Question about Samsung LN32C350 32 in. TV
Will the Samsung LN32C350 work with a regular Direct TV receiver, (not High Def receiver)? How do I hook it up?
    President:
  • Samsung Master
  • 1,779 Answers
Sure. Just use the a/v input jacks on the rear of your set. Use the Yellow (for Video) Red (audio-R) White ( audio L ). You should have no problem.
Posted on Sep 28, 2010
Testimonial: "Thank you! I've gotten various answers from the "experts" at the stores, and my carrier. I might jump and see what happens!"
We are trying to hook up a samsung flat screen TV, a sony home theater system, direct tv box, and a panasonic DVD to the dynex component video converter box. Which cable goes where
We can't make assumptions. Did you set it up in accordance with the manuals?
Without specific details...
In general, ins go to outs; compatible connectors need no modification.
If you have an HDTV and HD Satellite I don't think you want to be tying the video quality down to S-Video.
There are two signals to consider here. Video and Audio. TV's are expert at Video and A/V Receivers are expert at Audio, so each should get first crack at the specialty for which it is designed.
HDMI or Component Video (Red, Green and Blue RCA cables) are the best and ONLY ways you'll get Hi Def to the TV. If you route EACH HIGH DEF SOURCE'S VIDEO DIRECTLY to the TV (instead of through the receiver or a switch) the TV/monitor will receive the best video digital data.
Digital Audio from as close to the real source as possible (SAT Box, maybe) to the receiver.
Standard analog audio from the SAT box to the TV for watching lo-fi content like news and weather without the Sony HTS turned on.
Mar 15, 2011 | Dynex S-Video A/V Selector Switch
How can I get my Denon 2106 to play through my television? I'm not sure what's happened. I feel like I have the cables hooked up properly. It's worked for years. My stereo plays, so it's not the speakers....
Hello: If you are trying to get the sound from the TV to come through the receiver to your speakers and are hearing nothing, I had the same problem. For some reason, and I have the question posted, the sound level requirement is much higher for the TV. I turned my receiver up to +2 decibels and the sound was there. However, if you play high def channels through the receiver, the +2 will blow your ears off. My new problem is why does the regular TV need so much volume on the dial while the high def channels only require the lower sound level. It prevents you from switching from regular to high definition channels. So, in summary, the sound is there, just turn the volume way up.
Oct 30, 2010 | Denon AVR-2106 Receiver
The TV only received High Def chanles. When switched to reg. chanels, there are green vertical lines and you can see the goast chanel behind the green lines. On pic in a pic setting the pic. chanel is...
Exact same thing happened to me last night. The TV only received High Def chanles. When switched to reg. chanels, there are green vertical lines. Light is definitely on and visible in the back. Now goes out after abut 30 sec. Misery loves company. Will watch the site for a solution. 4yrs. old just went off extended warranty 45 days ago. damn
Feb 12, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
No picture - only sound
Ok, on a hi-def tv, you must have a converter box capable of receiving Hi-def. If you are using a converter box from a satalite or cable tv service, try getting a Hi-def box. Also try hooking a vcr or dvd player to the tv in the non high def ports to varify that this is the problem. If you have any question please let me know, I hope this helps, good luck.
Sep 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Have xbox 360....got used,no instruct. book,was hooked to flat screen tv, no longer have flat screen tv, have regular tv hook up game comsole to tv, wont work.....why
If it was hooked to a flat screen it was most likely on high def. There is a switch on the connection to the tv to make it work on a regular defination tv. Just slide the switch over to regular and it should work. Hope this helps.
Sep 12, 2009 | Microsoft Xbox 360 Console
Is my hd1080 that i bought about 8 to 9 years ago a high def
If your TV has HDMI inputs or if your receiver has component video out, then answer is yes. Please repost if you need any help.
Aug 30, 2009 | Mitsubishi WS-55807 TV
Need a tuner for HDTV Samsung Model #HLR4667W
THERE IS A DIODE ON THE MAIN SIGNAL BOARD THAT HAS SHORTED OUT REPLACING THE TUNER IS NOT GOING TO HELP MATTERS
Oct 16, 2008 | Televison & Video
Samsung lcd tv not working as the picture is blurry and not clear
are you watching a high def channel? Standard def channels appear blurry, rather more like youtube videos, because the technology is advanced enough to really show all of the flaws.
May 24, 2008 | Samsung Audio Players & Recorders
Panasonic legacy connection
s-video is a legacy connection. legacy means obsolete and this will impare your image.
what you should do is connect the cable box and blue ray directly to tv with hdmi cable, then run audio cables back to the reciever from these devices. the vcr and regular dvd player would be routed through the reciever the conventional way. you would have to change the inputs on the tv between the cable box, and blue ray if u have one, and a seperate single tv imput for components running thru the stereo. you would have to use the reciever to select between audio sources, and the video sources between the vcr and dvd only.
Nov 04, 2007 | Panasonic TH-50PHD8UK 50 in. Plasma...
Samsung LN32C350 32 in. TV Logo
206 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
