My Canon MF4010 printer shows "paper jam" even i have already removed paper
  • 17,130 Answers
The paper jam could have caused errors so remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Posted on Sep 28, 2010
  • ericvers Oct 01, 2010
    The problem is not in the PC, The light on the printer blinks red, the paper jam has been removed.
    But it still gives error. Some sensor that has been moved by removing the jammed paper from the printer?
  • Donald DCruz
    Donald DCruz Oct 01, 2010
    There is a indetect opto sensor which could have been moved or dirt accumulted within. You can access this in the input roller,try cleaning orr if there is any wire detached.
In canon mf4010 paper jam
Posted on Mar 15, 2011
How do I fix a canon mp190 series with a papper jam, I have removed all the paper?
Restart your printer.if then even your canon printer is showing paper jam.
  1. Open the paper output cover. ...
  2. Make sure that the jammed paper is not under the FINE cartridge holder. ...
  3. Hold the jammed paper with your hands.
  4. Pull the paper slowly not to tear it, then pull the paper out.
Get any kind of canon printer troubleshooting call us :+1-866-641-8283
CANON PRINTER TROUBLESHOOTING
Apr 19, 2018 | Canon Office Equipment & Supplies
My canon IP 1880 problem paper jam but no paper ... pls help me ..
If a paper jammed inside the printer before experienced this error there might still be a small piece of paper that remains inside the printer, turn the printer off, open the Front Cover, and remove it. Be careful not to touch the components inside the printer. After removing all paper, close the Front Cover and turn it back on. If you're sure that there is not even a smallest paper in the machine and you're getting this error, this might just be a glitch that can be fixed by a power reset. While the printer is ON unplug the power cable from either the back of the printer or the power outlet, leave it 20 to 30 seconds then plug it back. If the message still shows then that might already be a hardware issue. You can contact a Canon representative for additional troubleshooting. Technical support reps have special codes to reset their products to factory default should there be "glitch" issues like this. Once all the troubleshooting steps have been exhausted, that's when we can conclude it is a hardware issue that needs repair.
Apr 01, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Always paper jam on lcd display, even though that the jammed paper was already removed.
If the jammed paper is removed and still show paper jam it means tiny piece of paper is left over in the printer you can use a low pressure vaccum or blower to remove the paper piece before using the blower remove the toner and remove the power plug and the usb connector after cleaning conect the power then the usb then power up printer then in computer click the printer icon in the task bar and remove all the contents then click start settings printer and make your printer default printer right click the default printer and click properties in printer properties click print a test page
Apr 01, 2011 | Canon i-SENSYS MF4120 All-In-One Laser...
Canon mf4010 paper jam error and red light does not seem to want to go away even though the paper jam has been cleared.
Check that the paper feed sensors are all loose and not tight. It may be that the feed senor arm leading to the fuser has been displaced.
Jul 02, 2010 | Canon Office Equipment & Supplies
Illusionary Paper Jam;-(
yes first u open all cover of your printer carefully.than u clean all sensor of printer,,if there r dust in sensor than its give error msg,
Apr 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam showing when no paper in the printer
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 06, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
1,298 people viewed this question
k24674
jasbo
jasbo
