Question about RCA VR637HF VHS VCR
EVERYTHING WORKS EXCEPT WHEN I PLAY BACK ..ITS SNOWY
  • RCA Master
  • 5,309 Answers
The heads just need cleaning. I recomend Servisol Video 40 to do the job best and taking off the top cover for a good clean with it and some cotton buds on all surfaces where the tape touches.
Posted on Sep 28, 2010
(DESKTOP) My 42" lcd tv acts as both my monitor for my desktop and my cable tv. Everything is connected via hdmi except for my soundbar. After 5-10 of no use with my pc the tv goes snowy or shows n
if you have cable-TV then you have a Set-top-box and there should be a separate HDMI cable from that cable box to the TV, as well as an HDMI-cable from the PC to the TV.
This means that when you want to use as a monitor, the TV Input would have to be changed to PC, and when you watch TV, you need to change the Input back to Cable. It sounds like you are watching TV through the PC.
Oct 29, 2014 | Computers & Internet
Snowy picture
The remote doesn't effect the channels, I would say you have poor signal or interference from another device nearby.
Sep 12, 2008 | Orion1934 19" TV
The screen has went snowy and wont respond to the remote
Snowy screen, unresponsive to remote control... Sounds like an interference from something. An example... A hairdryer can mess up a CRT really bad. Anything that is likely to create small EMPs will surely mess up your TV and even interfere with the infra-red. Not marking this as a solution, check everything and test the TV. Here's the test: Turn everything off, except for the TV. If it's still doing it then the remote infra-red is just a coincidental failure with the snowy screen. Sorry I can't help you further.
Oct 16, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Vidio player toshiba v631 snowy all the time stand by
You need to clean the video heads and change the push buttons that not work
Jul 05, 2009 | Televison & Video
Picture loses all normal color & changes to snowy blues & greens
Not sure what causes it but it can be fixxed by your local repair guy, I just had mine fixxed for under a hundred bucks, he takes the back off and with a tiny screw driver adjust a few screws to near brand new perfect picture.. and it has been good ever since
Dec 01, 2008 | LG RU-52SZ30 52" Rear Projection...
Computer monitor problem
power supply is most likely going could be capacitors on the vga /inverter board also needs to be checkd out at a service location
May 01, 2008 | Gateway FPD2275W LCD Monitor
Konka klc 3211
i have the konka 32 inc lcd tv and it has power problem.thats why i want to buy a powerboarb and my tv model is Klc-3211QS and the powerboard sl no. is 10838.i want know the price of the powerboard.pleas reply me soon.
thanks
Md.Aminul Islam
Nov 14, 2007 | Konka KDL32AT23U 32 in. LCD Television
Snowy picture
A snowy video indicates that your input signal is relatively weak. On the other hand, a noisy picture is when there are too much interference is super imposing on the video.
Snowy picture comes about when the signal coming in the RF INput (Ant/Cable) at the back of the unit is below a certain level. If this is the case, then it is not a problem with your TV but rather your aerial (antenna) or the cable from your provider. A way to verify that it is the ant/cable that is the cause and not a defective TV/tuner is to hook up an old VCR set to Ch. 3 or 4 to the RF IN of your TV using a short 75 ohms coaxial cable terminated at both ends with FP-5 connector. Play a known clear good tape and set your TV to Ch. 3 or 4 as the case maybe. If the picture is relatively clearer, better, then you have just confirmed that it is indeed your aerial or your cable (provider) that needs looking into. If on the other hand, the VCR signal is also snowy then chances are that you have a problem with the input stage of your TV including possibly your tuner.
For your aerial problem, antenna orientation or replacing with a higher gain antenna might help solve the snowy signal. For your cable problem, you have to call-in for service from your cable provider. If it is a TV problem, your best course would be to seek the services of a qualified TV technician since this involve electronic circuitry analysis, diagnosis and possible component replacements.
Additionally, you may try looking for any loose connection, loose grounding, broken wire or anything out of the ordinary in your connections.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 12, 2007 | RCA P52926 52" Rear Projection Television
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
RCA VR637HF VHS VCR Logo
52 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
