WE ARE CURRENTLY IN NORTHERN TERRITORY VERY HOT AND HUMID. RUNNING AC THRU THE NIGHT IT STOPS BLOWING COLD AIR AND FAN SEEMS TO BE NOISY. HAS IT ICED UP DUE TO THE HUMIDITY. UNIT BEING RUN THRU THE DAY NO PROBLEMS
    Habit-Forming:
  • 156 Answers
If your coil is freezing at night, it sounds like your getting cold enough at night to have your saturation temperature drop below the design of what the AC is able to do. If it runs all day without an issue and freezes up at night, you need to add what is called an outdoor fan cycling switch. This will turn the condenser fan off when the saturation temperature drops so it will not freeze your coil at night. You need to have an HVAC technician install this. It is not a DIY projuect since it has adjustments that need to be right. Plus, it it's a heat pump, it needs to drop the switch off in the winter.
Posted on Sep 28, 2010
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
Why does my heat blow warm air then it turns cold
its VERY likely that your heater core is getting stopped up.
The heater in your car works by circulating hot water from the engine into a copper or aluminum pipe coiled up in the dashboard. The heater/airconditioner's fan blows across it and the hot air comes out of the vents. This is why the heater doesn't work right away when you first start the car. It usually won't work until the hot/cold needle in the gauges is starting to rise up.
If your mechanic recently replaced the thermostat, its possible that there is air in the system which will result in less antifreeze in the car than it should be. If this is not the case, the heater core is probably stopping up and will require expensive replacement if it cannot be flushed clean.
Check to make sure the car is full of antifreeze IN THE RADIATOR, AND THE OVERFLOW JUG. Please be very sure there is NO AIR in the cooling system as well.
Scott
Jan 22, 2013 | 1998 Ford Expedition
2003 Lincoln LS hot air while stopped cold while driving
Hello
Based on what you have said and my 30 years a Ford dealer tech I believe you have a slightly low AC system refrigerant charge due to a small leak at the AC compressor or the AC line connections. I would have a shop hook up a set of gauges to monitor the pressures at idle and see just how low it is. DO NOT ADD UNTIL YOU KNOW HOW MUCH IS NEEDED, YOU CAN LOCK UP THE COMPRESSOR.
Jul 09, 2012 | 2003 Lincoln LS
Why is air conditioner freezing up
Hi Krystal. Not sure how old your AC is. But mine is 1988 Class C. My roof mount started today freezing up After being on only 1/2 hour or less.I took the cover off AC on roof and seen the cooling coil half full of ice building up. When It get fully packed with ice the inside air cannot pass thru coil to fan to recycle the cooled air back down inside RV.. I checked out this site.Fixya.It seems my AC may be blocked with dust in the cooling coil. So I cleaned it out with compressed air. You can buy a can of it in spray form at Wal-Mart.$5..Also FixYa suggested to change the air filters after you clean the coils. Take off cover in inside on ceiling and put new filters. Peferable ones that are able to breathe thru easly. Mine was pluged with dog dander and a bit of dog hair.. I may have to put my dog..in a bag...No I can't do that... But today and yesteday it was very hot and ******* the AC.. But I did attach a small fan under my AC to push more hot up into coils.. It did make a diference The coils started to thaw and drip water on roof.. But I still have to check freon pressure...I'm attaching a photo of my small fan It is only 5"across...Hoped that helped a little.......John, Cornwall, Ontario
Jul 03, 2012 | Coleman Mach 15 Air Conditioner
There is moisture coming out of the AC vents on my daughters 2006 s40, usually during very hot weather and not until the car has been driven for several miles
The drain on the evaporator is stopped up,look for it directly bellow the ac lines ,where they go into the car,under the hood,it will be on the bottom of the blower box,use air pressure to blow into the drain to clear it out.
Aug 24, 2010 | 2006 Volvo S40
AC Wont blow cold air
I don't know how the rules are in Japan but in the USA you have to have an CFC certification from the EPA to buy refrigerant unless it's the little cans to recharge your car a/c. There are other reasons for the air to be warm also. Like the compressor not running.
May 06, 2010 | Sanyo Split System Air Conditioner
Air condtioning unit
check capicitor on motor, fan motor bearings may be locking up when they get hot then when cooled the motor comes back on. Then you must replace fan motor.
Aug 11, 2009 | Heating & Cooling
LG 8008R compressor runs one minute then fan blows 3 minutes
You need to have an AC tech come out and do some preliminary testing on this.
May 12, 2017 | LG Heat cool Window Air Conditioner
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
