The tray is stuck inside of the player,but it dosen't come out
    Problem Solver:
  • 9 Answers
There Should be a Pin Hole infront of your optical Drive if you poke it with a needle long enough to push the gear, it should eject the tray. assuming something is stick inside, it may release what ever is stuck in there but if the issue still happens then probably the gears aren't working properly anymore and may need replacing the optical drive / player
This happend to me once, I opend my optical drive myself and found out that some of my gears are broken.
Posted on Sep 28, 2010
When I turn on my Sony DVP-SR200P DVD player and press the eject button it's turns the DVD player off.
turn on first the dvd player and wait to read a disc inside if no disc inside the tray it will say disc error. if the unit doesn't turn off, eject now the the cd tray. if get turn off, remove the cover then check for an stuck up gear or obstruction in the cd tray assembly. you can check also the power supply board which may have unusual parts like bulged or burnt component parts.
Oct 06, 2012 | Televison & Video
CD-72 Marantz CD Player disc tray is stuck in the shut position.
You might have to open the player and see why. remember to unplug till you need to see if you can get it to work or not.
Sep 06, 2012 | Audio Players & Recorders
DVD tray is stuck
If your DVD tray is stuck, that simply means there is a problem with the mechanism that is controlling the tray from the inside part of the player.
For you to fix this, get the appropriate screwdriver,
open the back cover of the player.
you will see a mechanism by the side of the opening and closing of the tray.
Carefully examine the mechanism, and you will detect what is faulty on the mechanism.
You can replace the faulty mechanism or better still replace the whole mechanism.
Ensure the disc tray is properly seated.
yest it with a DVD disc before you couple it back together.
Take care
Jun 18, 2010 | Televison & Video
Dvd is stuck inside and drawer will not open
Yes, it was a piece of the addhesive dot that was stuck to the back of the disk. I unplugged the unit (of course), removed the 10 screws holding the cover on the chassis and that exposed the disk in its tray. I could not manually open the tray still, but I was able to remove the tape dot from the disk while it was still in its tray. All is well now.
Dec 02, 2009 | Philips Televison & Video
Cannot insert disc
If the problem is with the tray of the player, there will be a small hole at the front panel near the tray. You just need to put a pin into that hole, the tray will come out if it is stuck inside.
Thanks
Aug 09, 2009 | Sony DVP-CX995V Multi-disc DVD Player
A DVD is stuck in my player. When I open the tray the dvd isn't in it. I can see the dvd inside the player but it will not drop on to the tray. HELP! ITS A RENTED DVD!
Try removing the top cover, very often if the DVD is not in the tray it will be accessible to retrieve once the cover is removed.
Aug 04, 2009 | Toshiba SD-2900 DVD Player
Denon DCM-280. Tray won't open, there are CDs in
If you don't wanna send it for service, open the chassis of the player and free the CDs from the tray. Its highly likely that the CDs came off the trays and got stuck inside.
Jul 31, 2009 | Denon DCM-280 5-Disc CD Changer
DVD stuck in player
make sure that the dvd is unplugged from the outlet and remove the screws of the cover, you should be able to access the dvd from inside the player without the cover on.
I hope this helps
Jun 28, 2009 | RCA DRC225N
Won't power up. Disk stuck inside. Can i open that tray to rescue my rental?
take a small flat head and pry the door open if not the only other way is to unscrew cover and manually push tray open
May 13, 2009 | Panasonic DVDS97S DVD Player
Open Questions:
Cloud storage and file storage - DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jul 20, 2018 | Quantum Computers & Internet
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
