Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Freezer not cold enough - Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
    Problem Solver:
  • 4 Answers
TRY PUTTING A DOLLAR BILL BETWEEN DOOR SEAL,IF ABLE TO PULL OUT YOU HAVE A BAD SEAL,TRY TOP,SIDE,BOTTOM,IF SEAL IS OK TRY CLEANING CONDENSOR WITH BROOM OR VACUMN HEAT ATTRACTS LINT,DUST WHICH RESTRICTS PROPER AIRFLOW.GOOD LUCK
Posted on Sep 28, 2010
Model LFC25776SB/00 one side of freezer not cold enough
There should be a fan inside circulating the air...
Jun 13, 2016 | Freezers
Freezer is not cold enough, even though the control panel says that the temperature is where it should be.
pull the panels inside and check the fan usually in a fridge freezer the fan cacks out or is full of ice clean it out and clean the overflow tube if fridge is cold enough then it is the freezer fan
Jun 07, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Freezer not get cold enough
Thermostat needs to be set
Jun 22, 2014 | AEG Freezers
I have a Kenmore Elite 51374. The refrigerator is not getting cold enough but freezer is too cold. Technician said that it was an electrical problem to call a electrician that I needed a new outlet. I...
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
Aug 02, 2017 | Kenmore 23.3 cu. ft. Side-by-Side...
Freezer & fridge not cold enough
Please check the Thermostat switch settings. Try to put it to max cool and then see the results. If it still does not cool the you have to check the refrigent. It is lee and leaking somewhere. Get a technician and get it charged up.
May 18, 2011 | Freezers
What cause the freezer to not get cold enough?
Make sure condenser is clean with proper air flow around freezer.
May 07, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
FREEZER NOT COLD ENOUGH
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 17, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
My freezer wont stop running
either the cold control thermostat is defective or the rtc overload contactor has welded itself together and cant open and close the power contacts to the unit,un plug the cold control and see if the unit stops then
Feb 27, 2010 | Nor-Lake Freezers
the dryer is already sock ,, you need to change it and refill the gas
Jan 24, 2010 | Freezers
Freezer is not cold enough.
Turning it to the right will make it colder. It will only regulate the temp. by few degrees, so if your thinking there will be a big change there won't be.
Jul 31, 2009 | Viking Freezers
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
