Question about Frigidaire 26" Built-In Gas Cooktop - Bisque
I have a Frigidaire 26" gas cooktop (not sealed). It is the type where you turn the knob to start and an igniter clicks until the burner lights. Tonight while it was not being used, both front and rear igniters started clicking simultaneously and will not stop. I unplugged the unit to stop it. I did try replugging it in to see f the problem cleared but, it did not. It is currently unplugged. Do you know what the problem is? Thanks
  • 51 Answers
Thank you for accepting my bid. The ignitor switches are the problem. This usually happens when they get wet after cleaning the cooktop. Most of the time they dry out and will work a few days after. If they continue not to work properly they will need to be replaced. The switches just clip over the gas valves and are not hard to change. If you do need to get the part numbers for the switches I will need model number. Thanks again if you have any more questions let me know
Posted on Sep 28, 2010
Why want middle burner light automatically but will light with a lighter
That unit is suppose to have electronic quartz igniters. Apparently there's a problem but it doesn't automatically mean the igniter needs to be replaced. If you see a spark from the igniter then it's fine. If you see a spark but no flame then the ignition process is out of synchronization. In other words, the gas hasn't concentrated near the spark enough to ignite. This may be a matter of low gas pressure or the extra length the gas needs to flow to reach the center burner is impeding ignition. Simple fix is turn the knob just enough to start the gas for 2 seconds then continue the turn to click the igniter. or simply use a match. You may also see if there are any adjustments on the gas manifold that will enhance bringing more gas to the center burner quicker. Some unit have one click & that's it, others click the igniter continuously until you release turning the knob. Good luck. you'll figure it out.
Aug 13, 2015 | Verona VEFSGE365DSS 36" Double Oven Dual...
Cooktop burner do not ihnite
Hi hgodoy2 - Is the electronic igniter aligned properly? Ensure that tip of spark igniter is aligned with metal point or "nib" located on underside of burner cap after the burner mounting screws have been tightened. (Not all burners having mounting screws). When the burner control knob is set to the "LITE" position do the igniters spark? Can gas be heard or smelled coming from the burners when the control number is turned on? However, if you smell gas, I highly recommend turning the unit and the gas off if you can reach it and contact your gas provider. The range itself does not have a switch or regulator to relight it. Keep in mind that it may be experiencing an issue with the spark module, electrodes, wiring or EOC.
Nov 24, 2012 | Frigidaire 36 in.GLGC36S9E Gas Cooktop
Ingiter will either fail to start burner or won't quit clicking on the 1% of the times it does start up the burner
Hi look for adjustments to the lighter and also there should be a sensor tat sees the fire , this sesor allows the main gas to turn on, but only if it feels the heat , kind of like a thermocouple , if you think about about any type problem like this: what is it not doing ? then think what could cause this >/? if you go about any repair this way there is nothing you can't fix unless you need a part !
Dec 05, 2011 | Jenn-Air JGC8430 Gas Cooktop
My GE Profile propane gas cook top was just installed yesterday. When I go to turn on one of the burners, all of the ignitors click. This can't possibly be normal. Anyone else have this issue?
Yes, thats okay when you turn the knob voltage gets sent to the spark module, Then the module sparks all the burner igniter. And frame ignition only happens on the single burner of the knob you turned that sends gas to the burner associated with that knob.
Please rate me a "4" if this information was useful.
Dec 14, 2010 | GE Profile JGP636 Gas Cooktop
Piezo goes off every 10 seconds.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 10, 2010 | Whirlpool SC3017RQ 30 in. Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
I have a JGP636 or 960. One burner won't do
When you turn the burner knob on does the igniter click and turn off on it's own when the flame ignites? If it does then it has flame rectification. That means it can sense when the flame is on. Or does it click when the knob is in the light position and not stop until you move the burner knob? Then this is standard ignition. If it is standard ignition it sounds like it is the igniter switch built into the burner knob might be defective. Are you able to turn on any burner knob and when they are in the igniter position do all the electrodes spark or just the burner that you are turning on? If they all come on then they are wired in a series. If they are wired in a series do you get a spark at the electrode of the problem igniter? If so you can turn on one of the other burners to ignition position then while it is clicking turn on the problem burner to light it. If the cooktop uses flame rectification then there may be a problem with the switch built into the burner knob or the flame rectification sensor for that burner might be bad.
Sep 29, 2009 | GE Profile JGP636 Gas Cooktop
I have a jenn-air sealed gas cooktop jcg8430 only 1 burner lights
you have a problem with the ht leads or spark electrodes
Aug 18, 2009 | Jenn-Air Cooktops
Trouble with Kenmore Gas Cooktop
hi there,
the clicking noise is the spark module trying to ignite. i would get a technician to come and check it.
Sep 28, 2008 | Cooktops
Frigidaire 26" Built-In Gas Cooktop - Bisque Logo
57 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
