Rank: Apprentice
Rating: 81%, 4 votes
you can use the following way,if u still can't login ,u can e-mail me:
alinaisalina45@hotmail.com.
Step 1. Connect your computer's network port to one of your router's LAN ports (Ethernet ports) using a network cable. WAN port of the router should be connected to your modem.
Verify physical connectivity by checking for solid link lights on the Ethernet ports of the device. If you do not get a solid link light, try using a different cable or connect to a different port on the device if possible. If the computer is turned off, the link light may not be on.
Step 2. Check your IP address. Your computer must have an IP address in the same range of the device you are attempting to configure. Most DI-series devices use the 192.168.0.x range. If you are attempting to configure a D-Link router, then make sure you take note of your computer's Default Gateway IP address. The Default Gateway should be the IP address of the D-Link router. By default, it should be 192.168.0.1.
- Set your computer with static IP address: Go to Control Panel > Network Connections > Local Area Connection > Properties. Select Internet protocol TCP/IP and click on Properties.
Select the 'Use the following IP address' and 'Use the following DNS' options. Specify the TCP/IP settings you want to use:
IP address: 192.168.0.5
Subnet mask: 255.255.255.0
Default Gateway: 192.168.0.1
Preferred/Alternate DNS: 202.129.64.198 / 4.2.2.3 (or whichever your provider is using).
Click on OK and then OK again.
Try to access the router. Open Internet Explorer and type 192.168.0.1.
Step 3. If unsuccessful in accessing the router's configuration pages, please reset the router. Here is how to reset it: while the router is powered on, press and hold the Reset button for 10 sec. Release the button and wait until the router boots up (1 min). Try to log into it again.
Step 4. Check your Internet settings. Go to Control Panel > Internet Options.
- From the Security tab, click the button to restore the settings to their defaults.
- Go to the Advanced tab and click the button to restore these settings to their defaults.
- Click to the Connections tab and set the dial-up option to 'Never dial a connection'.
- Click the LAN Settings button. None of the options should be selected. Click OK. Click OK out to the desktop and close any open windows.
Restart Internet Explorer and try to access the router.
Step 5. Disable any Internet security software running on the computer. Software firewalls like Zone Alarm, Black Ice, Sygate, Norton Personal Firewall, etc. might block access to the router's configuration pages. Check the help files included with your firewall software for more information on disabling or configuring it.
