Question about JVC HD-61Z575 61" Rear Projection HDTV-Ready Television
Color is off blues have become green checked the color temp and cords but still very week color also replaced lamp it has slowly gotten worse started out as a gray shadow in the center of the screen.
  • JVC Master
  • 5,138 Answers
Light Engine/optical unit block.
Encompass Parts Distribution 1-800-638-3328
UED 1-800-648-6657
Posted on Sep 28, 2010
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Color changing
youve most likely got an issue with the CRTs one most likely which cuts out and back in randomly. Try removing the rear cover and look in at the three crts while its doing that and see if you can see one or more keep turning off and on.
Jan 01, 2013 | JVC AV-56P575 56" Rear Projection...
Samsung DLP 72" HL72A650C1F keeps turning off amd on
Did you buy the original lamp?
If the problem is related to the lamp door switch, you will get a different error instead of lamp LED.
Do you hear the color wheel spinning?
Again, if it's a color wheel problem the error will be different!
My good guess is the lamp but, it could be the ballast or both.
Best of luck
www.aaatvservice.com
May 08, 2012 | Samsung SELECT HL72A650C1F Rear Projection...
The color on my tv is turning green. It's not totally green but it's becoming green. No matter how I adjust the colors it remains the same with too much green. You can't see the true colors...
It is very common for the color of the lamp to change as it nears the end of it's life. Depending on the bulb itself you may see yellow, green, or blue shifts (I have even seen red/orange). This is due to the diminishing output of the bulb and while you can make some adjustment you will eventually hit the point of failure. The bulb could in fact last several more weeks or even months depending on your use and environment. It is probably a good time to start searching for a replacement now so you can replace it as soon as it dies or just replace it now if the color is too bad to be worthwhile.
May 23, 2011 | Philips Magnavox 9P6034C 60" Rear...
My LCD projection tv(KF-50E200A) displays projection lamp week when switched ON and out of red color display on the screen. Is this will happen if the projection lamp is week?
no and yes
the lamp warning is to alert you that a timer has expired that clocks the approximated life of the lamp in "hours of use".
it is never accurate and is dependent on whether or not it was reset the last time a lamp was replaced.
reset the lamp timer in the users "setup" menu.
the lamp has NOTHING to do with color, it only provides light.
check the connections between the TV and cable/satelite box...the red.green.blue component connector...the red one is likely loose.
if this does not correct you color problem, your optical engine has failed.
very expensive repair, not for the DIY type guy.
Apr 17, 2011 | Sony KF42E200 TV
I changed the bulbs in my two projectors awhile back and a month or so later they both started getting a blue dot/haze that has progressively gotten worse...any ideas?
service is very important be four replacement of lamp if you have a Multi color background in your image then your projector just need service of LCDs and inner parts of projector.
Jan 18, 2011 | Panasonic PT-LB20U Multimedia Projector
I have my settings on sports for a high contrast and nice bright sharp color and in the last 2 weeks the color has gotten darker. Like the contrast is slowly starting to fade away. On blu ray movies the...
you have to check preset picture mode if still not good then reset setting in setup mode.after that your picture become good. if problem still then there is problem with LCD panel.
Oct 16, 2010 | Insignia 42" LCD Flat-Panel HDTV
I have the same problem with my SONY KF-60WE610
Fan that cools lamp could be Bad,or Lamp could be Failing itself.
Sep 19, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
You are missing either red drive signal to CRT or you have a cold / fractured solder joint on the television. Also with the set unplugged check with a non metalic object like a ruler or a wooden spoon and start tapping around in the front or back of set and see what happens. See if you can narrow which area of the set has a problem... Good luck future technician.. Happy holidays.. Jay
Dec 08, 2008 | Hitachi 43FWX20B 43" Rear Projection...
JVC HD-61Z575 61" Rear Projection HDTV-Ready Television Logo
163 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
