Asko Front loader washing Machine W6551 stopped working - message Fault indication Wash motor fault Smells like burning wires
  • 10,515 Answers
This is not a good news. This is an indication of an internal failure. If the pump has blocked and the thermal overload has gone open circuit, just remove the blockage from the pump, the module and the pump should still be okay.
If the pump windings are water damaged, the pump will quickly overheat and cut off again. The pump must be replaced in this case. The electronics should still be okay.
However, on most cases, this error message indicates Faulty pump or a faulty pump and board.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 28, 2010
Error message: Thermistor Fault
yes it is serious as it indicates an over heating condition probably on the motor or control panel
May 17, 2015 | Asko W6761 Front Load Washer
What does a F6 error message indicate?
"F6" Motor fault · Check wiring to motor · Replace motor if necessary
Oct 12, 2011 | Asko W6461 Front Load Washer
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
Jun 21, 2011 | Samsung Washing Machines
Replace drum bearing ... in a ASKO W6551 step by step
you need to remove the drum start at the front remove front panel,four screws 2 under front,1 behind soap drawer and the one near the filter,next take door off 4 spring clips on the next panel plus screw on door lock,remove door lock,then undo clamp band,bolt at bottom and remove counter weight panel (heavy).remove stainless steel inner panel,use a screwdriver to loosen,from the back remove drum pulley.the drum will then pull out.replace vseal and bearings.hope this helps
Jun 05, 2010 | Asko WL6511W Front Load Washer
Smells like electrical burning
as the main motor in the machine is the one that does the work it is obvious to check this 1st it could be that th e motor brushes need replacing if this is the case use without brush replacement will damage the motor quite a simple job seek an engineer if not compedent
Jan 15, 2010 | Asko WCAM1812 Front Load Washer / Dryer
Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Mar 10, 2009 | Asko W640
Machine wont stop filling with water, it just overflows. Machine is an Asko w6551 front loader
Same thing happened to my ASKO W600.  Sounds like the water inlet valve is blocked or broken so therefore can't stop the flow of water coming into machine.  Check it out and replace if necessary.
Oct 30, 2008 | Asko Washing Machines
Fault indication: water inlet fault
see if there is a blockage in the level switch. the switch operates on air pressure within the dip tube and the diaphragm in the switch. there may be a spider's nest in the tube or a wasp's nest in the tube.
Feb 03, 2008 | Asko W640
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
