Question about Euro-Pro Kitchen Ranges
I have a Euro-Kitchen 218 Series "Spagna Vetro" exhaust fan with four 35w halogen lights and two electronic dimming controls. Well, the lights all stopped working, although the control panel shows the lights going on and off at the switch. If it is a transformer, how hard is it to replace? Would there be any benefit to the 300 watt transformer instead of the 150 watt? Thanks in advance for all your wonderful comments.
  • D W Sep 28, 2010
    There are two separate controls, one on each side. Pressing either light switch turns on the image of the light, and then turns it off again. Other posted comments on range hood lights referred to the transformer. What makes you think it is the switch(es)? What info can I get regarding their replacement?
  • D W Sep 28, 2010
    The first expert has neither brand nor range hood expertise. Other folks with similar range hood lighting problems, indicated "thanks" for pinpointing a transformer problem. Given that the fan works and the 2 separate light switches can turn the separate light symbol on and off, is this definitely a switch problem? I need more substance to substantiate my next step.
    Thanks in advance for your help,
    DW
  • 12,061 Answers
Hi, well a dimming control usually simply works by controlling the Voltage to the bulbs, by electronically controlling them. Usually any problems with these type of circuits, usually is the Dimmer itself, replacement is the only real option. You need to check if there is actually any voltage output from these dimmers, in the first place. I think you will find though, that there will be none. No doubt there will be an input, to the primary side of the transformer, But there will be NO output, measure the output with an AC voltmeter, and with the bulbs disconnected, you may indeed find, that there is some voltage UNLOADED, however this will disappear when the Bulb is replaced, into the circuit. This then indicate that the Dimmer is indeed faulty, we usually simply replace them, "on spec", as we say...
Of course check all connections and any switches too.
I doubt it would be the transformer, although this too must be checked.
There would be no real benefit in upgrading the transformer, as it is already quite "Overspeced" to begin with, but in saying that it will do no harm either.
A Dimmer "How To" below link.
http://www.epanorama.net/documents/lights/lightdimmer.html
Posted on Sep 28, 2010
  • 2,973 Answers
DW, It is not the transformer. It could be the dimming controls. Also, instead of using a bigger transformer go in for CFL bulbs and reduce the load on the transformer. And contribute towards efforts to reduce global warming by using less electricity.
  • thomas Nov 27, 2011
    you can't dim CFL. Try diods instead.
I have spagna vetro 36" stainless steel range hood 198B2-36 and I would like to replace the lights with LED - 120v my problem is; I can not find a vendor with this size lights.
!2VDc or 12VAc? If Dc check for a loose, corroded or greasy ground connection. Also check the center pin on the light sockets, they get flattened and coated, a good cleaning may solve your issues.
Sep 01, 2014 | Kitchen Ranges
Replace halogen bulb
Please see my answer at http://www.fixya.com/support/t9977585-sv168n_36_spagna. I suspect your problem is with a failed transformer, rather than the actual halogen fixtures.
Oct 29, 2013 | Euro-Kitchen SPAGNA VETRO 198D-36...
Euro spagna vetro series 218 light not working
Please see my reply at http://www.fixya.com/support/t9977585-sv168n_36_spagna. I think you may have a failed transformer.
Oct 09, 2013 | Euro-Kitchen SPAGNA VETRO 198D-36...
Replace transformer in a hood ventilation for euro fans
Please see my reply at http://www.fixya.com/support/t9977585-sv168n_36_spagna. I just replaced a failed transformer in a similar model.
Jan 06, 2013 | Euro-Kitchen SPAGNA VETRO 198D-36...
Dim head lamp in herohonda cd 100 ss
over my consideration actually dim light caused by the holder and lower battery supply.if any how any changes on holder and battery can b made,then d problem may can b fixed
Apr 04, 2012 | Motorcycles
We have a SV168n-36 Spagna Vetro Range Hood and it works well but the lights are having problems now. They only come on intermittently and when they do come on once they heat up they shut back off.
