have the option"wireless"
Step 8: On that screen you will have the check box as "use windows to configure to my wireless networks "
Step 9: That check box has to be checked then click "ok"
Step 10: Try scan and connect -you will have the network -you can connect to it
Hopefully this will work ....
If problem still presists please contact 24/7 belkin technical support 1800-2235546
Thanks.....
With regards ......
Priya ,,,,,
Oct 03, 2010 | Belkin Surf Share Wireless USB Adapters...
I have a embarq 660 series router and using a compaq presario computer. I have already installed the belkin surf/share wireless USB adapter to this laptop. When I go to Internet explorer it says offline.
your problem is a IP address conflict
Embarq and Belkin have the same IP address 192.168.2.1
change the IP address in to your Router.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Now go to lan settings and change the IP address 192.168.2.1 in to 192.168.1.2
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
=================== WIRELESS SETTING UP A WIRELESS CONNECTION ====================
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 06, 2010 | Belkin Surf Share Wireless USB Adapters...
Belkin Surf  Share Wireless USB Adapters (F7D2101) Logo
346 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
