Gratis driver Multi Remote Control Application RC102 - RC107 for 32 bits pc
Need a remote for it
June, Google search your make and model# replacement remote.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 30, 2016 | Televison & Video
Tip
HOW TO RUN TRIAL VERSION SOFTWARE ON PC FOREVER
Mere adjustment of PC's date and time at the control panel<br />does not do the magic as most sites would tell you.......<br /><br /><br />RunAsDate is a small utility that allows you to run a program in the date and time that you specify. This utility doesn't change the current system date and time of your computer, but it only injects the date/time that you specify into the desired application.<br /><br />You can run multiple applications simultaneously, each application works with different date and time, while the real date/time of your system continues to run normally.<br /><br />Using RunAsDate<br /><br />RunAsDate doesn't require any installation process or additional DLL files. In order to start using it, simply copy the executable file (RunAsDate.exe) to any folder you like, and run it.<br /><br />In the main window of RunAsDate, select the desired date and time and the application that you want to run. Optionally, you can also specify the command-line parameters to run the program. Press the "Run" button to start the application with the specified date/time<br /><br />RunAsDate Limitations<br /><br /> RunAsDate only works on 32-bit Windows applications. You cannot use it for old DOS 16-bit programs or for 64-bit Windows applications.<br /> RunAsDate will not affect applications that take the current date/time from another source. For example: application that loads the current date from remote serve<br /><br />TO DOWNLOAD<br /><br />visit <a href="http://www.nirsoft.net/utils/run_as_date.html">http://www.nirsoft.net/utils/run_as_date.html</a>
on Dec 22, 2010 | Computers & Internet
Tip
How to enable 2 Finger Scrolling, like MAC ie, multi touch in Windows
Multi-touch or multitouch functionality has been attracting consumer attraction, thanks to iPhone and iPod Touch, two-finger-scroll in Apple MacBook with TrackPad, and Windows 7, which has built-in multi-touch mapping application, photo viewing program, and gesture support in Internet Explorer 8. Multi-touch is essentially a set of interaction techniques which allow computerusers to interact and control graphical applications with fingers.
However, for marketing reason, Synaptics official standard drivers for most Synaptics TouchPads does not support multi-touch Synaptics Gestures. Synaptics' drivers lock gesture features on all non-supported OEM notebooks and laptop PCs, except for certain gadgets such as ASUS EEE PC. So multi-touch is disabled even though touchpad hardware does support them.
But now if you want to experiance this awesome multi touch features, well there is good news. One guy has developed a modded driver for synaptic which will enable the multi touch functionality in a normal PC with windows.
The Synaptics TouchPad driver should support all Windows operating system such as Windows XP, Windows Vista and Windows 7. However, do note that the digital signatures of the modded drivers have been broken, and the drivers are no longer signed. Thus, there may be issue when use in 64bit operating system which enforces strict driver signing requirements.
Installation:
  1. Uninstall all current Synaptics drivers from Control Panel's Add and Remove Programs or Programs and Features.
  2. Restart the computer.
  3. Install the modded driver by running the setup.exe inside the ZIP archive.
  4. Windows should prompt a warning about unsigned driver. Continue to install the driver anyway.
  5. Restart the computer after installation is completed and Synaptics TouchPad driver is updated.
  6. In Device Manager's Mouse and Other Pointing Devices" section, Synaptics PS/2 Port Touchpad should have driver version of 10.2.4.
Now just play around a little bit and you will know how awesome this features are. icon_smile.gif
Also there is a two finger scrolling application which is a project hosted in google code. So this application is all you need if you just need the 2 finger scrolling functionality in windows.
This application can be found here:
Download: http://code.google.com/p/two-finger-scroll/downloads/list
The moded drivers from synaptic can be found here:
Download synaptics_v10.2.4.0_allOS_modded_b2.zip or touchpad_synaptics_v10.2.4_vistax32x64_xpx32x64_modded_build2.zip
Or you can just download all the required files from here:
Mirrors:
  1. Synaptics Multi touch mode (all) - Selfhosted
  2. Synaptics Multi touch mode (all) - Rapidshare - Recommended
IMPORTANT: Do not upgrade the Synaptics TouchPad driver if you love these touch features, as Sypnatics locks and disable the advanced touch features from driver v11.0.0.0 onwards.
on Oct 06, 2010 | Microsoft Windows Vista Ultimate Edition
Dv4 1125nr remote control driver
I think the remote control is part of HP's Quick Launch product and the driver can be found under Mouse/Touchpad and Input Devices. Look for the Quick Launch or Quick Play which controls the Media devices such as the DvD/CD, etc.
In the excerpt below they reference the remote as the external easy access keyboard (I think). I got this off my daughter's HP which has a remote.
This package contains software that enables customers to program the Quick Launch Buttons on the keyboard and the external Easy Access Buttons Keyboard for the supported notebook models and operating systems. This application enables menu control of various buttons such as volume, internal/external display, and mute on/off.
May 21, 2012 | HP Computers & Internet
No puedo usar my camara gratis
Ve al panel de control y vea si su camara esta en la carpeta.De no ser asi vaya a :
1-MyComputer
2-right click
3-Manage
4-Device amnager
y corrobore que el driver de la comara este al dia.
Apr 18, 2012 | HP Pavilion dv9205us Notebook
I installed windows 7 and some drivers are not compatable
Did you install 64 bit windows? Something's are just plain incompatible with 64 bit. Your best bet is to try to find 64 bit drivers for whatever doesn't work
Dec 20, 2011 | HP Pavilion dv2610us Notebook
Podria saber cual es codigo para programar la television LG
menciona por favor la marca de tu remoto universal, o intenta obtener el manual gratis de tu remoto tecleando en Google: www.retrevo.com , no olvides darme puntos.
Apr 17, 2010 | DISH Network IR Remote Control
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
