Question about HP Computers & Internet
I own a computer with an integrated DVD player bought in Australia. I tend to play french and australian DVDs, however every time I switch between DVDs I have to change Region. I only have 2 changes left then apparently I won't be able to change region code any more, so I was wondering if I can do something about it ? The DVD player description is: HL-DT-ST BDD VDRW CA10N SCSI CdRom device. Thanks !
  • sophiemlr Sep 28, 2010
    The computer is currently not online, would you have any solution which doesn't involve downloading or running a program ?
    Thanks.
  • HP Master
  • 4,737 Answers
There's no option from the Windows to change the Region, but there are few free tools available to unlock the Dvd region to "Free Region". If the operating system installed on the system is Windows Xp, please install this and restart your computer (click here). [if it's windows vista or windows 7, then skip].
Again download and install this utility (click here), now run the program, a windows similar to the below picture will open up:
Click "Control", select the "Region Free" and do whatever changes' needed and click "Start Player". [Note: If control is not available, then install the first tool i've mentioned].
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Sep 28, 2010
  • Lebanon Raingam
    Lebanon Raingam Sep 28, 2010
    It's not possible for now and you didn't mention the operating system, but I hope you are accessing this website from another computer, if so you can download and copy the files to the other computer.
    Here's another tool (click here), simple and very small application, I've tested it on one of my system, it worked. You'll need to restart the computer. It will never work unless the system is restarted.
    It's possible from the Registry entries in windows xp, win 2000 and win 97, but it's complicated and you'll need to create "Key" and "Binary Value" which is risky and may cause system failure if done incorrectly.
    If you insist, i'll let you know after this.
    Once again good luck.
Pioneer dv320-k = no longer region free??
You maybe able to get a region free code for your player from these WEB sites.
REGION FREE CODES FOR DVD & BLU-RAY
www.dvdexploder.com/ www.videohelp.com/dvdhacks www.download-info.com/dvd/index_new.htm
Feb 24, 2013 | Pioneer DV320K Multiregion DVD Player PAL
Is there a way to change the region code on a Sony HCD-S300 Please?
Unfortunately, you have a DVD player that is "Region Specific" and cannot be changed. Your system has a region code printed on the back of the unit and will only play DVDs that are labeled with identical region codes. DVDs labeled "ALL" will also play in this unit. If you try to play any other DVD, the message " Playing this disc is prohibited by area limits." will appear on the TV screen. Depending on the DVD, no region code indication may be labeled even though playing is prohibited by area limits.
Mar 26, 2012 | Televison & Video
Foreign disc messed up portable dvd now it wont play british dvds
Croikie!!!
See if there's a factory reset option in the menu
Also,try cleaning the laser lens with 90% alcohol and a swab ( Gently) then buff it dry
Apr 19, 2010 | Sony DVP-FX811K 8 in. Portable DVD Player...
Toshiba BDX2000
is there a multi region hack for the toshiba bd2000kb blue ray so i can play imported dvds and blue ray.
Apr 10, 2010 | Toshiba BDX2000 Blu-Ray Player
PANASONIC DVD RECORDER DMR-ES35V
DVDs are region coded. This means that they will only play on a DVD player from the region the DVD was produced to be watched in. For example, an Australian DVD is Region 4. It will only play on a Region 4 player. If you try to play it on a player that is set for a different region, it will probably not play. One way around this is to get hold of a multi region player. These are widely available. Alternatively, you should be able to watch the DVD on your computer, although you may need some region free software if your computer's dvd player has been locked. Usually computer DVD players will allow you to play DVDs from any region a few times and then they will lock to a particular Region Code. If you are in North America, you will need a PAL player. The only other thing you may be able to do is to unlock your existing player to convert it to region free. Many DVD players can be unlocked but you would need to find the unlock information for your paticular player. Hope this helps....
Jul 27, 2008 | Panasonic DMR-E55 DVD Recorder
Looking for the regional code for a Panasonic DMR-EZ47V DVD/VCR combo in Australia and a Panasonic DMR-ES30V DVD/VCR combo. Can you please tell me how you put the code in. Thanks
Region codes are preset in the DVD unit. DVDs are encoded with a region code and are only playable if the DVD player is programmed with the same code as the DVD itself. If you want to play Australian DVDs, you will want to use code 4. There are 9 codes. Check below to find out what region each code is for:
http://en.wikipedia.org/wiki/DVD_region_code
You usually may only change a region code 3 times before it becomes permanent. You need to enter the menu-setup options in your DVD player and you'll want to look for "region code".
May 03, 2008 | Televison & Video
Australian dvd doesnt play on my dvd player
America makes it hard for any of us to view CD's from other regions. I've had to pay out to have videos and DVD's converted. Other options are playing them on your computer dvd with software that will play different regions. Go to New Zealand or Australia and buy yourself a player that will play other regions. Other countries cater for international viewing.
Jan 08, 2008 | Sony DVP-NS325 Multi-disc DVD Player
Dvd region codes
Try this (for a LH-T360SE)
Open disk tray and press 0000, a two line menu appears with "Edit Region _" and "Region Code:x" put in required region (presumably 0) and press enter. Region Code:0 appears. power off and enjoy.
region code 0 is No region restrictions.
Nov 03, 2007 | Televison & Video
Computers & Internet Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
