Question about Canon PowerShot A470 Digital Camera
My camera says, Lens error, restart camera. wondering where the reset button is if you could help me... Thank You
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 09, 2011
Canon powershot SD780 is camera. Camera shows the canon screen then turns black and beeps three times then says "lens error restart camera". I don't know how to restart...i need to use it I'm on a trip...
There's really no way to restart it if there's a physical problem with the lens. Try to power it on again but if that doesn't reset it, the camera needs to be serviced. A great site for help with these is: camerasandparts.com They just specialize in service for the Canon Powershots and nothing else, they are fantastic if you need help with one of these problems. Try them, your exact SD780 lens error restart camera problem is right on the site for the SD780. Good luck, that's the place for help with a powershot, it just sucks that it happened while you are on vacation.
Jun 22, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Lens error, restart camera.How can I restart the camera IXUS 60?
Since the camera is locked after lens error, you will restart camera removing batteries.
If this does not help, then you are in one of the following conditions:
Lens error and lens does not retract.
Try helping lens gently back in while you turn off the camera holding the button at same time.
Lens error and lens do not extend.
Restart the camera , and try gently tapping the camera back with the palm of your hand whilst restarting camera at same time.
If that does not help, then one part on the camera lens assembly is broken or out of place, or dirt inside lens mechanism caused the fault.
The lens must be disassembled by a technician to fix the problem.
If the problem is not fixed swapping batteries and resetting, then the camera must be taken apart and tested by a technician.
Here you can get a quote on repair: Repair
Aug 22, 2009 | Canon Cameras
Lens Error. Restart Camera. Camera gives this error message and then shuts off. I can't access photos or function buttons. What can I do?
Press the "MENU" button and navigate to the reset command and reset the camera. That may get the camera to function properly.
May 10, 2009 | Canon PowerShot SD1000 Digital Camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Canon SC100 Lens Error
I have a 3 year old Canon PowerShot SX100 IS. While testing an external battery power supply I built, the external power connector pulled out while the lens barrel was extending just after I turned on the camera. Power to the camera was lost before the lens barrel fully extended and wouldn't reset when I repowered the camera. The dreaded error message "Lens error, restart camera" appeared and the camera shut down. I restarted the camera over and over and over again but the lens wouldn't reset. I was extremely lucky to find the information here and read various fixes. I didn't want to take the camera apart so I tried various fixes others have successfully used. I first tried smacking the bottom of the camera hard with the palm of my hand just after pushing the on/off button but that didn't work. The one which worked was smacking the camera on the side immediately after I pushed the on/off button. I smacked it quite hard twice with the palm of my hand then, suddenly, the lens barrel began to move and the lens reset itself back to its starting position. Thanks to everyone who has posted here!
Apr 07, 2009 | Canon PowerShot SX100 IS Digital Camera
Lens error,restart camera
take your finger and slide it inside the lens and pull it out slightly, not all the way but enough that it moves. then hit the power button and it should work fine after that. good luck!
Nov 23, 2008 | Canon PowerShot SX100 IS Digital Camera
"lens error please restart camera"
Hello!!
Remove the batteries and keep pressed the power button for few seconds it will reset ur system!!
Oct 21, 2008 | Canon PowerShot A470 Digital Camera
Lens error!!!!
when i turn on my camera the lens comes out ,then goes back in saying theres a lens error.it tells me to restart my camera but im not sure how too. is it just turning it back on ,or is there a reset button?
Jul 03, 2008 | Canon PowerShot S5 IS Digital Camera
Canon PowerShot A470 Digital Camera Logo
160 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
