Question about Honeywell HY-048BP Tower Fan
The fan rotates but wont blow air - Honeywell HY-048BP Tower Fan
My heater won't blow out any air
make sure the fan is rotating if it wont turn it wont blow heat.
Feb 01, 2015 | Heating & Cooling
Maza 323 radiator fan rotating direction
the direction of fan rotation will be on the motor body but check that th curved edge ( leading edge) of the fan blade is facing the radiator and that air is being pulled through th radiator. THe motors are dc operation and can spin in both directions and the fans themselves are made to fit in front of the radiator( a/c fan) and blow air through the radiator. So checking these points is necessary
Jan 19, 2013 | Mazda 323 Cars & Trucks
It turn on , revolve but no air comes out
I am having the same problem. Did you ever fix your fan?
Aug 29, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
Whirepool Refrigerator
Single phase appliances only turn in one direction. Try cleaning your condenser to get better air circulation. Sounds like your compressor went out on head pressure.
Dec 30, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ceiling fan does not blow air
I would guess that the blades are on upside down. Ceiling fans are not supposed to work the same as desk fans though. The idea is not to create a strong flow of air but to create a "cooling breeze" by speeding the convection currents. They work better when they are running slowly (like you see in the old movies)
Sep 19, 2009 | Hampton Bay 24002 Ceiling Fan
My lasko tower fan gets power n wont blow air
The bearings on the motor are dry and need oil. It's really not made to be oiled, but you may be able to take it apart and get some oil to the bearings if you want to mess with it.
Jul 22, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Blower motor wont start
Every air conditioner is equipped with at least two motors, the compressor and the fan motor. It is possible for the fan motor to be defective and the compressor to be running. If this is the case the unit will appear to be running and may even sound "normal" but no air is blowing out the front or back of the unit. If, after removing the cover of the unit you discover the fan blade is very stiff and difficult to rotate, the fan motor should be replaced. If the fan blade turns freely the circuit powering the fan motor will require electrical troubleshooting. It may be necessary to have a qualified technician locate the cause of the problem, which may be either a problem with the capacitor, the selector switch or the motor itself.
Jun 06, 2009 | Goodman CKL42AR42 Air Conditioner
I need to replace my condenser fan motor. I replaced it once before but instead of blowing out the top, it was blowing on the condenser. Should it blow out of the top? If so, what direction should the...
Yes. It should blow out the top. The rotation of the fan does determine the direction of air. Either have the motor replaced and indicate the direction of rotation.
May 08, 2009 | Heating & Cooling
Fan motor blows air toward the grill
The rad fan should **** the air through the grill from front to back. Best of luck.
Mar 22, 2009 | 2002 Jeep Grand Cherokee
Honeywell HY-048BP Tower Fan Logo
26 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
ray gallant
Danny Kuhlmann
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
