Question about Cnet CN8816TPC (CN8816TPC/220) Networking Hub
How connect cnet cn8816tpc router to the dsl modem
2 Suggested Answers
  • 1833 Answers
SOURCE: I have acquired a used
To connect your network hub with computer and TV do the following.
You need cat5 or cat6 straight cable which single wire color configuration would be orange-white, orange, green-white, blue, blue-white, green, brown-white, brown, same in the both side.
Install a network interface card (NIC), if your computer or other network devices don't already have them.
Install the "T" (normally supplied with the card) onto the back of the connector on the card.
Install the network driver for the network card you installed
Attach the network cable to one connector on the "T."
Connect another side of the cable to the hub,
Restart the computer.
Name the new computer to be networked. Enter a user name and password when prompted. Use information provided by your network administrator, if any, or creates your own.
Check to make sure the system is working.
Enable sharing if you wish to share data with other computers on the network.
To connect with TV if there don't have NIC port then you need coaxial cable to connect
Posted on Jul 28, 2011
CNet wireless router Model CWR-854V. is causing my Ethernet lite on my DSL modem to blink causing me not to be able to get on internet. Changed all cables no help disconnected Router and modem works...
Use an Ethernet cable to connect your computer directly to the DSL modem, bypassing the router, turn the modem off, turn the modem on, wait 60 seconds, and restart your computer.
Does the Ethernet lamp still blink when Windows is booting, and when you are using the Internet?
Turn the DSL modem off.
Turn the router off.
Turn the computer off.
Disconnect the Ethernet cable from the modem, and connect it from the computer to the router.
Turn the router on, and wait 60 seconds, then turn your computer on.
After Windows is running, click Start.
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: default gateway........ 192.168.123.456
If the string starts with '192.168', then your computer *IS* "talking" to the router.
Now, use an Ethernet cable to connect the WAN port on the router to the DSL modem.
Turn the modem on.
Turn the router on.
Wait 60 seconds.
Restart your computer, and you should be able to web-surf.
Jul 19, 2011 | Cnet CWR-854 Router
HOW DO I CONNECT DSL LINE TO LINKSYS WRT54GS
The WRT54GS does not have a jack to connect a phone/DSL line to, so in order to use this router with a DSL connection, you'd have to connect the DSL line to a modem and then connect the modem to the router, or connect the DSL line to a computer if you have an internal modem, and then connect that computer to the router.
Dec 15, 2010 | Linksys Wireless-G Broadband Router
I just switched from cable modem to dsl modem..dsl modem gets on the internet when connected directly to computer..once connected to router doesnt connect to internet
Your new ISP is DSL. the router was working before with the cable modem. The settings for the cable and DSL ISP are different. Now your computer is working when you connect it directly to the DSL modem. that means the modem is working.
The DSL modem works on 2 different modes.
You will need to check which mode is your modem working on and according to the settings of your modem you will need to set up the router.
To change the settings of the router, you will need to open the set up page of the router.
Click Here for more information about the router set up.
Feb 20, 2010 | Linksys WRT160N Wireless Router
My Belkin wireless G router does not seem to work any more. If I connect my router to my DSL modem, I am not able to make a connection to the internet via the router to my iMac. However, if I connect the...
So if you connect the computer directly to the modem , it works .
That means your modem is working properly. Your ISP is DSL connection. Now connect the modem to the router and the computer to the router. Open the router xet up page and change the settings of the router according to the type of connection you have.
There are 2 types of connection in DSL.
DHCP and PPPOE .
Click Here for step by step instructions
Feb 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't configure my router to my modem, i follwed the instruction already from the manual. it still didn't work. still can't connect to the internet
Router set up is very easy. You will need to access the router set up interface to make changes on the router.
If you are not able to go online using the router then you will need to check the settings of the router.
First make sure that your computer is able to go online when connected directly to the modem without the router.
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.ind network key.
Router set up for Cable Internet service provider :
This connection type uses the MAC address of the main computer to identify your connection. They generally register the MAC address of the main computer. So the MAC address is everything in this connection type. Now we set up router using the MAC address of the main computer. Main computer is the computer which was able to go online through the modem. Use only the main computer to set uo the router.
Connect the modem and the computer to the router . Check the IP address on the computer.
According to the Default gateway value open the set up interface of the router. Once you open the set up interface, you will need to clone the MAC address of the computer. Then change the wireless settings on the router and your router is ready to go.
Router set up for DSL Internet service provider.
What is DSL connection?
DSL (Digital Subscriber Line) is a high-speed Internet service that competes with cable Internet to provide online access to local customers. DSL operates over standard copper telephone lines like dial-up service, but is many times faster than dial-up. In addition to being faster than dial-up, DSL does not tie up the phone line. Coexisting with telephone service in this way allows users to surf the Net and use the phone at the same time.
There are two types of DSL connection
1 ) PPPOE : In this connection type you will get user name and password from the Internet service provider. Your computer will not be able to go online when connected to the modem only. You can open the router set up and change the Internet connection type to pppoe and type the user name and password for the ISP. After that change the wireless settings of the router and it will be ready to go.
2) DHCP : In this connection type your computer will be able to go online when you connect it directly to the modem.
you don't require the user anme and password for the ISP.
In this connection your computer will get a private IP address from the router. According to this the IP address of your router will change. Change the wireless settings of the router and it will be ready to go online.
Nov 16, 2009 | Cnet CWR-854 Router
I just installed dsl and want to use it with my existing router and the router doesnt want to work with the dsl ...help what do i do ???
First, make sure the dsl is working by connecting it to your computer directly.
Next, turn the router off, turn the dsl modem off, connect the dsl modem to the router. Start the dsl modem first, then start the router, then start your computer and try to connect.
Nov 07, 2009 | Linksys Wireless-G WRT54G Router
No internet connection
This should be connected as so. From wall outlet to DSL modem, from DSL modem to D-Link router, From D-Link router to Laptop via wireless or wired connection. You will still need the DSL modem installed but the wire coming from the DSL modem will go to uplink port on the router instead of into the laptop.
Dec 21, 2008 | Computers & Internet
I have a netgear wireless router which I need to configure. Part of the process requires me to connect the router to the modem. However the modem uses a USB connection. How do I connect it to the router?
I would check you have the right router, as DSL and cable use different types routers, if you are on a DSL connection my advice would be to return the router and purchase a modem/router and do away with your modem, if you are on cable modem, you have bought a DSL modem as they have no connection for a modem.
Oct 03, 2008 | Computers & Internet
Ic help
Scenario 2 to 4: Scenario 2) The modem does not have an Ethernet port. The modem is a dial-up modem for traditional dial-up service. To use the Router, you need a cable/DSL modem and high-speed Internet connection.
Scenario 3) You cannot use the DSL service to connect manually to the Internet.
After you have installed the Router, it will automatically connect to your Internet Service Provider (ISP), so you no longer need to connect manually.
Scenario 4) The DSL telephone line does not fit into the Router’s Internet port.
The Router does not replace your modem. You still need your DSL modem in order to use the Router. Connect the telephone line to the DSL modem, insert the setup CD into your computer, and then follow the on-screen instructions
Apr 19, 2008 | Linksys Wireless-G WRT54G Router
Cnet CN8816TPC (CN8816TPC/220) Networking Hub Logo
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
valuesrespec
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
