Question about E-Machines eMachines Desktop PC
T2385 i unplugged everything. the only way to power down is to unplug it. when i plug it back in the lights flash and the fans go (without touching the power button) and it taps rapidly
  • 1 more comment
  • sandy02479 May 24, 2008
    i unplugged everything. clicking? it's hard to say where it is coming from, but when everything was plugged it came out of the speakers for a few seconds as well as the unit itself. i don't know alot but it doesn't sound like when my old computer's hard drive went
    the light around the power button is greenish orange. the hard drive access light is orange. they flash together continuously. the tap/click noise seem to keep pace with the flashing. no pattern just continuous. when it was plugged in my monitor said no signal
    there is a repair guy i have bought stuff from and he lked at my printer. he's on your list. nice guy...i'm not so much worried about thecomputer as i am getting all my important stuff off of it!!
    i appreciate your time and effort as well as your quick responses
    Guru:
  • 859 Answers
Okay, Good. That's a start for me to help you. Did you unplug the keyboard too and where do you hear the tapping coming from? And, would you kindly take a moment to see if you can try another word for taps. OK?
Thanks in advance,
Worldvet
Posted on May 24, 2008
  • 1 more comment
  • Glenn Rogers
    Glenn Rogers May 24, 2008
    Alright. It is hard for us here as techs to diagnose problems using a messaging system when we are most used to handling calls over the phone from local users but bear with me even if what I give you is bad news.
    You have a green light that indicates power is on and the tap or clicking sound.. is it in sequence with a orange or yellow light?
    Thanks for your patience.
    Worldvet
  • Glenn Rogers
    Thanks for the information on the lights. It sounds like a hard drive read write stylus moving back and forth and thus broken, but this would only mean you need a professional tech local to you that you can trust and has done work for other people you know.
    Here at Fix Ya, there is a directory of places you can go to. Still, I rely on referrals only to get new customers and believe that is the best way to find a tech who will treat you fairly.
    Is there someone you can go to you've used before and trust or is there at least someone you can ask?
    If not, please try your local chamber of commerce and check with the Better Business Bureau first if they are new to you.
    Sorry to be the bearer of bad news, that is to say you need more help than we can give you here with just text messaging to rely on.
    If you have found my assistance helpful, please select Helpful vs. Thanks for Trying. It means a lot to those of us who spend time with folks like you for free and not for a fee.
    My best regards and good luck,
    Worldvet
  • Glenn Rogers
    There is still a chance that it may be your power supply sending voltage out to the wires that run your hard drive over and over again. If that is the case, then you will have a fair chance of recovering your data, if it is the read write stylus or hard drive motor chances are not good.
    Just so you know, there are companies that will take a hard drive apart and put the data platters on a working drive and recover the data for a fee. It is usually quite expensive and only worth the money for accountants, tax preparers and financial firms.
    Best of luck and it was my pleasure to help you out. Thanks for using Fix Ya.
    Worldvet
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
Wont power back on. only yellow light flashes
I have an aspire one AOD250 notebook and I have had to unplug and plug the power cord to the outlet on the side and it always gets my charger light to come on, try it
Apr 03, 2010 | Acer Aspire 5610-4648 Notebook
Initially, my fan would run fast and then slow. Then, it began to shut off frequently by itself; the monitor would state "monitor sleeping." Now, the CPU will not power on at all. Even after having a...
Fixing the problem would have been to change the fan when it started to fail. The bearings were probably going out and causing it to labor and slow down. When the fan quit altogether that was the big flashing warning sign "Do not run till you fix me" type of warning. CPU's develope tremendous amounts of heat. Without a fan there to cool it, it could have damaged something.
1. Get a new fan
2. Unplug all add on cards
3. Unplug hard drives, floppys and cdrom
The only thing that should be plugged into motherboard is the video and ram and keyboard. Unplug power supply for 1 minute. Make sure the power supply master switch on the back is on. Try to start the computer. If it starts then start connecting your drives back one at a time and any addon cards. If it doesn't start you may be looking at replacing motherboard or CPU. I've never seen an Intel CPU fail even from heat but there is a first for everything.
