Question about Panasonic Lumix DMC-LS80 Digital Camera
I take pictures of plates, cups, bowls, crystal, etc., for ebay. I am getting very yellow - tannish colors. No true colors. It is very irritating. I have a white background, and the background is not even white. It is a brownish yellow. I have no clue what to set my camera on. I just have it set on "intelligent". Outdoor pictures are great though.
    Brigadier General:
  • 11,967 Answers
You need to change the white balance setting. Take a few shots at each setting and review the results. Pick the most pleasing.
Posted on Sep 28, 2010
NUBIRA 2005 Coolant volume decreas , no apparent leaking , checked all hoses , changed thermostat , reservoir.It seems to be corrosion aswater colour becomes yellow , there is no oil mixed in water?
Check the oil for water. It will start to turn a tannish color. Could be a head gasket. You can pull the spark plugs, if one or two look super clean, that's were the water is going.
Jul 09, 2016 | Cars & Trucks
Tip
Dishwasher Tips!
Don't jam dishes in - give adequate space between plates and bowls to allow the water to circulate freely; moreover, be careful that a large bowl or lid does not block the water spray from reaching the inside of any other dishes and drink cups etc.
on Aug 17, 2010 | Dishwashers
KitchenAid ACCOLADE 400 Mixer.When mixing dough the bowl jumps out of the the bowl lock. How can this problem be resolved?
I know this sounds a bit simple but the bowl cup can sometimes actually wear out and a very fast (# screws) and a new one and the problem is solved. If however there is a problem on the head hold down set screw (under the mixer in the cavity ) it can come loose then the mixer head can bounce all over the place causung the bowl to get loose in the holding cup at the base of the mixer., I hope this helps, let us know if you need more, we can FixYa
Feb 22, 2015 | KitchenAid Food Mixers
How many place settings should I buy? How do you decide this?
It starts from 3, 4, or 5 piece sets. lids and saucers are separate. 3 piece set will have a plate, cup, and saucer. 4 piece includes a salad plate and 5 pieces also include either a bread and butter plate or a soup bowl.
english dinnerware will usually have 7 pieces: dinner plate, salad plate, bread and butter plate, cup, saucer, soup bowl and stand.
The number of setting you buy depends on the number of people in your family or the number of people you plan to have in your family in the future. It also depends on how much entertaining you do.
May 06, 2013 | Home
Kitchenaid bowl
Some might say that this is OK, because it can be a bear sometimes to unlock it from it's mixing position, but I am thinking that is not the case here. First do you use a glass or metal bowl. if you use a glass bowl you have a grey mounting screw on the bottom of it that can come loose, if so tighten it up and you should be right as rain, if you are using a metal bowl then it is one of two things, first the bowl has been damaged in such a way that it does not fully engage the mounting cup / plate on the base of the mixer or the mounting plate has taken the damage, look at it carefully to see where the damage is, if it is in the mounting cup on the base it's easy to fix and inexpensive, if it is on the bowl then it's a new bowl and that can be 50-60 bucks for a new bowl. let us know if this helped, if not try to be more specific. Don't be insulted but you may not be locking the bowl in place all the way either. happens to me all the time when I am baking, I don't turn it all the way in.
Jan 20, 2013 | KitchenAid Artisan Series Stand Mixer -...
Picture green with color off mo.av-56p575 jvc
That is a common symptom in projection TVs that use tubes or "color guns" As the set ages the emission in the picture tubes (there are three) begins to slowly fade.
This is unfortunately a normal thing for those older projection sets. A set of tubes will last anywhere from 20,000 to 40,000 hours of operation then they are simply worn out. They can be replaced but I don't recommend it due to the age and technology version of your set. The newer type big screens use a different principle. They either are LCD or Plasma these days. The advantage of the LCD (Liquid Crystal Display) is they are very low in power consumption. The disadvantage is that you can never get a true black, only close. On the other hand the Plasma TVs are more consumptive of power but will give a very sharp image with true black levels. The choice is up to you but I suggest you replace your older television.
Zashiban
Jun 04, 2010 | Televison & Video
I turn my PS3 on then the light turns a tannish color then it shuts off and I can't eject the disk inside it
This is probably the yellow light of death. This caused when the unit overheats causing the solder to bridge. Contact Sony to see if it is till under warranty.
Feb 15, 2010 | Sony PlayStation® 3 (80GB) Console
3 (r,g and b) color lines in background of picture
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Dec 05, 2009 | RCA R52WH73 Projection Television
What's the recipe for coffee ice cream
Ingredients:
  • 2/3 cup sweetened condensed milk
  • 2 tablespoons instant espresso powder
  • 2 tablespoons espresso liqueur
  • 1 1/4 cups heavy cream
    Put the condensed milk in a bowl and stir in the espresso powder and liqueur. In a separate bowl, whisk the cream until it reaches soft peaks. Fold the cream into the condensed milk mixture, then pour this gorgeous caffe latte-colored airy mixture into an airtight container and freeze for 6 hours or overnight. Serve straight from the freezer.
    This is the best procedure to make a coffee ice cream.
Sep 17, 2009 | Ice Cream Makers
Rust inside my washer
Use Oxylic Acid Crystals dissolved in hot water and test for color fast if applicable, carpets, clothes, washer, toilet, surfaces, etc. Oxcylic acid is a white crystaline acid which reacts specifically with Ferric Oxide, (rust) and oxidises the stain quite selectively. Few teasthingys in a small bowl of hot water and a toothbrush. Purchase cheap at local hardwares Hope this Helps Let me Know Ttech
Jul 24, 2007 | Kenmore 22422 Top Load Washer
Panasonic Lumix DMC-LS80 Digital Camera Logo
108 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
