Question about Pioneer Audio Players & Recorders
I have a a/v recevier that i am trying to hook up to a emerson lcd high def tv but there are no outputs on tv how do i hook it up
  • 37 Answers
You can download free user manuals from, http://www.retrevo.com/samples/index.html
Posted on Sep 28, 2010
When i hook up my ps3 to an emerson 19 in tv with an hdmi cable it says format not supported
LCD Emerson only support screen with a 1440 x 900 720p resolution.
And PS3 has support 1080p or full HD.
You must arrange output HDMI resolution to 1440 x 900 or to 720p.
thanks.
Mar 21, 2011 | Emerson LD195EM8 19 in. LCD TV
Can't get HD on my TV. Tried with every cable type but cannot get High Def
2 things have to happen. first, your tv has to be set for the correct resolution, second, You need to be recieving high def from your cable/sat provider.Your tv does not make programming high def, it allows high def.
Mar 10, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
I received a Blue Ray as a gift but I don't know if I can connect it to the Emerson LCD LC195EM92. Can it be done? If so, how?
I couldn't find a picture of the inputs for your television model. Look at the inputs on your television and the outputs of your blu-ray. If your TV is high def you should be able to use a HDMI cable from the blu-ray to the television. There should also be other inputs on the television if you can't use HDMI but they won't have as good of a picture as HDMI. You will need to have cables for video, and cables for the audio in some cases.
This link should help you. http://www.emersonaudiovideo.com/support/connection.php
Feb 10, 2011 | Emerson LC195EM9 19 in. LCD TV
Tv is stuck on standard def.while it is hooked to hi def signal.How do I reset it?
read your owner's manual; to find out which video output is HDMI it is usually video3 set this in the video "menu"
Jul 17, 2010 | Polaroid 3211TLXB 32 in. LCD Television
My company's remote will not work on my high def Insignia TV. They told me I have to get a code to be able to turn it on or off Need code for Model NSewL
A variety of remote control codes can be found at InsigniaProducts.com; just search for your TV model number and click Support. Also, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
May 08, 2010 | Insignia 42" LCD Flat-Panel HDTV
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Motorola DCT 6200/1000 seems to only have one audio output?
There are three options:
1) Connect the Tivo using the coax output of the cable box into the cable input of the Tivo
2) Exchange cable boxes with your cable provider for one with composite output jacks. It may require you to use a Motorola box that isn't High def depending on what your provider has. I know Comcast has a Motorola HD tuner that has composite outputs as well as component.
3) Upgrade to a Series 3 Tivo. Those units are designed for High Def. Use HDMI cable hookup.
Jan 17, 2009 | Arris DCT6200 DTV Receiver
Picture problems
The pixelation is probably caused by MPEG2 compression on the DVD and Virgin media video streams, the blur is probably caused becasue you are displaying a standard definition signal on a high definition TV.
However if a high-def source still has these problems then you may have a faulty TV, your best bet is too hook up a high-def source such as a HD/Blu-ray player or PS3/360 games console.
Should a high-def source look ok, then you may have some look changing the display settings on the TV to try and improve picture sharpness and color balance.
Thanks.
Nov 08, 2007 | Televison & Video
55 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
