Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
NTLDR missing I had formatted one of my hard disk partitions and tried to install XP (prof) SP2. I got the message "NTLDR missing, please re-start the system" Please let me know how to overcome the error and able to install XP SP2 easily. Azim
  • 1 more comment
  • Syed_Azim May 24, 2008
    Dear Worldvet,
    I could not load xp sp2 (it failed), same message repeated "NTLDR missing, please re-start the system"
    Please...
    azim
  • Syed_Azim May 29, 2008
    I'm out of station, will be informed soon after returning....(Azim)
  • vinujanan Oct 28, 2008
    yes
    Problem Solver:
I can get into the Boot First Screen but can't seem to change anything within it... These screens seems to be selectively responsive to my key presses.... I can get the bios screen up, boot order screen up but not necessarily do anything within them... e.g. I can't restart the pc using ctrl alt del when the missing NTLDR message appears.... also I have put an XP disc in and it says to press any key to BOOT from CD .... I Do so but obviously it doesn't recognise it so it gives me the missing NTLDR message again! :(
Posted on Sep 07, 2008
This is raj ihave face ntldr missing
Posted on Sep 29, 2008
For me it is, all i have to do then is just download a recovery software and voila, boot ini again... Thanks a lot
Posted on Jun 24, 2008
    Guru:
  • 859 Answers
ntldr missing means there are no instructions for loading the Operating System. The instructions are in a file called boot.ini
Please explain further. Did you finish installing XP or did it fail?
Thanks,
Worldvet
Posted on May 24, 2008
  • 1 more comment
  • Glenn Rogers
    Glenn Rogers May 24, 2008
    You will need to try and install XP again and when it prompts you have the setup format your drive for you as NTFS.
    Good Luck,
    Worldvet
  • Glenn Rogers
    Are you using the CD to initiate the Install or is the Contents of i386 on another local hard drive partition?
    Worldvet
  • Glenn Rogers
    Glenn Rogers May 29, 2008
    Sayed,
    You probably need to enter your bios setup screens. Press either F2, F10 or Delete on bootup depending on your system maker. Once you are in the bios setup screens you will want to find something that is identified similar to this: "Boot Priority Order" or "Boot Order".
    What apparently 'may be' happening is that the PC is attempting to boot from your hard drive and for some reason is 'not' looking to your XP CD ROM. With that in mind, there is another setting to change next. It is for what hard drive to access first and which CD ROM to access first, if you have two. So, when you get your first bios setting screen you'll notice a list of devices which include your hard drives and CD ROMs, note the model name and version you are entering your CD into, then you want to most likely go to the last setup screen or another instead and where it says which Hard Drives or CD ROMs to load first enter this setting and select the CD ROM that you noted that you are putting your CD ROM into.
    Other than that I need more information from you on what you've found out and what you are or are not doing. Can you help me with this.
    Thanks,
    Worldvet
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
My windows XP has an error message when started. It says "MISSING NTLDR, PRESS CTRL, ALT, DEL TO RESTART" I tried restart with boot disk but nothing. Please help!?
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Jan 22, 2014 | Belkin Basic Wireless Router
How to fix a NTLDR is missing error
Fixes for NTLDR Errors
Apr 06, 2012 | HP Pavilion 513n (P9850A#ABA) PC Desktop
MY PC IS NOT BOOTING AND DISPLAYING MESSAGE ''NTLDR IS MISSING''?
Missing NTLDR file.
To repair missing orcorrupted system file/s, please click on this link and follow my instructions :-
http://www.fixya.com/support/r4482455-repair_windows_xp
May 22, 2011 | ASUS P5GZ-MX Motherboard
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
Replacing with harddrive 40GB
Did you simply swap hard drives? "Couldn't find NTLDR" basically means the PC cannot find any version of Windows installed because the boot file is missing. This could be because you have a CD in the drive or the hard drive is missing or broken.
If you put in a new hard drive to replace your older smaller one you need to reinstall Windows on that new 40GB drive or it just won't work. If you have some PC Tech friends they should be able to move the data which is tricky or help you out.
Mar 18, 2009 | Compaq Presario 5000 PC Desktop
Needed to reinstall xp home-sp2 with my recovery cd-rom
Try changing the CD, if that dosn't solve the problem :
1. Format the whole hard disk using the default partition manager.
2. Install XP freshly.
Mar 13, 2009 | Microsoft Windows XP Home Edition
NTLDR missing on changing harddisk connection
put the xp bootable disk in computer and boot from it, choose repair option. it will slove your problem.
Feb 24, 2009 | Microsoft Windows XP Professional With...
NTLDR is missing
  2. Check your floppy and optical (CD/DVD) drives for media. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors. There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  8. Open your computer's case and ensure that the cable that connects the hard drive to the motherboard is firmly in place. If this does not resolve the issue, try replacing the cable. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
  12. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive. Replace the hard drive and then perform a new installation of Windows XP.
Jan 17, 2009 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
787 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
