Question about Samsung SGH-A877 Impression Cell Phone
I did the reset on the phone but when i put my sim it does not give me any signal
    Sergeant:
  • 193 Answers
You can search the network manually.Then select your network provider .Put your sim in any other phone and confirm sim is working or not.
Posted on Sep 28, 2010
Blackberry signal
walaikum assalam. Your phone may have a network problem. To chekc do as follows :
1) carry out a hard reset. Remove the battery while the phone is ON. remove and re-insert the sim card. put on battery and switch phone on.
2)if that doesnt work, insert sim card into another phone to check if u get signal. if you get signal on the other phone, the problem lies with ur blackberry handset.
3) if there is no signal on any phone, contact ur network operator.
Jun 03, 2013 | Cell Phones
No signal is coming
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Oct 25, 2012 | Computers & Internet
I have android I5801, from yesterday the sim which i used in android phne shows no signal,shows not registered on network, but it is usable in other phones, if i use any other sim in android phone it...
The above said problems usually occur when the SIM is getting blocked but you said it's working on other phones.Most probably you will have put some SIM security codes on your phone and thus it blocks signals from that operator.If you are not remembering the security details,please try a master reset on your phone.Things will be all right then.
May 29, 2011 | Google Android
When i put sim fail and always say no sim mode and same sim when i put it in other phone work also i put another sim in my phone worked the problem that samsung not play this sim the name of this sim card...
u will need to reset the phone firmware. i will give u a code. Make sure U remove ur memory card and put in a sim u dnt use often,ok. At main screen, dial: *2767*3855#
Mike
Apr 20, 2011 | Samsung Jet S8000 Cell Phone
I forgot my nokia3110c mobile password
Hi, Please note that the default securitycode for all Nokia handsets is 12345.In the event the security code is changedand you are unable to recall it, then the phone needs to be reset.You maykindly note that the security code can be reset at any Nokia Care Center. Kindly be aware that therewill be a service provision fee associated with this service, as it is anon-warranty procedure. You maykindly note, once the phone has been reset, all data in the mobile will belost. I recommend you take along theproof of purchase/receipt while visiting the Nokia Care. Hope this solves your problem. Thanks for using FixYa.
Mar 02, 2011 | Nokia 3110 Cellular Phone
Hi. i need a no. to restart my phone ( gt-e1080t samsung) because there is no signal.. or any solution..
Hello there,
Try putting in another sim card to isolate the problem whether its a phone or network problem. If putting in another sim still gives you a no signal, it might help if you restore the phone to its original settings. Just dial *2767*3855# and the phone will restart itself.
Tell me how this goes. Thank you for using FixYa.
Jan 24, 2011 | Samsung E1080 Black OPTUS Cell Phone
MY samsung jet (no network
try to do these steps:
1. switch off your phone, remove battery, sim and memory card.
2. reinsert your battery and switch on your phone.
3. on your keypad menu type this code to make a hard reset. *2767*3855#
4. after hard reset, reinsert your sim, battery and memory card and check.
you may also want to try these.
1. remove your sim and have it check with other phone if it's receiving a signal.
2. insert another sim to your phone and check if it will receive a signal .
3. check your phone profile settings, press menu, select settings, select phone profile, select normal mode and check if it will give you a signal.
if you found out that your sim has defect, you may buy new sim and replace it, but if your phone has the problem after all of the above steps, go to your nearest samsung service center and have it check. if it's still under warranty, you may want to consider returning it your phone dealer, where you bought it, and have it replace with new one.
good luck and take care...
Jan 11, 2010 | Samsung Jet S8000 Cell Phone
I have full signal strength, but NO NETWORK!!
I've resolved numerous problems with phone that has a signal but cannot make calls.
What I did is to I reset the phone, but it'll completely delete all files in the phone memory.
If you want to reset the phone, perform this steps:
Turn ON the phone without a sim card then tap on the dial pad.
press *2767*3855#
phone will then reboot & put the sim card back in..
Try to make a call..
Hope that'll help you..
Happy Holidays.
**Please rate my post**
Dec 17, 2009 | T-Mobile Samsung T429 Pay-As-You-Go Cell...
Sim lock
you need to put back the original sim card in the phone and do a master reset.....in the phone settings.....
menu/settings/intial setup/master reset - 000000 security default code
Jan 06, 2008 | Nokia 1600 Cellular Phone
Samsung SGH-A877 Impression Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
