Question about Dell Dimension 4600 PC Desktop
Desktop gon blue background
When times I try to save a file the system crash and blue background screen appeared with white letters and system error appers in a flash moment and the booting option( normal/safe etc appears.) then the system restarts. why it happens
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    A Blue Screen crash and instant reboot is the default or programmed behavior for Windows XP.
    Where are you trying to save the file to. A folder on your main drive, a CD, a Floppy?
    Regards,
    Worldvet
  • 121 Answers
I advise you to reinstall windows.
Posted on May 24, 2008
Nokia E90 freezing on blue nokia white background
It seems your phone has corrupted its operating system. But no worry, just flash program it with latest Nokia E90 flash file. You can download it to your PC and using Phoenix tool or ATF/ HWK UFSX as flash platforms. Or simply let an expert near you do it for you. It's simple but needs experience to avoid damage to your unit.
May 08, 2014 | Nokia E Cell Phones
Tip
How to View Windows Minidump Files
First of all, you need to configure Windows to save these important log files. Most of the time, this is already done automatically, however follow these steps to make sure these log files are being saved.
1) Click on Start
2) Right-click on My Computer
3) Click on Properties
4) In Windows XP , click on the Advanced tab. In Windows Vista , click on the Advanced System Systems option on the left side of the screen.
5) Under Startup and Recovery, Click on the Setting button
6) Under the System Failure section, you'll see the options for the memory dump file. Write an event to the system log should be checked along with Send an Administrative Alert. The debugging information should be set to the Small Memory dump (64K) and generally the Small Dump Directory is set to %SystemRoot%\Minidump. In most cases this is the C:\Windows\Minidump directory.
As far as the third check box is concerned, if this is checked the computer will automatically restart when a blue screen error message is encountered. So, if your computer is booting into Windows, then rebooting automatically most likely you are getting some sort of blue screen error message and its forcing the computer to restart. If you uncheck this box, then the message itself will appear so you can retrieve important details about the error.
Download and Installing the Debugging Tools to Read Minidump Files
In order to view the Minidump files, you have to download the following tools.
Debugging Tools for Windows including WinDbg
Although most of the time its not necessary, you can download the Symbol packages as well as the Debugging Tools so you can read the Minidump logs easier. Once you've downloaded the Debugging Tools for the correct version of Windows and installed them, open the WinDbg program by following these steps.
1) Click on Start
2) Click on All Programs
3) Click on Debugging Tools for Windows group
4) Click on WinDbg to open
The screen should look similar to the one below.
Deciphering the Minidump Files
In the WinDbg program, click on File, then click on Open Crash Dump
Browse to the following directory on your hard drive and open a minidump log. The drive letter will be whichever drive you installed Windows on. In most cases, this is drive C.
C:\Windows\Minidump
After you open a minidump file in WinDbg, scroll to the bottom of the file. You should see a line that says Probably caused by:, followed by a filename. This is the problem file. In my case the file was related to the ELock Program in the Acer Empowering Technology set of tools. I simply uninstalled this program from the computer and the blue screen and problem went away.
Probably caused by : eLock2FSCTLDriver.sys ( eLock2FSCTLDriver+11332 )
Although you may not recognize the file that is causing the problem, it definitely helps in tracking down a solution for the blue screen error message and resolving the issues.
on Jun 25, 2010 | Computers & Internet
I have a Dell Inspiron One 2305 with windows 7 it constantly crashes and comes up with a blue screen also when it boots up i get an error message for the catalyst control center.
Use a system utility software like RegInOut to fix blue screen error. It will fix corrupt registry files & windows file.
Hope it works for you.
Dec 28, 2011 | Dell Inspiron One 2305 Desktop Computer...
I can't seem to change my desktop solid colour background back to the dots background. I have tried to do it on the appearance and personalistion mode from the control panel with no success
Hello
1. Open a notepad, and copy the following commands and then paste them into the opened Notepad window.
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"Wallpaper"=-
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"Wallpaper"=-
2. After the above commands have been pasted, please close the Notepad window. Choose "Save" when you are prompted to save the file. When the "Save As" window pops up, please click "Browser folders", click Desktop, change the file name to register.reg and click Save.
3. Go to Desktop, you will find the file.
Before you you run this file, please make a backup for your registry first, you can refer to the following link:
http://windows.microsoft.com/en-us/windows7/Back-up-the-registry
After that, you can double click register.reg to run the commands that have been pasted.
In addition, please uncheck the setting in the Ease of Access Center.
1. Click Start, Control Panel, Ease of Access, Ease of Access Center.
2. Click Make the computer easier to see, Under Make things on the screen easier to see, deselect the option:
Remove background images (where available).
3. Select Save.
After that, you should be able to change the desktop background now.
I hope this would help you.
Apr 15, 2011 | Computers & Internet
Blue screen appears at start up boot screen and restarts again
press "F8" while statrting , and then select "safe mode"
Feb 01, 2011 | Computers & Internet
I am trying to SCAN a photo and save it to my SCREEN SAVER and at the same time enlarge it to fit the entire screen.
The photos in your computer can be used as screen savers (those files that pop up when you are idle).
1. Right click on your desktop and choose personalize.
2. Select Screen Saver
3. Select Photos
4. Click OK
All of the photos in your pictures folder will be your screen saver.
If what you want is this picture to be your background (the file that shows on your desktop all of the time)
2. Select personalize
3. Select Desktop Background
4. Change the "Location" to Pictures from its setting of Windows Backgrounds
5. Select a picture
6.Click OK. It is automatically sized to your desktop.
Dec 03, 2009 | Microsoft Windows Vista Home Premium with...
Blue Screen of Death
it gonna need a reinstall of windows to work
Sep 28, 2009 | Dell OptiPlex 270 PC Desktop
Display background color
Check your MS Windows System colors
Most likely that is the cause of the problem.
Sep 29, 2008 | Corel WordPerfect Office 12 Standard...
Computer will not start
When Windows crashes with blue screen, it writes a system event 1001 or 1003 and a minidump to the folder \windows\minidump. Check system event 1001 and 1003 and it has the content of the blue screen
Event ID: 1001
Source: Save Dump
Description:
The computer has rebooted from a bugcheck.The bugcheck was : 0xc000000a (0xe1270188, 0x00000002, 0x00000000, 0x804032100).
Microsoft Windows..... A dump was saved in: .......
Event Source: System Error
Event Category: (102)
Event ID: 1003
Description:
Error code 1000007f, parameter1 0000000d, parameter2 00000000, parameter3 00000000, parameter4 00000000
Control Panel -> Adminstrative Tools -> Event Viewer -> System -> Event 1001/1003. Copy the content and paste it back here
Aug 17, 2008 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Dell Dimension 4600 PC Desktop Logo
62 people viewed this question
Alun Cox
