Question about Frigidaire GLEQ2152ES Electric Dryer
My dryer dont star no power at all - Frigidaire GLEQ2152ES Electric Dryer
    Problem Solver:
  • 4 Answers
PLUG A LAMP INTO A PLUG MAKE SURE YOU HAVE POWER,THEN TRY DRYER SWITCH STILL NO POWER TAKE DRYER SWITCH APART AND BYPASS BY CONNECTING TWO WIRES. STILL NO POWER BYPASS DOOR SWITCH. STILL NO POWER CHECK TIMER THEN START CAPICITAR ON MOTOR, IF MOTOR IS HUMMING REPLACE IT. GOOD LUCK
Posted on Sep 28, 2010
    Problem Solver:
  • 6 Answers
If your dryer is 220V , do Not stick a lamp into the socket to check for power. You should use a volt meter to check for power. If you don't have one and you don't have a friend that has one, please use caution and call for help. 1st step is to verify you have power though.
Posted on Mar 03, 2011
Where is the reset button and how do I get to it
On some appliances the reset is to cut off your breaker an then turn it back on. Loss of power will reset unit. Repairman told me to try it before he came out. It worked.
Mar 29, 2014 | Haier Dryers
Tumbler won star
What is the complete model number of your unit?
Dec 03, 2012 | Maytag MDE2400A Electric Dryer
(2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Just hook up drier had to change power cord getting 240 to the drier light is on but drier do not star up.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 26, 2011 | Kenmore Dryers
I push to star dryers but dont work also the light dont work
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Jan 13, 2011 | Kenmore Dryers
I have a GE gas dryer model DBXR463GD1WW, the problem is that it star the flame but dont heat enough for dry the cloth I change the sensor in the flame but it still have the same problem
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 03, 2010 | GE DBXR463GB Gas Dryer
Want star up
3 things to check if it will not start the thermal fuse on the back of unit could be broken "if it gets to hot inside the dryer it will break this thermal fuse from the venting being clogged" or the door switch is broken or the push to start switch is broke
Apr 09, 2010 | Kenmore 73952 Gas Dryer
CHanging Belt Maytag DE410 Dryer Q#2: Opening Top
Pop the top ... usually held down with spring clips
Be careful of the finish ...
Let me know what happens ...
Post a comment here for additional information/instruction
thanks for your interst in FixYa.com
Dec 11, 2009 | Computers & Internet
THE UNIT WONT COME ON AI ALL, BUT ON THE THERMOSTAT THERES A BLINKING STAR. WHAT DOES THAT MEAN?
the blinking star means the t-stat is on delay, you can try to cut the power to the t-stat or remove the batteries for about 2min to reset the t-stat connect your power or put your batteries back on t-stat and see if works dont forget the delay on the t-stat make the star to blink
Sep 23, 2009 | Carrier Heating & Cooling
Frigidaire GLEQ2152ES Electric Dryer Logo
430 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
