Question about Toshiba 37HLX95 37 in. LCD TV/DVD Combo
My tv doesn't recognize my computer when I hook up the monitor cable
When I connect my Win Xp Media Center computer to it it says that it's unsupported. How do I get the tv to display what my computer is displaying?
  • halfcrazy10 Nov 30, 2008
    same here i have an hp win xp laptop and when i hook the cable into my tv into the high def tv i dont know what its called but its what they said i needed at future shop it just doesnt pick up my computer screen and my buddy tried it on his laptop hes has a toshiba and it works fine
Posted on Aug 12, 2008
Try lowering the PC/Laptop display resolution (Display Properties > Settings).
Posted on May 25, 2010
HS-M701-4GB not recognized when connected to USB port.
try loading the drivers for it before hooking it in
Sep 17, 2017 | Computers & Internet
Connect toshiba nb500 netbook to RCA tv win 7 stater with VGA cable and s video no displaying in the monitor tv didn't recognize
Does you notebook shows any connection information after connect to tv. If not you need to install. If this didn't work you have to change VGA cable. If not your notebook doesnot supports the tv
Jan 21, 2013 | Computers & Internet
I have a Jensen (JE1909ACB) 19 LCD TV Can't get it to hook up as a monitor on my desktop. It reply's unsupported mode.
Are you using the VGA port on the Jensen TV? What is your computer's OS?
The usual reason for the unsupported mode message is that the the computer did not recognize the TV as a monitor on boot up or that the previous settings were incompatible with the TV. (For example, if you previously had a CRT connected to the computer and used a refresh rate of 75 Hz, the TV can't handle the refresh rate. It needs to be set at 60 Hz.)
First turn off both the TV and the computer. Then turn on the TV and set it for the PC input (assuming you are using the VGA port). Next turn on the computer. If you have Windows XP or later, it should find the TV and set the resolution without any input. (If it doesn't, use a different monitor and set the resolution to 1366 x 768 and 60 Hz. Then try again.) If you used the HDMI port, try the VGA port. This TV doesn't understand a computer signal over the HDMI port (only set top boxes).
I hope this helps.
Dec 08, 2011 | Car Audio & Video
How can I hook up 2005 Mitsubishi LT-3780D with cable TV? Because in the back of TV looks more like computer's monitor, I can not connect it with a cable cord.,
Your LT-3780 LCD is only one part of a two-part television system. The LCD is the "monitor" and the HD-4001 "Media Center" is where the inputs and outputs are for the television. The HD-4001 was included with the LT-3780. They are connected together with an HDMI cable and a Serial Cable for communications. If you don't have the HD-4001, you can connect your cable box or DVD player directly to the LT-3780 with an HDMI cable. You will not have any means to connect more than one device at a time, as this feature was performed by the media center. You will also be unable to connect any S-Video, Composite, or Component devices, as these connections are only on the back of the Media Center.
Aug 13, 2009 | Mitsubishi LT-3780 37 in. LCD Television
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Jun 21, 2009 | Linksys Wireless-G Broadband Router
Ok when you hook it up and it says MTP just push and hold the Play pause key till it says Usb then it should recognize it .....
now mine recognizes it on both usb and mtp i have win xp pro ...  If you do this and it doesnt work
If you are using Windows XP or Vista, make sure that the player is in the Media Transfer Protocol (MTP) mode. This can be done by pressing the M button. This button is located on the top of your mp3 player. Open Windows Media Player 10 or 11 and follow the directions for transferring (synchronizing) music. If you have Windows Media Player 9 on your XP machine, upgrade to Windows Media Player 10 or 11. This can be done by visiting
If you are using Windows 98SE, Windows ME, or Windows 2000, you will only be able to transfer music using the USB transfer mode. Open Windows Media Player 9, and follow the directions for transferring (synchronizing) music.
If you have version 9 on Windows 98SE or Windows ME, you will need to visit the Download Center for updated drivers.
Jan 15, 2009 | GPX MW-238B MP3 Player
Computer won't recognize monitor driver
Its the usb, if u connect the monitor via the standard port, the vga port, it will work. If your monitor only have an dvi cable you can fix that by an adapter. That adapter should be an DVI to VGA.
Good luck to you
Dec 11, 2008 | Acer AL2016W 20" LCD Monitor
Windows xp mce
Do you have tv tuners installed and setup properly? Media Center 2005 is just the software, the computer needs to have hardware tuners in it and hooked up to external antenna or cable.
Feb 15, 2008 | Philips TV Tuner Video Capture PCI Card -...
Unable to connect to computer
Does you player have media player 11 installed? If it does you need to completely uninstall all traces of it and install media player 10 installed.
Feb 03, 2008 | Samsung YP-K3 MP3 Player
Toshiba 37HLX95 37 in. LCD TV/DVD Combo Logo
2,440 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
