Question about HP Officejet J4680 InkJet Printer
Put in new cartridges now can't get to scan? - HP Officejet J4680 InkJet Printer
  • HP Master
  • 17,130 Answers
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Posted on Sep 28, 2010
  • HP Master
  • 1,679 Answers
Remove the Cartridges and clean the Electrical contacts ( golden points ) on the cartridges
Power off the Printer
If possible clean the contact inside the printer cartridge slot with cue tip.
Power on the printer and reinsert the cartridges.
It should print the alignment sheet.
Place the alignment sheet face down on the Scanner bed and press OK button on printer front panel.
If this does not work, Press the Setup button ( Ranch like symbol )
Scroll down to TOOLS - Press OK
Choose Align Cartridge/Printer - Press OK
I just put in new ink cartridges. It scans fine but will not print from my computer
Hi Karen:
If it worked before you installed this cartridge, there are 3 possibles that I would check.
1) The new cartridge is defective
2) The new cartridge is not installed correctly
3) The pull tab that covers the ink ports was not removed before the cartridge was installed.
Dec 27, 2015 | Office Equipment & Supplies
Need to know how to change printer ink
Do not touch the electrical contacts or print head nozzles on the Cartridge. The machine may not print properly if you touch it.
1. Make sure that the power is turned on, and open the Paper Output Tray.
2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support (C).
genebur2_1.jpg 3. Pinch the tabs and open the Ink Cartridge Locking Cover.
4. Remove the Cartridge.
genebur2_2.jpg 5. Take a new Cartridge out of its package and remove the orange protective tape gently
6. Put a new Cartridge in the Cartridge Holder.(The Color Cartridge should be installed into the left slot and the Black Cartridge should be into the right slot.)
7. Close the Ink Cartridge Locking Cover to lock the Cartridge into place.
8. Push down the Ink Cartridge Locking Cover until it clicks.
Nov 08, 2010 | Canon PIXMA MP240 All-In-One InkJet...
How do I load the ink cartridges into the Canon Pixma printer MX320?
2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support on the right side.
The FINE Cartridge Holder moves to the replacement position.
3. FINE Cartridge.
(1) Pinch the tabs and open the Ink Cartridge Locking Cover.
(2) Remove the FINE Cartridge.
4. Prepare the new FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape gently.
5. Install the FINE Cartridge.
(1) Put a new FINE Cartridge in the FINE Cartridge Holder.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be into the right slot.
(2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
(3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
(E) Closed correctly
(F) Not closed correctly (the cover is tilted)
6. Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support back to its original position, and gently close the Scanning Unit (Cover).
Oct 05, 2010 | Canon Office Equipment & Supplies
Changed printer cartridge now wont scan printed sheet!Thanks,DV
Every time you put a new cartridge, the printer does a test page. That is because it is aligning your cartridge. Now what you need to do is take that test page and put it in your scanner as indicated on the test page. Then press "scan" on your printer. The printer should then do a scanner alignment and you should be able to scan. If you do not have that test page, print another one. Go to start, settings, find printers and faxes and open it. You will see your printer. Right click on the printer and you will see a menu. Open Properties. Find General- there is a "print test page" button. Click on it.
Apr 04, 2010 | HP PSC 1410v All-in-One Printer
Alignment of cartridges
To align the cartridge from the control panel:
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
Apr 17, 2009 | Lexmark All-in-One Printer with PictBridge
White vertical lines in copy of photos onto plain paper. I have gone through nozzle cleaning, resetting print quality, etc. I installed a new color cartridge before encountering these problems. Copies...
I would put the old cartridge back in if you can and do a test scan, the cartdridge you put in may be at fault, the trick is to duplicate the problem and solution, if nothing else take the new cartridge back and get another.
Dec 11, 2008 | Lexmark Office Equipment & Supplies
Canon multipass 390
alarm is flashing and flashing put in cartridge even though I've put in both black and color new cartridges and reset both still won't print
Mar 25, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
HP Officejet J4680 InkJet Printer Logo
37 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