Dec 07, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
Projector turns on the power light flashing and lamp light solid
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jun 12, 2009 | HP Digital Projector Vp6120 Multimedia...
4600C no power, flashing amber light
i have a dimension 4600c. same problem. amber flashing light no sounds. replaced my power source and its now working fine. bought one on ebay for $47
Apr 11, 2009 | Dell XPS 700 PC Desktop
Emachine t2385
You might have a stuck key on your keyboard. I emphasize might.
Try this though:
Remove the power cord from the back of your PC. Leave it out for a minute or so. While it is unplugged turn your keyboard over and strike the top of the keyboard against your work area top a couple of times. Some debris may come out, could unstick any key that may be stuck. Reattach the power cord and if it doesn't power up immediately turn the power on and see if everything is okay or not.
If not, let me know by commenting back so I can talk you through another troubleshooting technique. Okay?
Regards,
Worldvet
May 24, 2008 | E-Machines eMachines Desktop PC
Power Green Light Flashing HP Desk Top PC m7250n
During a power outage their is a surge when power come back on the grid (surge can be caused by lighting strikes akso). This surge trips the internal procters inside the power supply to protect the Mother Board, hard drive, processor and fans and any device that pulls wattage from the power supply. Since all these power using devices are trying to pull power at the same time to boot the computer back up one ends up with a loop of surge thrugh the power supply with a protective trip, reset, surge again and trip again. This will continue in this loop as the computer is trying to boot all the devices at one time (Mobo, Hd, processor, cooling fans and other devices). Simoly, more power wattage is being demanded than the protectors will allow at one time causing a protective shutdown followed by a restart followe by a protective shutdown in a continious loop.
The normall sequence for a boot is to boot the board, processor and fans followed by a boot of the hard drive, and other boot devices once the board is energised, NOT all devices at the same time, as this results in an overload and trips the protectors. This protective loop is indicated by the blinking light as the power is turned on and then shut down for protection as the wattage pull is over the demand that the protectors will allow.
Blinking light indictes you are in the protective loop.
SOLUTION: 1. Disconnect the Mother Board connector, with the computer unplugged, this will allow the power supply to reset at maximum wattage upon reboot.
2. Disconnect the Hard Drive power connector and ay boot device power supply cables, this will allow the Mother Board, processors and fans to boot without an overload of the protector inside the power supply.
3. Plug in the computer and the indicator light will be solid green indicating that it is reset and out of the loop.
4. With the computer pluged in and the Power Supply fully energised, plug in the Mother Board. The computer will now boot, and the processor fan will come on and the cooling fans.
5. After computer has rebooted, shut the computer back down and connect the Hard Drive power cable and any other power cablis that were unplugged.
6. Reboot with all cables connected and you are up and running again.
POWER SUPPLIES HAVE AN INDICATOR LIGHT FOR A REASON.
REMBER - BLINKING LIGHT IS AN OVERLOAD OF THE PROTECTORS AND ELLIMINATING THE OVERLOAD SOLVES THE PROBLEM AND THAT THE POWER SUPPLY IS WORKING AND CONVERTING POWER.
NO LIGHT MEANS NO POWER OUTPUT AND THAT INDICATES THE POWER SUPPLY IS NOT FUNCTIONING AND NEEDS REPLACED.
Hope this helps everone with power outages and lightining strikes. It is a rather common problem and can also occure when building a computer and one missmatches the power supply with the board wattage needs. If the board wattage needs are greater than the power supply output you will get stuck in a potective loop eventually. WHEN BUILDING A COMPUTER ALWAYS MAKE SURE THE POWER SUPPLY CAN PRODUCE MORE WATTAGE THAN YOU CAN CONSUME AT THE MAXAMUM LOAD.
Have a great computing experiense.
Jan 13, 2008 | HP Media Center m7250n (ED842AA) PC...
All lights on the touch panel are flashing and a continous beeping sound
bosch 700 series range. So far unplugging the range and waiting several minutes to plug back in reset everything like rebooting a computer.
Dec 19, 2006 | Bosch HGS435UC Gas Kitchen Range
E-Machines eMachines Desktop PC Logo
59 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
