THE AIR IS COLD BUT ONLY AT THE VENT FAN DOES NOT BLOW HIGH ENOUGH
  • Michael Youngman
    Michael Youngman Sep 28, 2010
    Do you have a centeral air conditioner or a wall unit. Let me know what you mean by "only cold at the vent but does not blow high enough". The more information I have, the better help I can give you!!
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 28, 2010
    Problem Solver:
  • 8 Answers
In central HVAC systems, the fan motors will sometimes have a dual motor speed. You may need the higher setting. If you are already at the higher setting, you may need a diverter in the system or bigger unit (more tonnage).
Why hot air dont blow out of vent?
Probably have a bad Door Airflow control box
Dec 04, 2016 | Toyota Cars & Trucks
What causes a Bradford White Gas Hot water heater to leak at the base of the vent fan?
Here are some general things to check:
1. Is the vent piping correctly sized?
2. Is the vent piping run too long? There are length limits depending on the heater for both vertical and horizontal runs.
3. Is there sufficient combustion air available? A very tight dwelling can cause a lack of adequate air supply for the combustion process.
4. Does the vent pipe run through a cold or otherwise unconditioned space on its way to the outside? The vent may need to be insulated (high temperature insulation only)
5. Is the vent fan working properly and stay on long enough?
6. Is the gas supply pressure ok and is the burner working properly?
Aug 12, 2015 | Refrigerators
Would high winds and rain cause pilot light on a rannai tankless water heater to go out?
Yes.
High winds can cause reversal of air flow down vent pipe causing pilot flame to blow out.
If situation happens frequently, then special roof cap has to be added.
Have plumber check natural draft up vent pipe.
Other things can cause same problem, for example if vent fan is located in same room as water heater, or house is tightly insulated, and vent fan is ON, then it will draw air down the water heater vent and blow out pilot.
http://waterheatertimer.org/pdf/Bosch_Checking_the_draft.pdf
Oct 29, 2012 | Water Heaters
My A/C used to blow out very cold and with lots of force at the vents, now I get cold air but you can barley feel the air coming out of the vents. The fan sound like it is on high but very little airflow....
It sounds like you have a blend door issue.Try cycling the air to blow on different parts of the cab ie: defrost,to floor to vent.if you have cold air blowing good on all selections and you know your motor is working on all speeds,then you have a blend door not opening.The control for that is behind the heater/ac control unit.They do go bad from time to time.You can pick up a replacement at either a dealer or a Auto Parts place that sells GM or AC DELCO parts.
Aug 23, 2011 | 2002 Chevrolet Silverado 2500HD
Acblows cold on passengerside but warmon driverside on1999 aurora
Check the vent plumbing under the dash with the fan on high. Just run your hand along the tubes and feel for moving air.
May 31, 2010 | 1999 Oldsmobile Aurora
Refrigerator is not cold
Hi Louis,
This is what has happened. Due to the door being opened for so long moisture which is naturally in the air has collected on your freezer coils. What you need to do is turn the whole thing off for at least 24 hours. Open the doors and put some towels around it to let the frost melt out.
All the air that gets cooled in your unit gets cooled by a fan that pulls air through those coils. Once the frost has melted out of them it should cool just fine.
May 25, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer is working correctly but fridge
hi there is a electronic vent that opens when cool air is needed and a fan ..to blow it up through channel.you need to find out if the fan is working first..open fridge door and push light switch in this should turn your fan on you should hear it hummmming. also put other hand were the vent is to fill if cold air coming through ..if not then you need to change vent assy. hope this helps,01179512835
Dec 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
