Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
No spark on new engine - Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
  • 17,130 Answers
Check on the impulse to the coil , if hti is absent there will not be any spark, so a loos of the trigger voltage to the coil must be checked... the coidl must get the posiitve voltage and the trigger voltage on the other side to produce the HT.
Posted on Sep 28, 2010
After I drive in water my engine come hot an dies
You probably need new spark plug wires with new boots.
Sounds like water is splashing up thru the wheel wells and spraying on the engine (which makes the engine steam) and the moisture sometimes makes the spark ground out especially if the engine is dirty and the spark can leave the wire more easily and ground out on the engine block etc.
Spark wires eventually get overheated and their resistance goes up so your spark plugs end up getting less spark strength.
Feb 25, 2015 | Cars & Trucks
Hyosung ms3 250 battery fully charged engine turns over wont fire up also new spark plug fitted
has spark? has fuel going to carb? if you smell gas from the muffler or carb then it not burning check for spark pull plug touch away from the hole so you don't ignite the vapors on the engine look for a great blue red spark
Feb 24, 2013 | 2009 Hyosung MS3 250
My car is not starting and i put a new distributor and new control modular a new coil pack new spark plugs and wires and pvc
Was the reason for the new parts the engine had no spark ?
Is the coil and control module getting power from the key switch ?
Are you getting spark to the plugs now ? Is the engine getting fuel ?
And what is the year model and engine size ?
Jul 24, 2012 | Oldsmobile Delta 88 Cars & Trucks
There is no spark thus car won't start. the battery is fine, it turns over good, it is not flooded, the spark plugs are new, the ignition coil was just replaced, what else controls the spark
The Crankshaft Position Sensor and the Ignition Control Module also control the spark. It depends on whether your vehicle is equipped with the 2.2L engine or the 2.4L engine as to where these components are located and what they look like.
Jan 29, 2011 | 1996 Chevrolet Cavalier
How to replace spark plugs in a kia sorento
The 2006 KIA Sorento is a smaller SUV with a 3.5-liter V6 engine. This engine uses six spark plugs to run the engine properly. There will be three spark plugs on each side of the engine. All six spark plugs will need to be changed at the same time to ensure that all six are working equally. The spark plugs are in plain sight on the right and left side of the engine and have rubber wires connected to the top of each one.
  1. 1 Insert the edge of the spark-plug gapping tool under the meal arm in the center of the one of the new spark plugs and turn the gapper until the number .038 is in the center of the metal arm. Repeat this for all other new spark plugs.
  2. 2 Open the hood of the 2006 KIA Sorento and remove a rubber wire from one of the spark plugs. Use the ratchet and spark-plug socket to remove that spark plug from the engine.
  3. 3 Insert the new spark plug into the hole where the old plug was. Hand-tighten the new spark plug until you are certain it is seated properly, then tighten it further using the ratchet and spark-plug socket. Replace the rubber wire to the top of the new spark plug.
  4. 4 Repeat for all other new spark plugs. Once you have replaced all six spark plugs and replace the rubber wires to the tops of them, close the hood.
Jan 21, 2011 | 2006 Kia Sorento
Won't start new engine no spark
If it turns over fine, check the crankshaft position sensor, and wiring. I have had two no sparks after swapping engines, and it was the crankshaft position sensor.
May 01, 2010 | 1996 Chevrolet Suburban
I have a 98 grand am blew a head gasket, ive had the heads reworked and new gaskets now the car doesn't start, just turns over. what could be the problem?
Check if you have spark at the spark plug. Go buy yourself one plug. Take any plug wire off plug in engine. Attach plug wire to new plug and touch a ground on engine with new plug threaded side. Have someone start engine and watch for spark. If spark exsist, look for fuel problem.
Mar 01, 2010 | 1998 Pontiac Grand Am
Change sparks plugs on 06 hyundai sonata v6
You didn't specify whether you have the (4) cylinder or the (6) cylinder engine..... I have a 2004 Hyundai Sonata 2.4L 4 cylinder and I just changed the spark plugs in it. I believe that the 2005 2.4L engine is the same. To locate and change the (4) spark plugs on a 2004 Hyundai 2.4L 4 cylinder engine: Remove the (4) 12mm bolts from the decorative plastic engine cover. Remove plastic cover from engine and place it off to the side out of your way. Standing in front of the car, the (4) spark plugs are located laterally (left to right) in the recessed area underneath where the plastic engine cover was removed. Note: This engine has (2) coils....They are located above spark plugs number (2) and (3) from left to right. Starting with the fist spark plug on the left: Remove the spark plug cable by pulling straight up on the insulated connector. Using a spark plug socket, remove the old spark plug and install a new one in it's place. To access the second spark plug from the left, remove the electrical connector and the spark plug cable wire from coil number (1) and then remove the (2) 12mm bolts that secure the coil to the engine. Spark plug number (2) is located directly under the coil. Lift the coil straight up removing the insulated connector from spark plug number (2). Using a spark plug socket, remove old spark and install a new one in it's place. Repeat same procedures for spark plugs number (3) and (4). Note: If you have the (6) cylinder engine, the front (3) sparks pluge are readilly accessible but in order to access the (3) rear spark plugs, you will have to remove the intake manifold
Jul 08, 2009 | 2006 Hyundai Sonata
Cant find the spark plug location on 2002 4cyl tacoma
Locate the spark plug cover on the engine.On some Toyota Tacoma engines, the cover is across the top of the engine. On others, it is along the side 4 cyl. Remove the cover to reveal the ignition coils and spark plugs wires. The spark plug wires are plugged directly into the engine and the ignition coils are in the tip of the spark plug wire.
Remove the coil and wire from the spark plug. Twist and pull the plug out of the engine. Remove the spark plug from the cylinder well with a socket extender and socket wrench. Turn the wrench to the left to unscrew the spark plug from the engine.
Discard the old spark plug and apply a coat of anti-seize compound to the threads of the new spark plug.
Insert the new spark plug into the socket. Use the socket and extension to screw the spark plug into place.
Return the ignition coils and spark plug wires to the engine and turn it to lock the plug in place. Repeat the entire the process with the remaining spark plugs.
Replace the spark plug cover when all of the spark plugs are replaced.
Good luck and hope this helps and The spark plug tension may range between 11 and 15 foot pounds, depending on the size of the spark plug. The correct tension is indicated on the spark plug's packaging.
Apr 19, 2009 | Toyota Tacoma Cars & Trucks
I can't find the spark plugs in my 2005 sonata
Note: If you have the (6) cylinder engine, the front (3) sparks pluge are readilly accessible but in order to access the (3) rear spark plugs, you will have to remove the intake manifold.
please rate!
Mar 18, 2009 | 2006 Hyundai Sonata
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
79 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
