Question about Technics SL-1210 Turntable
Technics sl 1210 will not start up
Help! i have power going to my 1210 mk2,but when you press the start/stop button the platter does not spin. When you press the button initially there is the slightest bit of movement. The platter moves freely manualy. Ahh please help!
  • Fredericka Jun 06, 2008
    cheers, they had never been opened untill last night, everything looks fine no unatached cables in there .I think i will need to send it away as it looks far to complecated in there for my electrical skills , thanks for your response J
  • Fredericka Jul 03, 2008
    My deck is now fixed , hooray ! The Driver IC was replaced an6675 and then the deck was recalibrated .
    Problem Solver:
  • 6 Answers
Did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
Posted on Jun 03, 2008
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
Hi having a problem !!
If it has a belt drive, the belt has to be replaced.
Mar 22, 2015 | Technics SL-1210 Turntable
Technics sl 1210
you might try lifting the platter off and putting a drop or two of light machine oil on the spindle. cleaning the motor might help also.
Jun 27, 2013 | Audio Players & Recorders
There is power going through my technics 1210,but the platter & strobe light still will not work
how do you know theres power to the unit if theirs no strobe light pitch adjuster light & the platter doesn't spin?
the power comes in & to the transformer first,then through the strobe switch, the transformer is what blows when you short the target light out.....i've seen this many a time when people try & change the target lights to blue neon.
Mar 04, 2013 | Technics SL-1210 Turntable
Help for technics 1200 MK2 and 1210 Speed is too fast
On the 1200MK2 the pitch control slider is for just that purpose. Disregard the 0 setting and use the illuminated strobe marks on the platter to adjust to nominal speed. When they appear to be motionless you are there. The control on the 1210 may be a knob but the same principles apply.
http://en.wikipedia.org/wiki/Technics_SL-1200
Apr 04, 2009 | Technics SL-1210 Turntable
Technics sl 1210 MK2 does not start
Your switch probably went bad. Does it not respond at all? Does the button at least 'bounce' back when you press it? If not, then you might have messed something up when putting it back together.
- DJPROLAB
Feb 14, 2008 | Technics SL-1210 Turntable
Technics 1210 mk2 problem with pitch and lights
Check that your voltage settings are set correctly. This is located underneath your turntable platter. If you remove the slipmat, you will see 2 holes on the metal platter. Rotate the platter till you see the voltage switch, located @ the 9'o'clock position. Make sure it's set to your correct settings (N.America = 115V / Euro = 220V). If not, you will need a flat head screw driver to switch it. Before you switch it, make sure your unit is off and unplugged. After you swich it, it should be ok.
If your still having issues with the speed and the pop-up light, then there is something seriously wrong, and will need to be checked by a technician. Sometimes a resistor or IC will go bad, causing the speed issue, but for the pop-up light - that's usually faulty wiring generally caused by an incorrect replacement.
Did you buy this new or used? Have you had this serviced recently?
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians
Nov 30, 2007 | Technics SL-1210 Turntable
1200 platter drag
the platter should have two holes on it,my 1210 does. put your thumb on the spindle and a finger in each hole and prize the platter off. theres no screws holding the platter on just a tapered spindle shaft. it is quite heavy so a good pull will do it. as for the scraping it might be as simple as packaging placed under the platter to secure it for shipping, technics are built really well so i cant imagine it could be anything major. i hope this helps you out, if you need any more help let us know. please also let us know how you get on. darren
Oct 05, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1210 Turntable Logo
498 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
