Question about Philips 43PP9202 43" Rear Projection Television
The TV screen is blurry/fuzzy - Philips 43PP9202 43" Rear Projection Television
  • Philips Master
  • 5,138 Answers
You have Bad Coolant fuild in Tubes need to do a fluid change
Mats Electronics has Coolant Fuild 1-800-628-1118
Posted on Sep 28, 2010
Testimonial: "Thanks"
3 Suggested Answers
Cybertech
  • 149 Answers
SOURCE: Blurry screen
coolant fluid on picture tube may be contaminated replace it an setbe ok (this is a technician job)
Posted on Mar 29, 2008
Shuttle83
  • 1139 Answers
SOURCE: Blurry/Fuzzy Picture/Double Vision after power outage
Hello stevenkgray and ADIMEN,
I think what has happened is the your TVs are out of focus which could be due to a voltage problem. First I would warn you that this is a problem in the High voltage section of your TV and caution should be taken, in fact I would suggest that if you do not have a background in electronics that you get the TV checked and fix by a qualified TV repair technician. However if you do have a background the next few lines will make sense and you might be able to effect these repairs yourself.
Items needed for troubleshooting:
Schematic Diagram
Multimeter
High Voltage probe (40Kv)
Universal Video Analyzer (UVA)
1) Unplug the TV and take the back off of it
2) connect the UVA to the tuner F connector and setup the UVA to send a test pattern into the TV
3) Power the TV back up and turn to the channel set on the UVA
4) check the anode voltage on the CRT with the HV probe (connected to the Multimeter set to volts and grounded) and compare it to the voltage on the schematic.
5) If the voltage is not right adjust the focus and screen controls on the Integrated High Voltage Transformer (IHVT) to obtain the proper voltage.
6) Check the pattern to see if it is still fuzzy.
If the pattern is still fuzzy you may have to inspect/replace the IHVT and or its associative circuitry.
If you suspect that the IHVT is bad you can perform a ring test on the transformer using the UVA. (The instructions on how to do this are on the UVA quick steps pull out. or the instructions can be looked up on the web.
I hope this helps
Thank you,
Shuttle83
Posted on Jul 04, 2008
Iphone 4 screen has gone fuzzy and blurry
time to replace you digitizer and screen. We do it for 99.95 with return shipping.
Feb 18, 2014 | Apple iPhone Smartphone
My iphone screen is fuzzy and blurry
Your screen is demaget, change with new
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
Philips blurry 34pw8502/37 Blurry Screen
a part called picture tube base which connects picture tube to circuit board got some trouble,,, u can replace it with the help of a service pro..
Mar 23, 2010 | Philips 34PW8502 34" TV
Blurry picture
If you know where the fly back is, ok open the casing and see at the back of the fly back, there are two knobs, one for the focus and the other is for the brightness. Try twist both and see which one is for the focus. Ok, from the focus knob try adjusting until the fuzzy sight disappears. Try this, I usually do it to screens with blurry appearances.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Schematic Diagram
Multimeter
I hope this helps
Thank you,
Shuttle83
Jun 24, 2008 | Philips 60P8341 60" Rear Projection...
Re: CTX monitor getting blurry
Hi Beth,
Your focus screen network turn faulty. It can be solved by by passing the original focus screen network to a new assembled focus screen network.
Apr 08, 2008 | CTX PL 9 19" CRT Monitor
Blurry screen
Mar 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 43PP9202 43" Rear Projection Television Logo
148 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
