Question about Brother HL-2040 Laser Printer
Paper jam - paper has ripped leaving a piece inside
You can disassemble your printer down to the shell almost. Take off the back and the front to get to the jam easier. Try compressed air if needed.
Posted on Oct 02, 2010
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
Tip
Steps to clear paper jam.
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
on Jun 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
The paper seems to have got jammed up and after I did try to get it out it still seems to say paper jam
Often times after forcing a piece of jammed paper to come out, it can begin to tear and rip. It's possible that a small fragment of paper is still inside the printer, and most likely blocking a jam sensor along the paper path. My recommendation is to take a piece of heavier card stock paper and manually feed it through the machine, attempting to clear out any debris that may have become lodged inside the paper path.
-David.
Oct 30, 2010 | Brother Office Equipment & Supplies
Misfeed Indicator light is on - there are no jamed copies present. Other solutions recommended. Thank you
Make sure that there isn't any little piece of paper caught near a sensor. Often when a jam is removed, the operator rips the paper, leaving some if it there inside. If it's near a sensor, you'll get a constant jam indication. Use a flashlight to check for it.
Feb 21, 2009 | Sharp AL-1642CS Copier
Paper jam!!
2.
3.
4.
5.
put the cables back and switch on
Aug 25, 2008 | Brother HL-2070N Laser Printer
Can't find printer jam inside printer
the small piece of paper is definately inside.or while pulling the paper out you have disturbed the allignment of the gears.clean the gears of the paper feeder.
Aug 16, 2008 | Samsung CLP-510 Laser Printer
Showing paper jam but no paper in machine help!!!!
please confirm that all paper detecting switches are in normal position and can move freely and no small pieces of torn paper inside-clean all switches with dry cloths or brush.-reset your copier off-on-operation.
Jul 22, 2008 | Office Equipment & Supplies
How to fix paper jam Epson CX3650?
2.
3.
4.
5.
6.
7.
CREDITS: nanicool
IF YOU DONT GET FIXED WITH THIS THEN PLEASE REPLY BACK.
I SHALL BE GLAD TO HELP YOU WITH YOUR PROBLEMS.
THANK YOU
REGARDS
SWEET RASCAL
Jun 28, 2008 | Epson AcuLaser C3000 Printer
Printer
2.
3.
4.
5.
6.
7.
Jun 03, 2008 | Office Equipment & Supplies
Paper jam
replace steplon sleve and pressor rollel or replace fuser assy
May 31, 2008 | HP LaserJet 1300 Printer
Brother HL-2040 Laser Printer Logo
94 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