I had the exact same problem with my Spagna Vetro hood. The fan worked fine, but the lights started working intermittently and then stopped working altogether. The problem in my case was a failed transformer, which sits between the power switch and the lights and is necessary to step-down the voltage from conventional 120v to 12v to support the halogen bulbs in the unit. Although there are several steps to resolving the problem (replacing the transformer), it's really not difficult. Here's what I did to solve the problem:
1) Shut off the circuit at the breaker (always very important :^) )
2) Removed the glass arch from the top of the hood. Four screws hold it in place and are accessed from above the unit.
3) Removed the access panel above the fan and light switches. This panel is visible underneath the glass arch, when the glass arch is removed. I slid the lower section of the decorative stainless chimney cover upward to gain complete access to the back two screws of this panel.
4) I unplugged the original transformer from the light on/off switch (connected with two yellow wires on my unit). Remove the wire-nuts and disconnect the 12v leads from black and white wires that connect the transformer to the halogen bulb fixtures.
5) Using a flat-head screwdriver, I pried the transformer off the metal surface to which it was adhered with double-stick tape. This was strongly adhered and took a bit of prying.
6) Found a replacement step-down electronic transformer at the hardware store. My hood takes only two 10 to 20 watt bulbs, so only a small transformer is required. The original one I removed was rated to 70 watts max. I replaced it with a transformer rated to 60 watts max. Either was more than sufficient to cover the 20 watt load produced by my two 10 watt bulbs. Cost of the replacement was about $15.
7) Connected the replacement transformer to the hood power switch. Here, I had to be a little careful to maintain the original polarity of the wires from the switch. This is because the original transformer, though it had one white and one black wire on its 120v side, was attached to the switch via two identical-looking yellow wires, using a non-standard plastic connector. The new transformer did not have one of these connectors on its 120v input wires (black and white), and I wanted to make sure that the I wired the replacement exactly as the original had been wired. Fortunately, the original plastic connector ensured a consistent polarity. When I looked at the end of the connector, one lead was square and one lead was round and noted that the square lead had been attached to the White wire on the original transformer. The replacement transformer also had a white and black wire for its 120v side. So, I marked the yellow wire from switch that attached to the white wire through the square lead. Then, I cut off the plastic connector from the yellow wires, stripped the sheathing from them about 1/4 inch, and attached the white wire from the new transformer to the previously marked yellow wire, using a small wire nut. I then connected the black wire from the transformer to the remaining yellow wire in the same way.
8) On the 12v side of the transformer, the wires are the same color and I did not pay close attention to polarity, simply connecting each to the spliced wires leading to the halogen bulbs (that I exposed when I removed the wire nuts from them in step 4, above) using fresh wire nuts.
9) The double-stick tape that attached the original transformer to the hood remained firmly attached to the metal surface of the hood and it was still very tacky on the surface that had been attached to the original transformer. So, after I tidied up the wires in the space, I positioned the new transformer over the tape and pressed it down firmly, which seemed to adhere the new transformer to the hood pretty well.
10) With the connections completed, and power restored to the circuit at the breaker, the lights worked fine, and the fan continued to work fine. I reversed the steps I used to expose the switch and transformer.
So that's all there was to it. The cost of parts was about $20 for the transformer and a bag of wire nuts. Investigating the problem probably took more time than the actual repair, which took about 20 minutes from start to finish.
Aug 03, 2011 | Euro-Kitchen SPAGNA VETRO 198D-36...
I have a Cavaliere 218 range hood and the lights don't come on. Lamp button illuminates, but no lights come on. Bulbs are good.
We have a Cavalier range hood as well that the two halogen lights stopped working. Bulbs were good and the light switch illuminated. I ended up ordering and replacing the transformer and it works great:
https://www.lightsonrus.com/store/products/Hatch-RS12%252d80M-(RS)-Series-Electronic-Transformer-80Watts.html
Dec 30, 2009 | Kitchen Ranges
How many dimmers types?
Certain dimmers can control standard incandescent lamps that use 120 volts while other dimmers can control low voltage xenon or halogen light sources that use 12 or 24 volts.
Aug 27, 2008 | Lutron Electronic Low-Voltage...
Electronic Display
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Feb 23, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
1,458 people viewed this question
Top Euro-Pro Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you an Euro-Pro Kitchen Range Expert? Answer questions, earn points and help others
