Question about HP Compaq nx6125 Notebook
Volume buttons screen display
My laptop recently crashed and since I reinstalled everything, the external volume up and volume down buttons now give an on-screen display when I use them. This is irritation when running full-screen applications. Is there any way I can remove this on-screen volume display when pressing these buttons?
  • 101 Answers
Hi uninstall the application software for OSD from add/remove software .
Posted on May 24, 2008
All i get is screen save display?
It seems you need to reset your phone.
If your HTC HD2 is frozen and a soft reset doesn't work, this guide shows how to restore your handset to its factory settings with a hard reset
There are two ways you can perform a hard reset on your HTC HD2. The first is best if your phone is still operational. If it has crashed and you can't get a response from it, you're better to try option two.
Performing a factory reset via the settings menu
  1. On the Home screen's Settings tab, select Menu - All Settings - System - Clear Storage
  2. Enter 1234 and tap Yes to confirm
Performing a factory reset using phone buttons
  1. If your phone has crashed and won't respond, you'll have to perform a battery pull to power the phone off. Simply take off the back cover and remove the battery. Otherwise, just turn your HTC HD2 off using the power button.
  2. With your phone powered off, press and hold the volume up and volume down buttons
  3. While holding the volume buttons, press the power button and then release it
  4. When you see a warning message on screen, release the volume up and volume down buttons
  5. Press the volume up button to perform the reset when prompted, or press any other button to cancel the reset
How to reboot the HTC HD2 with hard reset
Mar 31, 2014 | HTC HD2 T8585
My volume display stays on
The Tv needs to be serviced by a technician.Probably there is a problem with the circuits inside.
Apr 12, 2008 | Televison & Video
Reset tablet
Hello,In order to hard reset your tablet, the steps given below must be followed:
  • Ensure that the tablet is powered off.
  • Press the Power and the Volume Up button together till the device displays the start-up logo.
  • Once the logo is displayed, release the buttons and wait till the device enters the Android system recovery mode.
  • On the displayed screen, use Volume Down button to go to the wipe data/factory reset option (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
  • Once the option is highlighted, press the Power button to select the option. (Pressing the Power button in Android system recovery mode selects the highlighted option.)
  • On the next screen, press the Volume Down button multiple times till the Yes -- delete all user data option is highlighted.
  • Press the Power button to hard reset the Samsung tablet device while clearing the dalvik cache along with the process.
Hope this helps..
Jan 12, 2014 | Computers & Internet
Users manual for Nobis NB09 tablet
I had same problem with mine found out to do a hard reset. Make sure power is turned off. Then while holding volume down button hold power button at same time until you get factory reset screen. Use Volume up/down button to navigate and use power button to select option. You will lose everything as it is a factory reset, but know way around this, that I am aware of. Hope this Helps and Good Luck.
Dec 19, 2013 | Computers & Internet
Hard reset motorola atrix dual core smartphone
  1. Power off the phone.
    NOTE: If unable to power off, remove and reinsert the battery.
  2. Press and hold the Volume Up + Volume Down and the Power button.
  3. The screen displays Boot Mode Selection Menu; press volume down key to cycle through choices until Android Recovery is viewed. Press the Volume Up key to boot in this mode.
  4. Wait for the triangle ! / Android screen to display, then proceed to step 5.
  5. Press both Volume up and Volume down key simultaneously. A recovery menu displays.
  6. Tap on Volume Down key until Wipe data/factory reset is highlighted, and tap the Power button.
  7. Another confirmation screen displays. Tap the Volume Down key until Yes displays, then tap the Power button.
  8. After user data is cleared, the reboot system now option is highlighted by default. Tap the Power button.
  9. The phone reboots to the initial setup screen.
Wireless
Nov 23, 2013 | Motorola Mobility Nice Atrix 2 4g Hd At&t...
I put a password on my android tablet and now i dont remember the password
Make sure you backup your files by connecting it to a PC (if you have access to one) via USB cable,you will have to do a hard reset, otherwise there is no other way to get past the lockscreen (unless you have a recovery option with your email address)
Below is the process to tell you how you can hard reset your Samsung tablet (should work with any tablet):
  • Ensure that the Samsung tablet is powered off.
  • Once the option is highlighted, press the Power button to select the option. (Pressing the Powerbutton in Android system recovery mode selects the highlighted option.)
  • Once your device is hard reset and rebooted successfully, you will see that the unlock pattern obstruction is also gone, and you can now set a new unlock pattern on your Samsung tablet.
Oct 21, 2013 | Tablets & eReaders
I need to reprogram my phone and delete all of my prior information off of it.
Force reset.
From the home screen, hit the menu button.
Select "Settings"
Select "SD & Phone Storage"
Select "Factory Data Reset" and confirm. This WILL DELETE EVERYTHING OFF THE PHONE(not the SD card) AND RETURN THE PHONE TO HOW IT WAS WHEN TAKEN OUT OF THE BOX!! THERE IS NO UNDO!
Hope this helped
Feb 24, 2011 | HTC EVO 4G Smartphone
Recently i formatted my laptop (Dell latitude c400). i installed fresh copy of windows XP. i finished the installation but when i open it again after i turned it off, i think it crashed (i hear the start...
You would probly want to completely reformat and reinstall your copy of XP, if it is already crashing on a fresh copy, it most likely didn't install correctly. Make sure you format first. You can do this before you run your installation. Reboot your computer and hit f8, select the option that says command prompt with networking. when the screen comes up with the C: type in there vol you will need the volume label to format, it will display this for you and make a note of it. At the next C: type in there C: format it will ask you to enter the volume label, do this and hit enter. It will then ask you if you are sure you want to delete all data, type y and hit enter. It will go through the format process. Enter your XP cd into the drive and reboot your computer, you should now be able to reinstall windows with no previous errors or versions already installed. Hope this helps!
Lori
Oct 13, 2010 | Dell Latitude C400 Notebook
External Volume/Mute Button not working
You will get a better response if you pay for the expertise we have to offer!
Jun 05, 2008 | JVC XV841 Notebook
Volume level display
it sounds like your laptop drivers aren't working properly.. possibly the program dealing with your sound volume is corrupted or missing.
I'd try reinstalling your keyboard/touchpad drivers. what is the make and model # of your laptop?
Dec 28, 2007 | Lenovo ThinkPad R60 with Wireless Wide...
HP Compaq nx6125 Notebook Logo
122 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
