Question about Sony Handycam DCR-HC20 Mini DV Digital Camcorder
When I turn on my camcorder, it gives me an error message that says, Lens cover not fully open. What should I do?
    Genius:
  • 1,812 Answers
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Posted on Sep 28, 2010
HG20 lens cover opens fine but camera doesn't know it - give error message. Camera did get damp and lens cover didn't open fully at times for a short while but corrected itself. Error message was...
Apparently there is some water damage to the circuit that tells the camera the cover is open. This can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Nov 21, 2010 | Canon VIXIA HG20 DVD Blu-ray Camcorder
Lens Cover not fully open
It sounds like a problem with the firmware in the camcorder itself. As an authorized Sony repair person, I have gotten no technical bulletin on this model. The firmware is preloaded into the microprocessor IC. You will need to have this unit looked at by an authorized Sony repair center who specializes in camcorder repairs or send the unit to a Sony factory service center. good Luck
May 22, 2007 | Sony Handycam HDR-HC1E HDV Digital...
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
Hi I have DRC-SR200 camcoder, bought one year ago. Issue is lens cover is not opening. On the LCD display there is a message "lens cover not fully open. Turn off and on". I tried that but no use. Went...
Hi, perform the following steps to get this issue resolvbed... 1. Check whether the lens cover is opened 2. check whether the battery is fully charged. If the battery is not fullly charged, connect the Camcorder to the wall outlet using the sipplied AC adaptor. 3. Then, try resetting the Camcorder by pressing the RESET button using a sharp-pointed object while the Camcorder is turned ON. 4. If the issue still persists, turn OFF the Camcorder; then remove the battery pack and discinnect the Ac adaptor from the Camcorder; slide the POWER switch to the ON position for 1 minute. Then, connect the AC Adaptor tro the wall outlet and cjeck whether it helps.
If the issue still persists, service of the unit may require. contact the manufacturer of the Camcorder to get ut serviced.
Jul 10, 2009 | Sony Handycam HDR-HC1E HDV Digital...
Lens cover won't open
I have the same problema. Have you fix it? How? I appreciate your answer. Regards, Diego dspeier at yahoo.com
Feb 23, 2008 | Sony Handycam DCR-HC96 Mini DV Digital...
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Coolpix s6 lens cover error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. Its is a step by step solution with images.
Regards Mukesh
Aug 30, 2007 | Nikon COOLPIX S6 Digital Camera
Lens Cover won't fully open
Hello Tomkimball, the solution for your problem is in replacing the lens barrier. Part number is 178727811. Best regards, Arpad
Oct 30, 2006 | Sony Handycam DCR-HC90 Mini DV Digital...
Lens Cover will not open or close
OMG! I had the same issue and blew on the lens. To easy to be true, but it worked! I thought maybe it was a fluke, so I turned the camcorder on and off several times, and it worked every time! Sure beats the $341 Sony was going to charge to fix it!!!!
Aug 23, 2006 | Sony Handycam DCR-DVD403 DVD Camcorder
Sony Handycam  DCR-HC20 Mini DV Digital Camcorder Logo
88 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
