What can I do to make my shredder to work. It works only on reverse
    Genius:
  • 1,218 Answers
If it wont run forwards try cleaning the "eyes" in the middle where you put the paper.
Posted on Oct 09, 2010
My Executive Machines EPS 1200X shredder works in reverse, but does not shred.
there should be a forward/ reverse switch that is used to unjam paper being shredded. check that
if it is automatic then check for paper stuck in the shredder causing the reverse action.
May 12, 2015 | Shredder Office Equipment & Supplies
Dynex shredder only works in reverse
If your shredder is jamed with paper, the centre of your machine has a switch which is plastic. If there is paper under this switch it will prevent it from being pushed downward, it will not shred paper, it will only work in reverse. Unplug your machine and clear the paper jam so the little plastic switch will be able to go down and it should work. Hope this works for you.
Sep 23, 2014 | Dynex - 10-Sheet Crosscut Paper Shredder
Fellowes P35C works in reverse but not forwards
In forward operation, a detector senses the presence of material in the feeder and turns it on. Reverse operation is selected by switch position; no sensor is involved. I would bet that if you remove power and turn the shredder upside down you will find bits of shredded paper clogging your shredder, particularly in the center area where the detector is located. After thorough removal of debris, you should be back to normal operation
Feb 03, 2013 | Fellowes P35C Black Cross Cut Shredder...
Why doesn't OfficeMax OM99732 shredder work on Auto?
My shredder would not sense paper being inserted and the sensor could not be cleaned. So "Auto" no longer worked but the manual reverse DID work. I opened the thing up, reversed the polarity on the red and black wires on the connector for the main drive motor and VOILA!!! I can use my shredder in manual mode by switching it to REV. Be mindful that this keeps the motor running until it is switched off. This can heat the motor and cause failure so I limit my shredding to 60 seconds then give it a rest so it will cool down. Also there is no emergency reverse so watch your fingers and neck ties.
Dec 17, 2012 | Office Equipment & Supplies
Shredder doesn't shred.
Shreader wont cut will reverse ok
Hi I have a GBC Shredder, made by swingline, model GLX2030. Since this morning the shredder didnt stop! Normally the shredder work only when we put paper into...but today we have to push the ''ON'' button...
There is an infeed sensor that isn't being made for auto on which is just a simple flipper switch and if it doesn't work it is because there is paper jamming it. Unplug it and turn it over where the blades are and see if clogged up and if so than put back on and reverse it and than forward again until it releases if it has a reverse ,reverse it. If no reverse unplug and use a narrow object to clear from the bottom side
Mar 28, 2011 | Gbc GLX2030 Shredder
JAMMED SHREDDER
if you have reverse, run reverse.
if you don't have reverse, you will have to disassemble the drive shaft/cutters and clear manually
Apr 05, 2010 | Aurora Electronics AS662C Shredder
Doesn't work going forward only in reverse
sounds like you have a sensor problem. is it automatic reversing on jamb? if so sensor is defective, or there is a bind causing sensor to reverse only, a bent shaft could cause that
Apr 04, 2010 | Aurora Global AS501X-MS Shredder
Our 0S - 11 cs shredder has stopped working. The lights are still on but it will only work in reverse.
Make sure there is no paper shreds blocking the sensors on top and also underneith the cutters. Use a cotton q-tip to clean dust from sensors and maybe compressed air.
May 15, 2009 | Fellowes 3011001 Shredder
63 people viewed this question
jasbo
jasbo
