Question about Daewoo Refrigerators
Compressor of my ref is not working & is out of gaurentee period
    Problem Solver:
  • 4 Answers
CHANGE YOUR RELAY SWITCH THATS CONNECTED TO YOUR COMPRESSOR. FIND PART ON APPLIANCE PROS.COM
Posted on Sep 28, 2010
My kenmore side by side mod.# 5965519400 is not getting cold or freezing in the bottom freezer...
Was this ref laid on its side for a period of time? You always have to allow the ref to sit upright for a period of time before you try to run it. You may need to call a tech to see if the compressor lacked oil when you turned in on... it may have burned up.
Oct 05, 2011 | Refrigerators
I bought my refrigerator just last December 2009 bu I've lost my receipt. The prob occurred yesterday when the engine has a very noisy sound. we turned off the ref but after getting started again,the...
You have the fridge in warranty period and so must be consulted. It is possible that the compressor motor/compressor has failed.hence the noise was heard prior to this failure.Advise you to contact Whirlpool for free replacement.
Sep 29, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
A/c compressor does not engage. with gauge the low pressure checks ok. was working two days ago. checked 1 - 10 and 1 - 15 amp fuses, okay.
Take this to an A/C shop, low ref. level can cause this issue and the thermal limiter costs TONS less than compressor failure.
You need a qualified diagnosis. If low ref, then exposure to low oil level. All of the fixes require special tools and training to correctly fix.
Jun 12, 2010 | 1998 Oldsmobile Intrigue
The ice is melting and the food in the frezer is
TRACK DOWN THE BUZZING. IT MAY BE THE COMPRESSOR TRYING TO START, MAKE SURE THE CONDENSOR UNDER THE REF. IS CLEAN AND THE FAN IS RUNNING
Jan 13, 2010 | Electrolux Refrigerators
Just purchased, plugged in....set temp....not cooling.
Is compressor running? If so, call tech. out as its under gaurentee. Just a thought, when you selected the temp did you press accept. Possibly comp. wont activate untill correct setting is done.
Sep 21, 2009 | Danby DWC1534BLS Stainless Steel Wine...
Fridge/freezer warm, water puddling underneath
Hi, clicking sound from compressor, means compressor not running (working) compressor overlay relay is what making that clicking sound, possible your compressor have a hard start, you can purchase compressor ( hard start kit ) from appliance store, your fans could be working, but compressor short cycling, you said fan not working? which one inside of ref, or one near to compressor, check fan, remove 2 wires from fan terminal, use ohm tester, place tester lead one on each fan terminal, if you get a beep sound (continuity) fan is o/k, if not, fan burnt out, replace fan, now if compressor is good, fans are good, then check or replace, defrost timer, but before doing any repairs, unplug ref, excessive water is because ref defrosting, because there's no refrigeration, remove your produce, leave ref. off for about an hour, then replug it, let it work for about another hour, then check to see if temp. dropping (colder) maybe you experiencing, low voltage, let me know what happened, then i can tell you exactly, what's the problem. good luck.
Aug 11, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
My fridge works when powerd but does not cools
"my fridge works when powerd"
I am guessing that when you turn it on the light is on and the fan is running inside the freezer which sounds like it is working but, the compressor must not be running because it will not cool.
You may have to get behind the ref to listen for the compressor running. With the ref off, take off the back panel so you can see the compressor, turn it back on and listen for the compressor to start running. If you hear a clicking noise and the compressor does not start then it could just need a relay.
Dec 12, 2008 | Refrigerators
Side by side not working
Make sure the compressor is running and not just a fan motor.
Unplug the ref for 30 min or so and while you are behind the ref plug it back in, listen for the compressor to start. If you hear a clicking noise and the compressor never starts then replace the relay on the compressor. If the compressor runs and still does not cool then you may have a coolant problem.
Dec 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Dvd player
my dvd player cannot acess to dvd"s but it is acessing to vcd"s this problem was occured three months ago at that time company mechanic handle it.now my gaurentee period was over,so please give me a solution
my dvd beloging to sansui.
Nov 29, 2007 | Sansui VRDVD4005 DVD Player/VCR
Refrigerators Logo
66 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
