Question about HP Computers & Internet
My system cooling fan is not functioning propery, if it gets too hot the system will shut down on its own.
  • HP Master
  • 17,130 Answers
The filter to the cooling fans can be clogged more if you had been using it on a bed as the fabric will be sucked into. So remove and check the fan where you can see it blocked and so the heat goes up in the processor shuting if off.
Posted on Sep 28, 2010
  • 97 Answers
Replace your cooling fan
My acer gets hot. the fan quit working i think. when it is hot it freezes and you have to turn it off, let it cool then turn it on. you lose the document you are creating. How can i stop it from freezing...
while the computer is off use compress air and spray it into the ventilation area where the fan is that stopped working. hopefully this will free the dust to hopefully get the fan to start moving again.
If the compressed air does not work, you will have to replace the fan.
Mar 05, 2011 | Acer Aspire 4315 Notebook
MY LAPTOP BECOMES EXCESSIVLY HOT AND CUTS OUT. ITS SITTING ON 2 USB FANS YET THIS MAKES LITTLE DIFFERENCE TO THE OVERHEATING. IN ADDITION TO THIS IT FREEZES AND THE ONLY WAY TO CORRECT IT IS TO HOLD THE...
Hi. Your laptop is experiencing overheating issues. This happens when the built in fans no longer have a functioning airflow. Collected dust may be closing the air vents and that is why even the laptop coolant do little help. I would recommend bringing you laptop to a local tech to have it cleaned including testing of internal parts. Thanks.
Feb 16, 2011 | Computers & Internet
When i am ueing the lop top it get hot and shut down i have to wait antill it cool down before it start up again
it sounds like your cooling fan has stopped working therefore the cpu is getting too hot to work and will shut the system down have the cooling fan looked at
Oct 29, 2010 | Compaq Presario CQ60-220US PC Laptop
Is there a thermostat shut off switch . car runs
The amount that it gets hot is a clue but theres no shut off switch. It's possible that the car is over heating and the temp gauge does'nt have enought water over it to report the problem. once the cooling system is cleared as it's full circulating and the fan will come on when it's hot ( disconnect the temp. switch on the therostate cover on the top of the transmission, ( the stat is in the lower hose ) with it disconnected and the key on the fan should be on and connected f till it's real hot. The crank senser or distrubutor module can can too hot and shut down too
May 13, 2010 | 1997 Toyota Corolla
Cooling fans in op until engine is shut down . At idle, in traffic, temp gets high, hen wmoving, temp goes back to normal. When I shut down the engine the fans start to run as they are supposed to when the...
Check out clarks-garage.com he has a complete troubleshooting guide for your cooling system along with a schematic. In short, check the low speed resistor on the firewall. Should be around one ohm.
Oct 10, 2009 | 1985 Porsche 944
My Toshiba laptop TECRA A9 shuts down on second attempt only, not the first time. What can I do?
Hi..
Laptop shuts down? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning. Hot spot, fan always runs? Many laptop brands and models have characteristic hot spots, like a particular corner of the keyboard or over the battery compartment. Before proceeding with the more invasive cleaning techniques that involve opening up the laptop (and potentially breaking something), spend some time searching the web for user feedback on your make and model. The bothersome hot spot on your laptop that none of your friends or colleagues have ever hear of may be a characteristic issue with your particular model and not worth a major panic.Similarly, if the fan always runs, or almost always runs, it may be a characteristic of the particular model that it simply gets hot in normal operation, or the fan control software might be poorly conceived. As long as the laptop isn’t overheating, I’d probably learn to live with a fan that seems to run too much if it’s typical for the model, and only get worried when I don’t hear it anymore.
Regards
PCmania
Aug 15, 2009 | Toshiba Tecra A9-S9021V Notebook
My cpu shot down evry more aften
try to check the fan in your processor maybe if didn't function that is why your processer got to hot and shut down it self or try to check  the connector inside your System UNIT. Then if the same proble occurs try to find a technician to check the current status of your Unit.
Jun 19, 2009 | Computers & Internet
Emachines T2958 overheating and shutting down
Your computer is automatically shutting down to prevent damage to the CPU because it is getting too hot. This can be caused due to a malfunction fan, heatsink, or dirt inside the CPU.
Remove the side cover of the CPU. Using a can of air (which can be purchased at most electronics departments), blow out any dust inside the case, paying specific attention to the fan and the heatsink mounting the CPU. Also blow out all vents and anywhere else you see dust. Do not shake the can of air and keep it as level as possible. If you do not have a can of air available, an air compressor will work. Alternatively, you may vacuum the dust up with the hose of a vacuum cleaner but do not use any attachment with brushes on it.
If the inside is relatively dust free, check to make sure all the fans are functioning properly. If the one on the CPU is not, then that fan will have to be replaced.
And one more thing, please give this solution a fixya rating. Thanks! :c)
Dec 27, 2008 | HP (158800-001) for Compaq Presario 1246,...
Cooling system
Computer hardware related downloads Operating System:, Windows 95, Windows 98. Description:, CPUCooL is a multifunctional utility: 1) Cooling the CPU under Windows 95 / 98.
Read instructions, Good Luck, Please dont for get to Vote/Thank You.
Dec 23, 2007 | Toshiba Satellite A25-S3072 Notebook
Computers & Internet Logo
113 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
