Question about Canon PowerShot A80 Digital Camera
Code e18 visible on screen - Canon PowerShot A80 Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea.
Posted on Feb 10, 2011
Won't shut off or take pics. code E18 comes on
Try removing the batteries and cleaning the contacts inside the battery compartment with a cotton swab "dampened" with rubbing alcohol. Also you'll want to clean the battery and charger the same way. Thank you, Dana
Feb 02, 2010 | Canon PowerShot S2 IS Digital Camera
Received the error code from Canon Power Shot
Just Google E18 and you will find all kinds of advice on this long standing problem
Mar 08, 2009 | Canon Cameras
Error message E18
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 12, 2009 | Canon PowerShot S1 IS Digital Camera
Error code E18
Lens errors (aka E18 errors for Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Dec 20, 2008 | Canon PowerShot A95 Digital Camera
E 18 problem
This error is caused by a faulty lens motor, contaminated transmission, or mechanical damage from dropping. Unfortunately, there is no easy fix for this and it requires service from Canon or other repair facility.
Dec 15, 2008 | Canon PowerShot S2 IS Digital Camera
Canon powershot sd400 error code E18
Yes !! I wacked it a couple of times on a hard surface and it started working again after I dropped it and got the dreaded E18 error mesage in the middle of a Jewelry shoot. wm
Oct 14, 2008 | Canon PowerShot A80 Digital Camera
Canon powershot A60. When the camera is turned on there is no image won't take shots, has a number on screen E18 and shuts down after a few seconds. Mike
E18 is an error code from self diagnostic system of the camera.if there is a malfunction in the lense assembly or the focus assembly then this error code appears. You have t show it at a repair shop.
Jul 17, 2008 | Cameras
II've dropped my camera
if it is a motorized zoom, it is probably jammed or broken, try going to the manufacturer's website and enter a search for the errror code which is what the e18 is
Feb 23, 2008 | Canon PowerShot S80 Digital Camera
Canon pwershot s1 IS E18 error code
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 14, 2008 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot A80 Digital Camera Logo
15 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
