Question about Acer Extensa 4620 Notebook
Few keys are not working in the keyboard like down arrow key , left arooow key and delete key
  • Anonymous Mar 18, 2014
    arrow keys not working and delete key not working
  • 97 Answers
Press your space bar (continues for 5 seconds) than try the keys.
Posted on Sep 28, 2010
How do increase the volume on my acer aspire 5741 laptop
I hope I can help!
If you want to use the buttons on your keyboard to adjust your volume, just hold the "Fn" button just to the left of the windows key, and then push the "up" arrow or "down" arrow. To be clear, those are just the main arrow keys, up will turn the volume up, and down will turn it down (of course).
I hope that helps!
Jun 19, 2011 | Acer Aspire One Netbook 8.9" Notebook
Tip
Hi, After I did this fix (which did succeed in unlocking the keyboard), I found...
The rt. keyboard connector has 7 connectors bussed together some of them become open. Cut a piece of foil wide enough to cover just those connectors and slide it down into the plug over just those 7 connections and this save replacing the keyboard.
DickyO
on Jul 16, 2010 | Lexmark Wheelwriter 1000 Typewriter
How do i flip my computer screen back?
Heya
Press CTRL+ATL+ Arrow keys on the keyboard
Say for example you want to flip it strait PRESS CTRL+ATL+UP Arrow key
Flip Right PRESS CTRL+ATL+Right Arrow key
Flip Left PRESS CTRL+ATL+Left Arrow key
Flip DOWN PRESS CTRL+ATL+DOWN Arrow key
Thanks & Regards
LoNG LiVE ThE gEeks!!!!!
Dec 11, 2010 | Computers & Internet
My Toshiba Satellite Pro A300-GR laptop wont type the letters o l k i and numbers eight and nine as well as comma - stop - down arrow not working - right arrow not working and delete key not working - also...
You have Number Lock set on your PC - Have a look for a key top right hand side, it will have something like NumLck written on the KEY - you may need to use that Key in combination with the FN key - bottom left of keyboard - there should be a light somewhere on the keyboard which goes on/off as you toggle the NumLck key. You should see different coloured numbers on the key s*()UIOPJKLM These are the numbers and symbols that will be displayed when the NumLock is used
Apr 15, 2010 | Toshiba Portege M205-S810 Tablet PC
Several keyboard keys on my Presario CQ60 do not work... i.e. backspace, delete and any directional arrow keys. Can I reinstall a drive and fix it? Mike
it seems the the middle part of the Keyboard circuit is having the Fault
Backspace arrow and delete keys are located in the middle area the Keyboard
I think its a problem with the Hardware --
Need to change the Key board -- (PROBLEM is with the Keyboard)
if its possible then try with another keyboard
Jan 08, 2010 | Compaq Keyboard
CLOCK RESET
Press the FN + F9 keys until the time and date appear on the LCD display.
press the FN + F10 keys to go into the Set Mode.
Use the left or right arrow keys to select the hour.
Change the hour by using the number keys on the keyboard or by up and down arrow keys
Use the right arrow key to select the minutes and change the hour by using the number keys or by using the up and down arrow keys Press the right arrow key again to choose the 12-hour or 24-hour format with the up and down arrow keys.
To change the date, use the right arrow key again and use the up and down arrow to select the month. To change the day, use the right arrow to select and the up and down arrows to change the day.
When you are finished, press Enter on the keyboard to exit Set Mode.
hope this helps
Apr 02, 2009 | Logitech Cordless Desktop MX3200 Laser...
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
Backspace key
you might have sticky keys permanetly stuck on, ive had this problem, it worked after i held down shift and press the backspace key, then it worked nomally again. hope this helps.
Jul 15, 2008 | Acer NSK8458AN Keyboard
Acer Extensa 4620 Notebook Logo
127 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
