Question about Kitchen Ranges
The compressor is not running and cooling level was down to the minimum
  • Kitchen Ranges Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 28, 2010
Does not cool either side fan runs and compressor seems to run
2 possible issues. If compressor running, but not cooling - No freon in the system, or compressor valves are bad, not compressing freon. Ideal would be to check pressures on the system while its running. Could be some kind of restriction. most common problem i would guess low freon level. Here are 2 of my videos i have on my channel. first is leak found at evaporator coils. i used leak dye to find it, second video is replacing compressor, but had compressor completely down. installed 3-n-1 hard start kit, but compressor did not come on, so replaced compressor with filter drier. Hope this will give you an idea what to do next.
Aug 19, 2011 | Maytag MZD2766GES Side by Side...
The Cool mode wont cool. It's just like fan mode. I cleaned all the dust off the panels and still wont blow cool air.
First the weather is extremely hot mid 90's and humid.I have a Trane combination a/c heat pump system. The A/C was pumping out warm air.I called for a technician and the problem was the compressor was not working.The solution/fix was to replace compressor start capacitor.The technician was here for about an hour.The compressor was running before he left however I informed him the air coming out of the a/c ducts after one hour of run time did not feel as cool as usual. It took from 1pm until 10 pm at night to cool the house air down to 80 degrees and the system ran constantly.I left it on 80 as that is where I usually leave it. Today again it is running all day barely able to keep the house at 80.My home was built in 07 block house, well insulated with thermal double pane insulated windows.I suggested to the tech to check the refrigerant level but he did not think it necessary and did not perform the check while here. The unit will cool the house down to 80 degrees but runs constantly.My question is: Should I have a technician come check out the system to insure proper refrigerant levels and pressure????????
Jul 30, 2011 | Haier HWR06XC6 Wall/Window Air Conditioner
I have a ATLAS COPCO GA 160 w at my work and it is shutting down on high element temprature. I noticed that the oil level in the seperator is low and have topped it up a few times but everytime i run it...
Without more info or knowing your compressor my first question to you is,is the oil cooler clean and does the unit have good water flow. DO you have good water flow / pressure. The oil level should be about half way the sight glass running loaded. If the oil level was low ,when the thermostat opens it allows oil to flow to the cooler which lowers the oil level.Typical problems during this time of year are , , dirty oil cooler, Faulty thermostat, Faulty element temperature sensor, Low oil levels and bad oil. Also dirty oil filters restrict oil flow and can cause high element temp. problems. Try back flushing the water side of the oil cooler. Have you checked to make sure the water solenoid is opening. May have a bad coil or valve. May also have water solenoid plugged with something. What is the cooling water inlet temp and outlet temp. The W usually indicates water cooled. If not water cooled, most of the above also applies to air cooled units. just replace water with air if it fits.
Jun 28, 2011 | Air Tools & Compressors
Our LG Art cool Airconditioner displays the error code CH 21. The unit turns on BUT after about 5 minutes the unit turns its self off. Please Help
Inverter compressor run current high. Check compressor windings all equal 1 to 4 OhmsCheck to earth 50 MOhm minimum, check run current. If high, winding is weak. Solution: Replace compressor.
Jan 11, 2011 | LG LSC183VMA Split System Air Conditioner
Our model is the ART30RLA ducted airconditioner and we are having problems with it. The problem is that it will not cool down, everything is running but it won't get cool. Could you please help us with...
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 04, 2011 | Fujitsu Heating & Cooling
C6 error
Inverter compressor run current high. Check compressor windings all equal 1 to 4 Ohms, Check to earth 50 MOhm minimum, check run current
Feb 21, 2010 | LG Art Cool LA121HNP Split System Air...
My air conditioner will kick on but will stay on and not
The thermostat is not functional, therefore its not cutting off the compressor once the room air gets cooled to the temp setting of the thermostat, also the refrigerant gas may have leaked out some but not the entire refrigerant gas(freon, CF4, etc.), keeping the compressor running contentiously to come down to the set temp..............sodeep
Aug 20, 2009 | Carrier 38CKC042 Air Conditioner
When shutting down the compressor, oil comes out intake filter
hi there,
well,if your air compressor was shut off this due to pressure switch w/c auto switch off your compressor,the pressure switch acquired already the cut off pressure.if the pressure goes down the cut in set up reached it will start your compressor
to run.
regarding oil spillage when shutting down check the oil level on the sight glass of crankcase
a red line indicate oil should not exceed on that level line,if the oil exceed try to drain oil.,on the side bottom of engine there is a drain plug.until on limit level .,besure that machine is shut off/breaker is off.have a nice day don't forget to rate me,thank's
Apr 28, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Does not cool
first off, any time you lay a refrig down you should have it remain standing up for a minimum of 24 hrs forthe compressor oils to return to the copresssor, unplug and allow to rest for allotted time try again tommorw morn.
Jan 14, 2009 | Whirlpool Refrigerators
Kitchen Ranges Logo
48 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
