Question about Amcor PLM-14000E Portable Air Conditioner
Air is not coming out cool what should it be set on?
    Sergeant:
  • 235 Answers
It should be set to a temperature that is at least a couple degrees colder than the area you are trying to cool. Is this a newer unit or is it older. Have you had problems before, or is this a new issue?
Posted on Sep 28, 2010
Power button indicates a cooling mode but I don't hear the compressor come on and the air coming out is not cool. Seems to have worked earlier this summer but sometimes the cooling seem spotty. Tried...
You may not have the temperature set low enough to make the compressor turn ON. Lower the setting until it does. This will give you an indication, where you need to leave it set.
Thanks for choosing FixYa.
Aug 27, 2011 | Amcor ALD12000M Portable Air Conditioner
Cool air comes out when the heat turns on. When I switch to Em heat, warm air comes out. Over the summer the air worker great, however when I switched to heat on the thermostat, cool air came out. Why?
Check the following. 1. Your setting temp must be higher +3 than room temp. 2. Check heating sensor.3. And also heater element.(If it's reversal valve, checke RV is working)
Dec 12, 2010 | Weather King 10AJA3601AH Air Conditioner
You can set the temp for the unit to come on and it comes on and runs and cools for a few minutes then the compressor cuts off then the fan a little later. After a few minutes it comes back on and does...
Is the AC set on an energy saving mode. Together with this program if the thermostat is defective the same symtoms can appear. So please check on the thermostat and replace.
Since the compressor is cutting off the cooling does not take place to the extend that is set.
Aug 30, 2010 | Whirlpool ACC184PS Thru-Wall/Window Air...
Unit turns on no cool air comes out even when setting is on high
1 Please remove th back cover and check if the cooling pipes are getting cool when the air conditioner runs. If there is no cooling /moisture deposit on the pipes it means there is no gas in the air conditioner. Get that checked up. Refill the gas after getting checked up that there is no leakage.
May 31, 2010 | Goldstar GW-HD5000 Window Air Conditioner
I have an LG AC and the lowest temperature setting is 60 degrees
Lowering the temperature setting doesn't change the temperature of the air coming out of the unit it just lets it run until the room temperature gets colder. Check the temp of the air coming out of the unit. If it isn't as cold as it used to be the charge could be low. First though you should make sure the filters are clean and the coils.You should also check the actual room temp. It's also possible the unit doesn't have enough capacity to keep up with the cooling load of the room.
May 02, 2010 | LG Heat cool Window Air Conditioner
AC is set on cool & furnace comes on blowing hat air
My first thought is a bad thermostat or control board or maybe something is wired wrong. If all that seems to be working I would look at the outside unit. if that condenser fan motor is not operating then you wont get any cooling. look for a swollen capacitor. Read more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 06, 2009 | Bryant 463AAC005BA Air Conditioner
Air conditioner is set on cool & furnace is turning on
probably your compressor not running or the air con is out of Refrigerant.
Jun 06, 2009 | Intertherm P3RA-048K Air Conditioner
Installed a honeywell rth7500 series thermostate, no air
Heat/cool wires crossed. RC- is red cool make sure the batteries are good and room temp is higher than cool setting. good luck
May 29, 2009 | Honeywell Electronic Programmable...
Air conditioning blowing only highest setting but HOT air
Sounds like your freon has leaked out and your heater blower resistor is burned out. Deffinitly take this to the dealer.
May 20, 2009 | 2001 Honda Odyssey
Amcor PLM-14000E Portable Air Conditioner Logo
55 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
